11-09-2019, 06:29 PM
new hitch concern
my trailer level is 17 in. to top inside of coupler and my receiver is 20in. from ground to top of inside of hole. equalizer says I need a 9 in. drop shank which is about 13in long. when I put it in the receiver I will have about 5-6 in. of ground clearance from the bottom of the shank. is this going to be a problem or will I be okay to drive. CONFUSED, CONCERNED. THANKS IN ADVANCE.
Ken
See you down the road. ;
Ken and Denise new SOB Imagine2019 2850mk 2017 Ram 2500 ctd.
previous 2015 shamrock23s,2015 Ram Eco diesel
previous 1997 coleman highlander pup,1994 35rb Vectra,diesel,2007 Fleetwood arcadia pup.2005 ram
11-10-2019, 08:35 AM
with the trailer level If the top of the coupler is seventeen inches then the top of the hitch ball when inserted in the receiver of your hitch should be at close to 19 inches. You can figure the drop you will need from that.
Retired Navy
2016 Flagstaff 26 FKWS
11-10-2019, 09:00 AM
Seadog is about right. With those measurements you only need about an inch or so of drop. You want the ball to be slightly higher than the coupler on the TT, so when the TT is placed on the ball and you let the weight onto your hitch the truck is going to drop a little and the ball being higher will compensate for some of that drop.
At least this is how i've always set mine up and it works for me.
11-10-2019, 07:48 PM
all true. but the ball is 3inches and sits on top of the equalizer head which is about 6 inches. if I did not have the wd hitch I would be good to go, however my concern is the ground clearance to the bottom of shank. I don't have pictures because I'm not sure I want the recommended shank. I know it is not a good explanation of what's going on, I just don't know how else to explain it.
11-10-2019, 07:49 PM
With the 7 inch drop the ball sits at 22 inches. and the squat is horrendous.
11-10-2019, 08:16 PM
What WDH are you using and how much is the vehicle squatting when you drop the tongue on it ?
11-10-2019, 08:17 PM
You must have very soft suspension on the tv for that kind of squat the tongue weight of your rig is around 800 or so. some of that squat will be taken care by the WDH bars I would go with 1K bars. Also with the very long shank you get the head of the wdh set and then cut the excess off the bottom of the shank to provide clearance. I did this with my WDH shank.
Retired Navy
11-10-2019, 09:35 PM
using the equalizer 4pt. 1200/12000. the ram does have the coil springs which are a bit soft, thinking of bump stops or air bags. ordered the 90-02-4400 shank and will see how it goes. thanks for the input. wish me luck or winning lottery numbers.
11-10-2019, 10:16 PM
Kenny, I live in Mint Hill, I’ll take pictures of my setup tomorrow and post. I’m just setting up my wdh. Bill
2008 wildwood le 19BH
Tv 2018 F150 screw 3.5EB
Retired UNC Charlotte engineering professor.
11-10-2019, 10:23 PM
thanks Bill. I have to work thru Wednesday and then we are leaving for 10 days. I am having the new shank delivered to our Fl. destination. I am interested in your pics. Thanks
11-10-2019, 10:24 PM
Bill come introduce yourself. I work the refund desk at Costco in Matthews.
11-11-2019, 08:24 PM
Will try to stop by tomorrow. No time for pictures today. Selling my pop up so had to empty it.
11-12-2019, 04:33 PM
got out there today after rain stopped.
Leveled trailer (pic 1), Measured coupler (24 inches (add 3 for body of tape). (pic2-30
Set Ball to 25 ( pic 4-5 21.5 +3 + .5 ( tape not to top of ball) = 25).
now ready to go and hook up the bars,
11-12-2019, 09:41 PM
thanks Bill. probably leaving tomorrow afternoon for Fl. having the new shank delivered there. going to nurse it down with added washers and raised L brackets. I'll post how it went Friday or Sat.
I will be back at work on the 25th. hope to meet you in person at some point.
11-18-2019, 08:56 PM
[QUOTE=Minthillbill;2220314]Will try to stop by tomorrow. No time for pictures today. Selling my pop up so had to empty it.[/QUOTE
Well the hitch worked fine. The new shank is too long(just as I suspected) so I'm sending it back. the truck sits level but I can feel the soft rear suspension. So I guess my choices are increase suspension or bump stocks or airbags.
11-18-2019, 09:17 PM
how much room is there from the bottom of the WDH to the bottom of the shank?
Retired Navy
11-18-2019, 09:25 PM
Mine was long like the one you got so I cut it off about 1/2 inch from the bottom of the WDH which solved the clearance issue give that some thought cheaper then suspension.
Retired Navy
11-18-2019, 09:30 PM
I read that earlier, but the shank still sat just less than 5 inches from the ground, so if I cut 2inches off the clearance still gave me concern.
