Old 03-15-2020, 07:05 PM   #1
No drill CB antenna mount on aluminum F150
I have an old CB that I finally fixed the power plug on. I have a magnetic mount antenna.
How did you mount your CB antenna?
I found an expensive steel bracket that mounts behind the high center brake light, bent steel plates that come up between the hood and fender, and bolted in the forward stake hole (which would require cutting up the bed lip cover AND my tonneau cover ;(
2019 Cherokee Wolf Pup 16BHS flipped axle
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, 3.55, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
Boomerweps is offline   Reply With Quote
Old 03-15-2020, 09:29 PM   #2
Grammar Pedant
67L48's Avatar
Go with a hood mount. Work good and look great.
EDIT: linked to Super Duty products. Sorry. Same site has 2019 F-150 specific mounts, too.
Former RV: 2018 Rockwood Mini Lite 2504S
67L48 is offline   Reply With Quote
Old 03-20-2020, 08:31 PM   #3
Failure is my business
2Evil4U's Avatar
I use bed stake hole mounts on my 97 F150 and 14 Ram 1500 and a right channel radios hood mount on my 17 Ram 3500. All are good.
Current vehicle list: 17 RAM 3500 4x4 Cummins Aisin 4.10, 16 Flagstaff 832IKBS, 14 RAM 1500 4x4 Hemi 3.92 Bilstein 5100's Derale oil cooler, 97 F150 4x4 5.4L 278,000 miles, 80 Firebird Esprit Aussie Burnout Car https://youtu.be/v06VjII7HmE, 78 Harley Davidson FX 79,000 miles dad bought new, 71 El Camino ZZ3 TH400 12-Bolt, 37 Ford 3 window 502 Chevy dad built
Days Camped: 2016: 43, 2017: 83, 2018: 44, 2019: 78
2Evil4U is offline   Reply With Quote
Old 03-25-2020, 11:41 AM   #4
I got the Firestik extended truck bed stake hole antenna mount. It will allow my tonneau cover to work as is. Will use with a 4' red (to match my truck Firestik antenna, spring and quick disconnect (for the car wash).
Will put it on the passenger side but have to decide on forward or rear stake hole. Too much time on our hands right now so plenty of consideration time
Forward: have to cut hole in plastic rail cover (Thanks, Ford), looks better IMO, possible cab transmission reflections.
Rear: existing hole cap, possibly in the way loading the bed, sticks up like a sore thumb, longer wire routing.
Any experiences using these antenna positions?
Awaiting SWR meter delivery for actual testing.
Old 03-26-2020, 04:21 PM   #5
Installed the antenna in the rear left stake hole. Had to run a ground wire for the antenna base. Testing with SWR shows a strong FWD signal but I can't get anything to show on REF ;( Ground continuity from cable barrel to power point ground in cab good.
Old 03-28-2020, 10:47 AM   #6
2Evil4U's Avatar
I'm a little late but, My stake hole mounts are both forward and driver's side with the exact antenna setup you mention. Very good reception and transmission. What I can say is the kits come with stainless fasteners. They all galled immediately during installation and I had to drill them out. Use lots of antisieze.
Second, on both my 97 and 14, the bed sides are sloped so much I had to install about a 1/4" shim on the outside to get the antenna close to vertical.
Old 03-29-2020, 11:31 AM   #7
Thanks for the info. Will loosen and antisieze the screws. The antenna seems pretty vertical to me on my 2019. I'd do the antisieze now but have to search for it the basement with about two inches of water standing on the low side after last nights storm ;( Portable sump pump running, need to install a permanent automatic one. Leakage wasn't a huge problem until PENNDOT widened the road and got rid of my basement drain line.
Old 03-29-2020, 02:22 PM   #8
Too late to edit.
Water in basement almost gone. Didn't want to forget, got the antiseize and cordless drill, removed and coated the screws. Had a prob on the last one ;(
Old 04-02-2020, 09:10 AM   #9
After adding on a spring and quick disconnect, the SWR meter shows normal readings. REF is 1.4 on channel 40 and 0.8 on channel 1. Yes, FWD and calibrated for each channel tested.
I'm asking everywhere but had no response. Is the preferred position for the quick disconnect above or below the spring on the antenna mount? Using that 4' Firestik. Mechanical considerations?
Old 04-03-2020, 02:41 PM   #10
2Evil4U's Avatar
My qd is mounted above the spring. No issues for probably 5 years now.
aluminum, antenna, f150, mount
