07-22-2018, 03:31 PM
Newbie Question
Hi all,
I'm new to trailer camping, still in the research stage. I'm leaning strongly towards a GeoPro 19 FD. Has anyone had experience pulling this trailer with a late-model ~2014 Nissan Frontier (V-6, 4 WD version). The numbers seem to work but I would appreciate anyone's experience with this truck/trailer combo before I jump in to it.
Thanks!
07-22-2018, 03:55 PM
Originally Posted by Davens
Hi all,
Thanks!
Our first trailer came in at a total combined weight of 2900 lbs. we pulled it with a 2014 Frontier with a 4 cyl automatic. You will be fine. But . . . You will enjoy it so much that you’ll want to move up. So in a couple years plan on a new truck and trailer.
2018 Rockwood Premier 2516G
2014 Nissan Titan
“Always do what’s right; this will gratify some and astonish the rest” – Albert Einstein
07-22-2018, 03:59 PM
Scoundrel
Hi Davens,
Welcome to the forums! I have a Micro-Lite 19fd which is very very similar to the Geo-Pro 19fd that you're looking at. I pulled it for one year with a 2007 Nissan Frontier Crew Cab, V6 4x4 with a revamped and lifted suspension. In the end, I found the TT to be too much for the Frontier (although Frontier payloads are somewhat better than most would expect).
For one, the advertised hitch weight of the camper is an enticing 398lbs. Measured, its over 500lbs (with two batteries, propane, etc). If you check the yellow payload sticker on your drivers side door jamb ("Cargo and occupants should not exceed.....lbs) you'll find your limitation right there. The weight of you, your passengers, dogs, kids, camping gear and tongue weight of the trailer all added up should not exceed that number or you'll be over taxing the rear axle (weight) and the entire drivetrain of the truck. Don't forget to add in another 100lbs for a weight distributed hitch. Does your truck have a topper? That adds another 150lbs...
I think you see where this is going... I did it for a year and it was a mistake. I ended up selling the Frontier and purchasing a different truck just because of the payload numbers.
If you'd like, post up your payload number from the yellow sticker on the door jamb and we can be more precise and perhaps more helpful.
Rich J.
2024 Geo Pro 15TB, 400W Solar, 2 Golf Cart batteries
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
07-22-2018, 04:03 PM
I don't know the towing capacity of your tow vehicle but I tow my E-Pro 19FBS with my 2017 Toyota Highlander (with tow package). I've driven over 500 miles on two trips with no problems at all.
2018 Forest River Flagstaff E-PRO 19FBS
2107 Toyota Highlander
07-23-2018, 09:55 PM
Thank you all for sharing your experience and input. I can see I'm right at the Frontier's load limit, and I need to think carefully about this. I don't have a TV yet, so I'm getting the truck specs online. Is it OK to be right at the load limit if i'm under the max tow capacity or should I keep the load on the vehicle down around 80% like the tow weight?
07-23-2018, 11:40 PM
Worry about payload capacity first, then towing capacity.
You'll always run out of payload capacity before towing capacity.
07-24-2018, 10:01 AM
Scoundrel
Towing Capacity = how much you can pull. There is no weight on the bicyclist.
Payload Capacity = how much weight the bicyclist can support.
The bicyclist can pull much more than he can support. The more weight you put on your tow vehicle the more wear and tear you place on the rear axle and transmission.
BTW, my F150 with a V8 gets better gas milage than my V6 Frontier, both towing and not towing...
