Old 02-01-2016, 08:42 PM   #61
Retusps's Avatar
Originally Posted by 05CrewDually View Post
You can get a ScanGaugeII @ Advance Auto for around $150. Order it online and use promo code TRT30 to get a discount and pay only $111.99.
It will read not only Trans temp but practically every other sensor on the powertrain. It can also check for codes.
Below is a picture of it's display. Simple one plug hook up to the OBDII port under the dash.
Advance Auto Parts: Shopping Cart
WOW !! Good call on the ScanGauge II! So much easier than the route I was thinking about, and it shows so many other readings besides the one I was after. Advanced Auto matched the $111.99 online price out the door, no waiting by the mailbox! Thanks for your help.
No matter where you go, there you are!
2018 3500 Chevy Silverado, Duramax, CC, Z71, SRW
2014 Palomino Solaire Eclipse 297rlds
Husky Centerline w/d hitch
Retusps is offline   Reply With Quote
Old 02-01-2016, 08:56 PM   #62
Who Dares, Wins
doc73's Avatar
Originally Posted by buckaroo2 View Post
Did i miss something here ??,Are we talking about the gas transmission or the duramax allinson trans mission which i believe are a lot tougher than the gas model trans I have a new 2015 duramax allinson tranny now you have me curious to lookaat my manual to see what max temp will be . as I just got this truck and have not towed with it , until i pick up our 36ckts in the spring
Back 900 pages or so.. I think it was for gas. But wither way it is a good resource.
I was interested to see the 215 on the Durmax.. Mine never got above 170 in the mountains, but good to hear the max temp to look out for.
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 02-01-2016, 10:32 PM   #63
2007 WildCat 32QBBS
18CrewDually's Avatar
Excellent. You can use that promo code all the time on other products and pick them up in the store. I do it all the time.
I'm guessing you found the ScanGauge website with the listing of X-gauges that you can enter in? You can also piggy back them for 8 display.
It's a priceless piece for guys like me running a Ford 6.0 diesel. Oil/water temp delta is a biggy.
18CrewDually is offline   Reply With Quote
Old 02-03-2016, 10:40 PM   #64
Retusps's Avatar
Yes, I found the X-gauge codes on the website. I'm not sure what you mean by piggy backing for 8 display. Sorry, I'm from the age where you drill a hole in the pan and stick a sending unit in it and run a wire up to the dash and attach it to a cheap gauge. I put it in my GMC 1500 gasser to monitor the tranny temps while towing. I can't find the oil temp on mine, computer must not register oil temp. It's a great tool just the same. Thanks for sharing your knowledge!
Old 02-03-2016, 11:00 PM   #65
2007 WildCat 32QBBS
Piggyback or daisy chain I mean you can hook 2 together with an additional cord so you don't have to scroll through to check other readings. In essence you have 2 live displays coming from the one OBDII port.
So, what kind of trans Temps are you seeing?
Old 02-03-2016, 11:34 PM   #66
acadianbob's Avatar
I've been using ScanGaugeII for 10 years. Very useful device.
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 02-04-2016, 05:59 PM   #67
Retusps's Avatar
Thumbs up
I'm following you now! I don't need to see 8 readings at once, so I'll just use it as is for now. As far as temps go, it's been between 98 to 130 degrees not towing. Cold weather here in K.C. keeping it down I think. I'm not sure what max temp should be for it either. Any idea?
Old 02-04-2016, 10:14 PM   #68
Who Dares, Wins
doc73's Avatar
250 (might be 230) I think. My 1500 would get to 205 at its highest when towing.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 Chevy HD D-Max
Old 02-04-2016, 10:29 PM   #69
2007 WildCat 32QBBS
GCVW ambient air temp, and hills will all play part but on flat land towing with my Ford it's around 165-180. Pulling long 8% grade it will creep up around 200+. Keep it below 230 for any extended time and your fine.
