Originally Posted by HiTech
Please never, ever, ever run 85 octane in an engine recommending 87. There is significant risk of dangerous preignition.
I did buy a 2001 E450 v10 that I drove for 10 years. My recollection is I got about 9.5 MPG long term not towing, no matter what the conditions. However, that was running a 20 year old PCM, strategy and calibration. These are periodically updated with significant new algorithms and technology (faster processors with much better knock detection, for example). I believe the V10 had one hardware update sometime since then as well, before Godzilla replaced them.
One of the byproducts of faster PCMs is the ability to be much more aggressive on adding a bunch of timing, say to climb a hill, and then let the heads cool off on the following downhill run. Modern Ford HP and torque numbers are based on top tier premium fuel, a recent change. The reason is that premium gives you more power and torque on modern Ford engines.
MOST of the time, an engine does not need the full rated octane. 85 octane gas is sold at higher altitudes for precisely this reason. At altitude, a
normally aspirated engine cannot generate the pressures needed to cause pre-ignition, so a lesser octane gas can be safely used. A turbo or super charged engine maintains internal pressures and temps at altitudes, so running lower octane is not advisable.
The full octane rating is needed to prevent pre-ignition when heavily loaded and/or running hot (the "normal" when towing). That's when internal pressures and temps are at their highest, and pre-ignition is most likely. Cruising with light loads doesn't generate high pressure or temp, and so lower octane is suitable.
Since I live at 6700ft and seldom go below 5000ft, running 85 octane for normal driving has no detrimental effects on my non-turbo engines. When I'm towing, I specifically use 87 octane at altitude, and 89 octane at sea level so that I do not trigger timing retardation.
Ford does rate their turbo engines using 93 octane gas. Which tells me that if I need max power or am running the engine hot, I need to be using 93 octane. Cruising and not using much power, I can probably use a lower octane gas safely.
Learned all about octane, pre-ignition, engine temps, timing, and mixture flying carbureted piston engine aircraft.
Fred W
2019 Flagstaff T21TBHW A-frame
