03-05-2013, 10:36 AM
#41
a dually and a pop up...lmao!!!!
03-05-2013, 10:45 AM
#42
daydreaming about camping
Hornswoggle, our experience may mirror each other in reverse. We started out looking at 28 ft bunkhouse models and ended up in a 32 model. Let me share some things we looked at and maybe it will help.
By the way - I think you are doing the right thing by looking at smaller trailers. Otherwise you would have been looking into a tow vehicle upgrade very quickly.
We started out on the Grey Wolf line looking at this:
Grey Wolf Travel Trailer by Forest River
We still feel it was hte most bang for the buck of any trailer we looked at. At 16.5 out the door with all power options (touchscreen remote control for slide operation and stab jacks it was very nice. But too small and I just did not like the aluminum sided trailers.
with that said - this floorplan is killer and with a GVRW of around 7500 lbs is exactly in your ball park:
We then looked at Keystone, mostly the Bullet line and also Kodiak by Dutchman. We felt like we liked each but Coachmen offered more for the money with at least the same build quality. We were sold on the 310 (until the 320 came out):
Freedom Express - Coachmen RV
Note that on the 310 you are going to always be at your GVWR even packed lightly. It is probably too much, but with extreme caution, I think you could do it. It is about 1500 lbs less. It is however very long and to be safe you would be better in the 292BHDS which is really an awesome trailer is you have not been in one yet.
Then we went to the KC RV show and saw the Solaire. We already had our 320BHDS, but when my wife and I saw this one, we both commented that had we seen it first, we would have bought it.
Palomino RV - Manufacturer of Quaility RVs since 1968
The GVRW is right in your wheelhouse. You could pull this trailer comfortably and it has room for 3 kids. The fit and finish on the one we looked at was great.
I know this is the one you want, because it caught my eye too:
That 307 is an awesome looking floorplan. I think the weight is going to be a challenge, and truly it comes down to how safe and responsible you are. The truth is you are going to be over the hitch weight and CC of your Armada. I don't think you will be much over, but you WILL be over. That is a risk some people are willing to take, and while I would never recommend anyone purposely buy more camper than they can handle life experience shows some people can do it. When I was a kid we toed trailers all over the US with station wagons. People would say today we were crazy, but everyone did it. I can't tell you how many people I saw pulling 7500 lb airstream with Lincoln Town cars and Cadilac DeVille's.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
03-05-2013, 10:48 AM
#43
Sometimes it feels that way doesn't it
But seriously. Although I don’t know the details on many of the trailers you are looking at, here’s my general take on where you should be in order to stay within your limits
- Buy a trailer with a GVWR <6,100lbs. This means that the tongue weight (at a reasonable 13% ratio) would be 793lbs.
- This would work for you because, as you stated in post #19, you estimate that you have approximately 878lbs remaining for the TW (Armada GVWR 7,300 less est. GVW 6,422 = 878lbs).
- This would also keep you under the 900lb limit that Toyota places on the TW of a weight distribution hitch.
- Such a trailer is probably listed with a dry weight of 4,500 to 5,000lbs.
That Coachman 292BHDS is nice, but here’s the issue: You will be at max with the Armada. You will be constantly aware of how much you pack and you will be aware of how fast the kids are growing. You will always know when that trailer is behind you and, flat land or not, strong winds and semis will remind you that the trailer is 33’ long. Being from WI, I can also tell you that the winds blowing across a huge farm field and hitting you in the side as you’re traveling down the freeway is a consideration.
Also, the areas that you want to camp (Dells and Door County) are not exactly flat.
You asked for trailer suggestions so I am asking you to step outside of the bunk house floorplan for a moment and consider a hybrid. These trailers give the room you want inside with a fairly light tow and a smaller footprint. The Roo 233S, for example, has three queen bunks, will sleep guests with the table and/or couch as needed, and has a GVWR of ~6,300lbs. Loaded, our trailer weighs less than that, but using the GVWR as a max reference is good because it builds in a cushion.
Its also a 28’ long setup but under 24’ long towing. I am not one to suggest the wheelbase has to be priority, but I really do not think your Armada nor my Sequoia can safely tow a trailer over 30’. The physics just do not add up. Tail wagging the dog.
