Old 12-31-2018, 09:20 AM   #1
New tow vehicle, WDH needed?
Thanks in advance everyone.
Wife and I bought a Wolf Pup 16BH last August, and quickly installed a Harbor Freight WDH setup onto our 2019 Edge with tow package.
The trailer really was a bit too much for our lovely little Edge, so this December we also got a 2019 Colorado Z71.
Trailer has a 3900 GVWR, and I feel much better about towing that with the Colorado’s 7,000lb tow rating than our Edge’s 3,500lb rating.
http://www.forestriverinc.com/product-details.aspx?LineID=177&ShowParent=1&ModelID=1330# Main for reference.
My question is, should we be using the WDH on the Colorado, or is it really not necessary?
Thanks again.
AE0MT is offline   Reply With Quote
Old 12-31-2018, 09:23 AM   #2
Insert witty title here
Weight distribution hitches with sway control are always a good idea.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 12-31-2018, 09:32 AM   #3
This one doesn’t have any added sway control measures.
Old 12-31-2018, 09:35 AM   #4
Cherokee Wolf Pup 16BHS - Wolf Pup Travel Trailers Travel Trailers / Toy Haulers by Forest River RV for reference.
Thanks again.
You can get by with out but recommend you have one . do your self a favor and get the andersen
MR.M is offline   Reply With Quote
Old 12-31-2018, 10:11 AM   #5
007matman's Avatar
You should use a WDH.
There are many good ones on the market. Fastway E2 is another good one. I really like the trunnion style setups but Andersen is a good one too. You'll find lots of opinions on this and some folks can get really passionate about which is best.
I used a WDH to pull a pop-up with my Escalade. We bought a larger camper (33' Rockwood TT) and continued to use it with the Escalade. When I bought my F-350 Dually I moved it to use it there. Wouldn't tow without it.
007matman is offline   Reply With Quote
Old 12-31-2018, 10:17 AM   #6
Thanks for the replies guys, but I thought I should clarify that I wasn’t looking to buy another WDH setup, I was looking to see if there was reason to use the one I already have.
This is what I have , for reference.
https://www.harborfreight.com/10000-...tem-67649.html
Old 12-31-2018, 10:26 AM   #7
That looks like the same hitch I use except mine is made by Husky. You can add sway control with this:
https://www.harborfreight.com/traile...kit-96462.html
Old 12-31-2018, 10:36 AM   #8
A WDH is always a good idea but I think that hitch is too much for your trailer. The hitch spring bars are rated for a 1,000 pound tongue weight which is far above the ~400 pound tongue weight of your trailer. That lightweight trailer comes with a much lighter (thinner) frame which could be bent by the 1,000 pound capacity bars.
2019 Rockwood 2902WS
2019 Ford F250 4X4 CCSB 6.2/4.30
Equalizer E2 with single old-school friction sway control.
woo10-210 is offline   Reply With Quote
Old 12-31-2018, 10:38 AM   #9
Try driving it and see how it feels. Only you can decide for sure.
Looking at the specs, you will have ~400lbs tongue weight on your Colorado, and I think that is roughly ⅓ of your overall payload. See how the truck sits and feels when you drive it.
I had a similar setup with a Tacoma and my Nobo which has similar weight. I used a WDH.
2018 FR NoBO 19.5
2018 F150 XLT, 5.0l ,3.55's
blackfly is offline   Reply With Quote
Old 12-31-2018, 01:39 PM   #10
No, you do not need a WDH. You would only use half the capacity of your current WDH.
That said, a lighter capacity, like a 400-600# unit or slightly more, with built in sway control, would make for a more pleasant and safer tow. You should try towing without the WDH to some local CGs for test purposes. Check for porpoising. Anti-sway can be added by itself using an add on platform under the main tow ball to hold the anti-sway mini-balls. Then just add a friction anti sway like the $30 one from Harbor Freight.
I have the same trailer towed with 2008 Explorer, tow capacity 5225#. My dealer had a used Husky 6-800# WDH with built in anti sway that I bought. I was going to tow the TT home without a WDH to check it out but I got a good deal on this one and they set me up right. Great towing experience. I had previous experience with porpoising on a loaded 3K# box cargo trailer without WDH, same TV. Glad I got the WDH.
