Originally Posted by mopwr4me2003
What model TT do you have? If the fresh water tank is front of the axles and you fill it that could be where the extra weight is coming from. Not sure what size water tank you have but I’ll go off mine which is a 40 gal tank. 8.3 lbs x 40 = 332 lbs of possible extra tongue weight. I would weigh things as you have it now then empty the fresh water tank and see where your numbers fall. Seeing as how you have done everything else with your hitch this is where I would start just to see your numbers.
2012 8315BSS. Fresh water tank is behind the axles. From my scale slips it appears as though my current Trailer weight is 7660 without the water in the tank. My current tongue weight is 1260. Even if I move the battery and propane to the rear, I"m not getting down to 10% or 766. Even pushing the envelope to 15%, I'd be at 1149.
Length
34.25 ft. (411 in.)
Width
8 ft. (96 in.)
Height
10 ft. (120 in.)
Interior Height
6.5 ft. (78 in.)
Weight
Dry Weight
6,976 lbs.
Payload Capacity
1,474 lbs.
GVWR
8,450 lbs.
Hitch Weight
841 lbs.
Holding Tanks
Number Of Fresh Water Holding Tanks
1
Total Fresh Water Tank Capacity
43.0 gal.
Total Gray Water Tank Capacity
76.0 gal.
Number Of Black Water Holding Tanks
1
Total Black Water Tank Capacity
38.0 gal.
