Old 08-20-2019, 10:28 AM   #1
Need a new Equalizer shank
You may recall that I replaced my 4x2 5.0L F-150 SCab with a 6.2L F-250 Crew Cab FX4 (4x4). That thing is tall, 7' tall. And it has a Class V (2.5") receiver. My Equalizer has a Class IV (2") shank.
Obviously, the answer is buy a new shank (Fastway confirmed that's all I need to do), but which one? There are three: 3" drop 7" rise, 4" drop 8" rise, and 6" drop 10" rise.
The truck has a serious rake. Ground to front wheel well is 39.125". Ground to rear wheel well is 45.25". (see pic) Both measures are unloaded.
http://www.forestriverforums.com/for...1&d=1566313464
So, how to determine the appropriate drop? I doubt that it will be rise. Trial and error is out of the question. One thought is to hook up using the 2" shank only for the purpose of loading the backend to get a loaded height for the receiver (absolutely no pulling!). I'm open to the collected wisdom of the group.
Mark Wilson
No trees were harmed while sending this message;
however, a rather large number of electrons were terribly inconvenienced.
TT: 2018 Surveyor 243RBS TV:2019 F-250 XLT 6.2L 4x4 Crew Cab
mawilson is offline   Reply With Quote
Old 08-20-2019, 10:34 AM   #2
Just Tryin' to Help
cboss's Avatar
My F250 came with a 2 inch insert for the hitch. I've towed our TT over 18000 miles with it.
Craig & Cath
2018 2902WS Rockwood Ultra Lite
2017 Ford F250 Lariat, 6.2 gas
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2016(retirement): 930
cboss is offline   Reply With Quote
Old 08-20-2019, 10:58 AM   #3
Grammar Pedant
67L48's Avatar
Unfortunately, I can't give you the exact answer you're looking for. I'll make three points of varying degrees of utility:
1) For 2" to 2.5", there are reducer sleeves available. Ford has a PN (HC3Z-19H282-A) for this and it's around $25-$30. Or, you can go to Walmart and get a Curt/Reese reducer sleeve for $10. I did the latter. Works fine.
If you need a new shank, then definitely just get the 2.5" one. But, this shouldn't independently drive the need for a new shank. In fact, it shouldn't even be a criterion in the decision process. Base your decision on the ability to level the trailer. If your current shank doesn't drop enough, then you need a new shank ... and then get it in the 2.5" flavor.
2) I went from a F-150 to an F-350. Definitely a taller truck, but I was able to move my hitch head down the existing shank. I'd like another 3/4" of vertical drop, but that is not near enough to justify $130 on a new shank. So, even though the F-350 is much taller than my F-150, the shank had enough adjustment to accommodate both trucks ... granted both my rigs are 4WD.
You're going from 2WD to 4WD, so that may push you into a different delta than I dealt with. But, still, I'd go ahead and try your existing shank first. By dropping the hitch head to the lowest setting on that shank, you might be surprised by how close you are to the right height.
Of course, you may still discover you need a new shank.
3) I think you have a 6.2L and an F-250. So, you definitely have a softer rear end than me (insert your own joke here). I don't know how much weight you're dropping onto the hitch, but the rake should settle out.
This plays into point (2) above, too -- try it with your existing shank first, as you might be surprised how it settles out.
Based on how your trials in (2) go, you should have a good idea on how much additional drop you need. From there, you should be able to spec out the proper shank or, at least, be able to call Equal-I-zer and discuss options/measurements.
Good luck.
Yours is a 2017. OP has a 2019. 2019s do not come with 2.5 > 2 reducers anymore.
Former RV: 2018 Rockwood Mini Lite 2504S
67L48 is offline   Reply With Quote
Old 08-20-2019, 12:01 PM   #4
007matman's Avatar
Park both the truck and trailer on a level surface. Unhook and pull up a few inches (just far enough to get the hitch out from under the coupler). Level the trailer out.
Measure the distance from the top of the ball to the ground. Then do the same for the coupler. The difference is your drop. Subtract about an inch and that's the drop you need to get. As always, having some extra is not a bad thing (unless it drags on the ground). Even if you do drag on occasion it could always be shortened (I did this).
007matman is offline   Reply With Quote
Old 08-20-2019, 12:13 PM   #5
Go buy a factory 2.5 to 2" adapter. Factory ones will have a flange on the outer edge to prevent the sleeve from sliding to the back of the receiver tube. Readjust head height if needed. DONE....and far cheaper than a new shank.
TheWolfPaq82 is offline   Reply With Quote
Old 08-20-2019, 12:17 PM   #6
Does Equalizer make a 2.5" shank?
They didn't last year when I bought one with a longer shank to be able to get my tailgate down. I just used the reducer sleeve and adjust mine, I think it was 4" drop version when I went from my F150 to the Ram.
