Old 08-22-2016, 05:03 PM   #101
danielabram71's Avatar
Ok I did a little checking on my way home from work today. I decided to watch my trans temp on the way home with nothing in tow. This is what it got up to
Name:	ImageUploadedByForest River Forums1471903355.486285.jpg
ID:	118147 I was so shocked
1014 1500 GMC
2015 solaire 267bhsk
danielabram71 is offline   Reply With Quote
Old 08-22-2016, 05:23 PM   #102
raspivey's Avatar
That may be a bad sensor. I ran about 192 pulling with 95 degree outside temp about a month ago. Otherwise, I'm well below 160.
Old 08-22-2016, 05:29 PM   #103
2007 WildCat 32QBBS
18CrewDually's Avatar
Attachment 118147 I was so shocked
1014 1500 GMC
Let it sit 24 hours. Then before starting, compare 3 temps.
1. Ambient air
2. Engine Coolant Temp.
3. Automatic Transmission Temp
They all should be within a few degrees Fahrenheit.
18CrewDually is offline   Reply With Quote
Old 08-22-2016, 05:40 PM   #104
Flybob's Avatar
The highest mine has ever been is 197 and that was after jockeying into a tight site after driving for 2hrs on a 90 degree day.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-22-2016, 06:04 PM   #105
Oh yes I forgot to put the temperature outside was 71. Eng. temp was about 210 or so
1014 1500 GMC
Old 08-22-2016, 06:08 PM   #106
raspivey's Avatar
Yeah...that seems much too high. I normally see about a ten degree increase through town at slower speeds but, after an hour or so of highway, back down in temp. I agree, let it get cold and compare all the temps.
Old 08-22-2016, 06:22 PM   #107
Members
Tommy Joann's Avatar
Mine runs between 192 and 199 when towing.
2018 Salem 28RLDS Showstopper Package
2015 Chevy Silverado Crew Cab LT Sport
Husky Centerline WDH
Tommy Joann is offline   Reply With Quote
Old 08-22-2016, 06:29 PM   #108
TsnTexas's Avatar
Maybe someone addressed this already, but I'm wondering at what temp. does the transmission fluid begin to break down. Going over Wolf Creek Pass in Colorado I watched my fluid climb to 207 degrees and am wondering if I should go ahead and replace it? Normally runs about 160 on a hot day in Texas.
2016 Rockwood 2504s
2016 Chevy 2500HD
TsnTexas is offline   Reply With Quote
Old 08-22-2016, 06:36 PM   #109
raspivey's Avatar
I think it was mentioned...over 270 ish if I'm remembering right. I was running up I45 out of Houston last year and my outside temp was showing 104. Trans actually got up to about 208. I believe there is a trans overheat light but it never came on. It felt like it was starting to slip a little so I pulled over and cooled it down. My rule has become change it if it goes over 200 for more than about 30 min. just to be on the safe side.
Old 08-22-2016, 07:03 PM   #110
My truck is a 2014 I bought it when it had 400 miles on it. It has done this the whole time I have had it. Believe it or not that is about the same as when I row the camper. A guy at a KOA told me one day that it has a 195 degree thermostat in it and that is why. I have no idea my first GMC ever
1014 1500 GMC
Old 08-22-2016, 07:26 PM   #111
raspivey's Avatar
I'm going to have to partially call BS on that one, lol. Without an external cooler, you're relying on the radiator for cooling but, even if you don't have an external trans cooler I have a hard time believing you're running that hot with those outside temps. If you are and you don't have one..definitely get a cooler. Cheap and easy insurance.
Old 08-22-2016, 09:04 PM   #112
Well I looked at my outside temp it was 71 we did have a cool day in wv today and then I took the picture of my temp. The outside temp is on my radio display and I could not get it and the dashboard in the same pic. But I have no reason to lie about it. That is what it was. Sorry if I have taken you the wrong way but the picture speaks for itself
1014 1500 GMC
Old 08-22-2016, 09:07 PM   #113
I have asked my dealer service about it and they said they have no idea when a warning light would come on and yes I may have a bad sensor idk.
1014 1500 GMC
Old 08-22-2016, 09:09 PM   #114
No I don't have a cooler on it. It is all factory.
1014 1500 GMC
Old 08-22-2016, 09:11 PM   #115
raspivey's Avatar
No, I wasn't calling you out. I don't doubt that's what it said, just that I don't think it's right. Then again, it may be. I'd definitely get a decent cooler for towing though. I've heard of people seeing 30+ degrees difference versus not having one.
Old 08-22-2016, 09:13 PM   #116
I am sorry for miss understanding you. My apologies. But how ever this truck has ran 200 plus the hole time I have had it. Dealer said its fine. With camper in tow or not
1014 1500 GMC
Old 08-23-2016, 07:04 AM   #117
Ok today on my way to work this is what I got Click image for larger version
Name:	ImageUploadedByForest River Forums1471953857.015258.jpg
ID:	118175Click image for larger version
Name:	ImageUploadedByForest River Forums1471953876.506704.jpg
ID:	118176 outside temp 59
1014 1500 GMC
Old 08-23-2016, 08:20 AM   #118
With the outside temps near 100 + hear in Texas, my transmission temps will go between 198 and 203. My engine temp also goes up a few degrees. Normally, my engine temp runs around 210, regardless of outside temp. However, when towing in the real heat, 100 +, I have seen 215. On the engine temp gauge, there is nothing that indicates what is considered overheated. Does anyone know at what temperature an engine is considered overheated?
AS Rabbit
2016 Wildwood 195BH
2009 Silverado 1500
Asrabbit is offline   Reply With Quote
Old 08-23-2016, 05:04 PM   #119
On my recent trip few days ago my tranny was reaching 230 on some inclines. 5500 trailer, 2011LT 4.8 Cc. I have an additional tranny cooler from etrailer-the bigger one. Temp outside was around.83.
Kuba is offline   Reply With Quote
Old 08-23-2016, 05:31 PM   #120
synthetic has higher temps, i recall most newer trucks come stock with synthetic
pbandrb is offline   Reply With Quote
transmission temperature