Anyway, consider a Hybrid for the Armada.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
03-06-2013, 05:41 PM
#44
Welllll
I spoke with our dealer and told him about my concerns regarding my GCWR and explained to him that I was not comfortable exceeding that. I asked him to cancel our order for the Coachmen 320BHDS.
We are investigating the Keystone Premier 31BHPR. It is not a hybrid or expandable and at 31 feet it is a bit long for my wheelbase, but it fits our family needs pretty well.
90% of our trips will be within five hours of Chicago, so we will not be getting a lot of mountains.
This unit would give me about a 20% buffer on my tow capacity and about a 15% buffer on my GCWR.
Those are numbers that I'm comfortable with
03-06-2013, 07:19 PM
#45
Camper Less Camping
Welllll
Beautiful TT (Keystone)...but 36'L and "dry weight" of 6440lb & 795lb tongue?
Like all of us, once your mind is made up on a floorplan that works for you, nothing much can't change your mind...with that said, consider trading up your current tow vehicle...Good Luck!
2013 Sabre 32RCTS-6 (sold)
03-06-2013, 07:23 PM
#46
We will eventually upg the TV, but in the meantime a "happy wife is a happy wife".
03-06-2013, 07:34 PM
#47
Ain't that the truth
Have a good one and I hope you stick around our forum. You're more than welcome!!
Scott
2012 Shamrock 233S
03-06-2013, 07:46 PM
#48
I appreciate that and hope to stick around. The Keystone forum has a lot less people on it and you guys have been very helpful.
03-06-2013, 08:05 PM
#49
Saw that typo...meant to say a happy wife is a happy life. Works either way I guess
03-06-2013, 08:33 PM
#50
I'm not sure where you got the 31' length from as it's listed at 35' 4" on the Keystone site. The dry tongue weight is 795 lb so you'll still be over you're payload capacity. Your determined to tow a camper this big and heavy...I hope you getting the best hitch there is for sway control like Pro Pride, Hennessey as I think you'll really need it towing with that short of wheelbase.
Dave
03-06-2013, 09:18 PM
#51
We have a 2010 Armada and pull a 2013 FR Wildwood 26TBSS which had a sticker weight of about 5900lbs. Length of about 28 feet. It seems like the max I could tow comfortably. If you are buying a trailer any longer, I would buy a ProPride hitch at the same time. Something to help you control away and swing with the short wheelbase of the Armada (short compared to a full size truck).
With that said, we pulled from Kansas City to Leadville, Colorado and back last summer. Didn't really notice to much pull or sway crossing the windy Midwest. I'm a slow puller though. Never breaking 65 to help with mileage and to reduce the white knuckle effect of cruising with 40+ feet of vehicle with little to no experience.
The 26TBSS has a triple bunk, a big slide out and fits us (two young boys, a black lab, the DW and myself) just fine. But to be honest, I'd love something bigger! But that is just because it would have more of the "home comforts".
03-07-2013, 09:38 AM
#52
Welllll
I will be interested to hear how you like the Premier. We looked at it as well, though the only local dealer who would get one was about 7K higher than the Coachmen we bought, so we crossed it off the list fairly quickly. I did like the full color paint options you can get.
As has been stated, that is really not much smaller. Overall length is pretty close and I would be surprised if you under 8500 lbs loaded.
03-07-2013, 10:36 AM
#53
I agree with everything that you guys are saying. The dry weight of the camper is 6400 pounds and if I had 1000 pounds in gear, propane, batteries, etc. I should be about 7400 pounds, which is 18% below my max tow capacity.
I agree that the length is a bit of an issue and intend to buy the pro pride hitch as a way to offset that.
I have not bought it yet And if I cannot get the same kind of discount, we will look for other options. I was able to negotiate a 38% discount off of list price on the Coachmen ($39,500 list / $24,600 buy) and hope to do the same for the Keystone. If not, we will start the process over :-)
The net net is I am willing to take a little bit of a risk with the longer camper so that we can get the space that my wife really really wants.
03-07-2013, 12:00 PM
#54
FWIW, that camper has only one 30 gal gray tank. If you're camping at nothing but full hookups, it's not an issue. Without hookups, you'd be filling that fast with a family of five...black tank also.
Dave
03-07-2013, 12:27 PM
#55
I tow the 292BHDS (non Liberty) with my F150. It has 1500 payload and 8800lbs towing capacity.