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 200W CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, 3.55, SumoSprings, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
Boomerweps is online now   Reply With Quote
Old 12-31-2018, 03:34 PM   #11
I use thr same one for 7K trailer, works well for me.
pdqparalegal1 is offline   Reply With Quote
Old 12-31-2018, 03:39 PM   #12
Denver To Yuma In 90 Days
I would...
It is an excellent safety factor to have!
JohnD10 is offline   Reply With Quote
Old 12-31-2018, 04:00 PM   #13
BigH's Avatar
... I was looking to see if there was reason to use the one I already have.
You need to check the manual for your truck...It will tell you when a WDH is required.
24 Ram 3500 CC/SRW/LB/50 gal tank/CTD
2024 XLR 31A LE
BigH is offline   Reply With Quote
Old 12-31-2018, 04:39 PM   #14
llr
Even if not required it is still a good idea. With my truck and trailer it is not required but i wouldn't do more then local back roads without a WDH with integrated way control, I use the Blue ox sway pro
2024 Artic Fox 3018 5th Wheel
Grand Design 2800BH TT 2021 - for sale
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW - on order
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload
llr is offline   Reply With Quote
Old 12-31-2018, 05:24 PM   #15
BigH's Avatar
WDH is a tool...a fix for vehicles with short wheelbases or vehicles that have handling issues when enough weight is removed from the front axle. Sway control is another tool...it improves handling for trailers on the low end of the tongue weight to trailer weight percentage.
Its not required on my truck either and I don't use one...it tows like a dream across the windy plains with crosswinds or though the mountains at 75mph+.
I'm sorry your truck and trailer is uncomfortable on anything more than back roads. Every trailer is different but maybe you need to move some weight around...
2024 XLR 31A LE
Old 12-31-2018, 05:35 PM   #16
llr
I never said it's uncomfortable but I do strongly believe that it adds a safety margin when things go wrong, hopefully it is never needed
Old 01-01-2019, 12:35 AM   #17
I agree that WDH is darned good idea. Not required but I use one when towing our R-pod 179 with our 2017 Tacoma. I added a stabilizer to help with the single axle TT. The whole package makes for comfortable travel on mountainous back roads and freeways.
BTW, jealous of your new TV. Nice rig!
Dirt Sifter is offline   Reply With Quote
Old 01-01-2019, 01:36 AM   #18
rsdata's Avatar
If you feel that the trailer porposes when hitting road joints, or your headlights go up in the air when hitting bumps then you NEED the WDH... even if that does not happen then I would use one anyway. I purposely load my travel trailer tongue heavy at 15-16% of total weight which virtually eliminates any sway for any reason. Because of this I use the WDH to help eliminate porpoising on un-even concrete slab interstate roads.
Even though the HFreight has 1000# bars, you do not have to crank them up to the last link in the chain to get a good ride as someone suggested would be a problem.
2014 Shamrock 183
Old 01-01-2019, 04:05 AM   #19
The job of a WDH is not to stop porpoising it is to make towing safer. The tongue weight of a tow behind is all on the hitch ball at least 3 feet BEHIND the rear axle. This weighs down the rear and actually makes the front wheels lighter with less weight on them. Then when you hit the brakes hard or move the steering quickly to avoid something the front wheels can lose grip and you can jacknife the rig. The WDH job is to transfer the LOAD fron the hitch ball forward into the bed and a bit FORWARD of the rear axle. This will plant the front wheels more firmly and make it safer. BEWARE ...too much WDH moves too much weight forward and the rear wheels can unload and also lose grip. With that WDH you have as someone said don't crank it down too much OR you can use just one of the arms tight and one almost loose. With that smaller trailer i doubt youll need the friction stabilizers/s. If the rear seems very bouncy get some good bilstein 5100's on there and they will damp out the ride much better then the cheapo stock ones.
stealth2715 is offline   Reply With Quote
Old 01-01-2019, 08:16 AM   #20
Thanks! First time owning a truck, and I’m grinning from ear to ear!
tow vehicle