2019 Forester 3011 DS
2015 Jayflight 28BHBE (sold)
2015 Ram 2500 Megacab 4x4 6.4 L Hemi 4.10 gearing
"Is this a game show?"
sugarray40 is offline   Reply With Quote
Old 08-20-2019, 12:34 PM   #7
Canadian Member
Equal-i-zer sells 2.5" shanks if they make one with the right drop for your application.
https://www.equalizerhitch.com/store/shanks
When I upgraded to my F-250, I bought a new shank from RV Wholesalers. They had the best price I could find at the time.
It took about 3 tries to get it dialed in just right but I had it dialed in so well that I didn't notice a big difference when I went to my fifth wheel. Equal-i-zer makes a great WDH.
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
Old 08-20-2019, 12:41 PM   #8
007matman's Avatar
One from Curt is available too.
That's what I bought for my E2 (which is very similar).
Old 08-20-2019, 01:59 PM   #9
rlh1957's Avatar
I called the maker of my hitch and explained what truck I had and what truck I moved over to and that it made the trailer too high in front with stock hitch all the way down on it. They looked up what I should need and told me places to look for replacements.
It's not cheap so make sure you are adjusted all the way down on what you have before buying another one.
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
rlh1957 is offline   Reply With Quote
Old 08-20-2019, 07:39 PM   #10
I also traded my F150 for a 2017 F250 crew cab 6.2. I’m towing a Salem 27RKSS.
I went with 2.5 shank and a 6 inch drop. It worked well on mine.
2017 Salem 27 RKSS
ssamme is offline   Reply With Quote
Old 08-21-2019, 03:43 PM   #11
I had to buy a 9" drop shank in the 2" size when I went from a Frontier to a Ram.
Ram supplies a reducer so I can use a 2" shank in 2.5" receiver.
The Ram is very high in the back.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 08-21-2019, 04:09 PM   #12
rlh1957's Avatar
My Ford F350 came with two reducers. I use the reducer and my 2" Shank. The reducer just gives you more metal in that receiver, it doesn't make it weaker or less. I don't get any noise from the receiver and shank with hitch on it.
I too had to get a shank with more drop when I changed trucks, the F350 SRW was a good bit higher even with the air bags all the way down.
24WS
FX4 Off Road (4X4)
Old 08-23-2019, 01:31 PM   #13
thebrakeman's Avatar
You do not need an Equal-I-zer brand shank. Just be sure it has the weight rating you need (equal or greater than the ratings on the WDH and your vehicle).
thebrakeman is offline   Reply With Quote
Old 08-23-2019, 01:48 PM   #14
Ejs4029's Avatar
I have a 2.5 Husky shank #32554 it has almost 6" of drop going by the Husky website. I use it with a Husky Centerline Hitch but X2 believe it will work with other brands.....Not very $$$ Rvupgrades.com has for like $61 bucks.
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30C
Ejs4029 is offline   Reply With Quote
Old 08-23-2019, 02:42 PM   #15
I bought a $10 Reese adaptor and welded it to the drawbar. You can swap out the rear blocks in the F250 for '16 and earlier blocks. This will lower the tail end about 1-1/2". The blocks are Ford PN 6C3Z-5598-A. About $35 each from Tasca.
woo10-210 is offline   Reply With Quote
Old 08-24-2019, 03:39 PM   #16
I am surprised that your truck didn't come with the 2" adaptor. I bought a 2500HD GMC Denali last year and I found the adaptor under the rear seat. Assuming that you bought the truck new, you might want to contact the dealer who sold the unit to you and ask them why you didn't get the 2" adaptor.
kluza2786 is offline   Reply With Quote
Old 08-25-2019, 06:42 AM   #17
nomad297's Avatar
I don’t know if this is true, or not. With my Chevrolets, this is true, but my friend’s 2016 F-250 came new with a sleeve that has no flange and it is a pretty sloppy fit. He has always griped about how it sucks that he has to fiddle with it so much to get the holes for the pin to align, and he claims that it causes excessive noise because of its sloppiness. Maybe Ford has changed this since then. The the pin holes in the sleeves for my Chevrolets line-up perfectly when the sleeve is bottomed-out to the flange, and there is very little slop in the fit.
I have read here and on other forums that using the sleeve reduces the weight capacity of the receiver and it also makes a weight distribution/anti-sway system less effective. Some of these claims were supported by links to sites with the technical information regarding this. I’m not sure if it’s something that really matters because I’ve never read anything about somebody actually having a problem towing due to the use of a reducer.
EDIT: Here’s what the eTrailer expert has to say about it: https://www.etrailer.com/question-185917.html
Bruce
Old 08-25-2019, 12:47 PM   #18
Which is why I welded mine. I also use a hitch clamp and I get no noise, no play with 1K lbs. tw.
Old 09-01-2019, 11:33 AM   #19
Bwood BBQ's Avatar
Have you figured your drop out mawilson? I am taking delivery for my 2019 F 250 on Thursday hopefully. I'm upgrading from a 2016 F 150. I was just wondering what you settled on and how everything is working.
Bwood BBQ is offline   Reply With Quote
Old 09-01-2019, 11:42 AM   #20
Shouldn't the clamp be forcing it down instead of up?
babock is offline   Reply With Quote
equalizer