My tongue weight is about 950lbs and GVW of TT is 7300lbs, this is loaded for camping with me, wifey, 2 kids ( 9yo) & a German Shepard, and no food as I weighed on the way home from a weekend trip.
The key is proper weight distribution set up and a GOOD anti sway system. I use the Husky Centerline which does a great job with sway, but the setup plays a bigger factor.
Another thing you may want to do is replace the shocks, as the factory shocks on crew cabs tend to favour a more comfort based ride instead of load dampening ride.
I swapped with Bilstein 5100's and the slight porpoising I was experiencing went away over bumps and expansion joints etc.
Once you get the WD dialed in, you should have no problems pulling a 292BHDS.
2012 Coachmen Freedom Express 292BHDS
2009 Ford F250 Super Duty CC 6.8L 4.10
Husky Centreline WDH w/Sway Control
2013 Nights Booked: 38
2013 Nights Camped: 40
03-07-2013, 01:23 PM
#56
My conscious isn't letting my ignore this.
First of all, I commend you for coming onto the forum and asking the questions of 'am I safe to tow this with that'. However it seems that you have some 'tunnel-vision' when it comes to the feedback that you're receiving. We're at 6 pages of posts without anyone endorsing what you want to do. The alternatives you ask for feedback on are little if any improvement.
You haven't indicated, but I assume that you're a newbie RVer that's going to make the classic mistaken of too much camper for the tow vehicle...too much tongue/total weight, too long. Perhaps you've had some towing experience, but towing a high profile camper isn't anything like a boat or flat-bed trailer.
When you say risk that you'll accept, I hope that you understand what that risk is. I don't want to be an alarmist, but this reminds me of a tragedy back in 2008 of a local family towing to Myrtle Beach with Dodge Durango and a 34' camper on I77 in Virginia. Reports say that the camper started swaying causing loss of control and they crossed the median into a oncoming tractor-trailer. Two daughters in the family of five survived. The driver made his living driving, so lots of experience.
Is the combo you talking about an accident waiting to happen? Perhaps not, but understand that the risk is much higher than with a longer wheelbase TV or shorter camper.
I'm getting off the soapbox now...
Dave
03-07-2013, 01:29 PM
#57
I'm with Dave on this.
Kristina
2016 Rockwood Premier 2317G
2021 F150 XLT
Previously:
2005 Fleetwood Seapine, 2012 Rockwood Roo
2015 Sunseeker, 2017 Fleetwood Pace Arrow
03-07-2013, 01:47 PM
#58
+1
I know the land in the midwest is flat and your TV has the horses to pull the camper just fine. Your TV is a beast, with a short wheel base. The midwest is also very very windy. You have to take the safety of your family and family friends you will have with you when towing your TT. You will have some serious tail wag with that long of a camper and a short wheel base. My guess is you will not enjoy the expreience at all. Maybe the dealer will allow you to test the TT and tow it on the highway?
TV:2006 Chevy 2500HD 8.1 Vortec - Allison Tran
TT: 2014 Wildwood Heritage Glen 300BH
03-07-2013, 04:01 PM
#59
Thank heavens you learned the REAL facts before moving ahead with this purchase. My previous TV was an 08 F-150 XLT and our family was going to purchase a 32BHDS. We fell in love with the floorplan etc. However, once I ran the numbers I quickly realized there was NO WAY I'd safely be able to haul it with my truck. In the end we decided to go with a Catalina 28BHS, which has served us well.
However, even a 28BHS Catalina will be too much for your Armada.
Suffice to say, run the numbers BEFORE you buy. It doesn't matter if your trips are 'only closeby', or 'in flat areas'. Should you ever get involved in an accident and you are over ratings, it's going to be a nightmare.
Don't despair though, there are lots of BH models out there and you will find the model appropriate for your TV if you search.
Good on you for coming to a place like this and getting the real deal. Some of these dealers should be ashamed of themselves.
03-08-2013, 09:15 AM
#60
I do appreciate all the feedback and yes, this will be my first camper. We have not bought anything yet, although there are some floor plans we love, which makes it emotionally difficult to scale back.
The part that makes me feel good is the fact that we cancelled to 320BHDS order because of all the feedback on the thread. Now we just need to look at more models and try to find a bunkhouse floor plan that fits our needs and is safe to tow.
I do have a little tunnel vision and I appreciate the honest feedback.
Sincerely,
Rick