Old 02-04-2016, 10:47 PM   #70
duramaxlbz's Avatar
Best thing to monitor your truck is a CTS 2... but for the Allison 100° above outside temp. But you don't want her to get over 230 pulling a hill. Your clutchs will hate you and it might Limp the tranny
duramaxlbz is offline   Reply With Quote
Old 02-14-2016, 09:05 PM   #71
danielabram71's Avatar
My gmc 1500 runs 195-200 not pulling anything. And with the camper around 210
danielabram71 is offline   Reply With Quote
Old 02-14-2016, 10:24 PM   #72
2007 WildCat 32QBBS
Year?
Old 02-17-2016, 10:15 PM   #73
Its a 2014. Extended cab. I just get bored on the hr drive to work. I flipped through the read outs the other morning and it was 11 degree's and trans temp 198. I really don't understand it. I had the service tech at the dealer cheek the trans oil ever time said it is all ok. And it don't have that burnt smell. I really keep a eye on it. He said that if it gets too hot a warning will go off in my instrument panel.
Old 02-17-2016, 10:28 PM   #74
2007 WildCat 32QBBS
You seem concerned but I wouldn't be. Many transmissions of today are thermostatically controlled so they warm up quickly so they're in the desired operating temp range.
Also, some have multiple PIDs for transmission temps. You may be reading the sensor of the used hot ATF before it's pushed through the coolers. You may have another temp sensor available that may read 15-20 degrees cooler.
Old 02-18-2016, 11:05 PM   #75
Most light duty cars and trucks run around the coolant temp for trans temps. The HD trucks run a lot cooler due to big coolers. 8K Behind a Diesel truck they run 160-180 F max usually.
jasonTDI is offline   Reply With Quote
Old 06-18-2016, 11:22 PM   #76
mrpep's Avatar
I just installed a trans cooler this evening and tomorrow I install the Gage. I am planing on placing it into the test port and I read that its not an optimal spot and some say its good enough, the manufacture of the temp Gage states to use the test port so i'm not sure. I have also read a few posts where people stated that they duct tape the probe to the trans output line and as close as possible and it works well for them. Still not sure what my approach i will be tomorrow but I think i will be going with the test port on the side of the trans. Another thing I did that I read a lot of disagreements on is I did not bypass the original trans cooler on the factory radiator. The cooler installation manual also called this the optimal way to cool and it makes sense to me. What do you all think ?
mrpep is offline   Reply With Quote
Old 06-19-2016, 12:07 AM   #77
Bluepill's Avatar
FWIW, a transmission tech told me he likes to see the temps get a bit above 212 from time to time. That is hot enough to boil out any moisture that has gotten into the fluid. The trans will "breathe" a bit as it cycles from cold to warm, and that can bring in humid air.
Old 06-19-2016, 12:15 AM   #78
duramaxlbz's Avatar
212 is getting up there for a Allison. A Allison should run 100* above outside temp. Mrpep do u have a duramax? If so you should run a edge insight to monitor your truck period. It reads off the ecm. I last have a truck with gages also. I prefer the cts over gagues.
ID:	111549   Click image for larger version
Old 06-19-2016, 12:36 AM   #79
2007 WildCat 32QBBS
160-180 is warm enough to cook off any moisture, it just takes longer than if it was at 212. If the truck is ran almost everyday moisture is not an issue. My Yukon sees temps to only 165 or so. So in your mechanics theory it should have 5 years worth of moisture in it. I assure you it doesn't.
Just putting this out there so no one gets worried their Trans is too cold.
Now, where his theory holds true is in motor oil of piston engines in fixed wing aircraft. But that's another story.
Old 06-19-2016, 06:12 AM   #80
Follow the instructions of the supplier. They have likely tested it throughly. Not bypassing could cause a drop in pressure and cause flow issues of the atf but I have not seen your set up. That would be worse than just the stock cooler.
transmission temperature
