06-02-2017, 01:51 PM
#41
My fifth wheel has a battery disconnect. Does that also turn off the emergency braking system or is that wired in prior to the switch? I hope that is the case. I usually have the battery switch turned on when towing but you never know.
2015 Ram 3500 CC SRW SB 6.7 Cummins
2015 Sabre 36QBOK-7
Nights Camped, 2015: 23, 2016: 27, 2017: 29, 2018: 22, 2019: 29
06-02-2017, 01:53 PM
#42
it is supposed to be before the disconnect, however it is not a bad idea to verify that.
TT 2017 Flagstaff 831CLBSS Classic Ultra lite
TV 2017 F150 6.5' bed 3.5 Eco-boost
prior TV 2014 Silverado 2500 HD
06-02-2017, 04:03 PM
#43
Originally Posted by seagrace
My receiver is bolted to the frame of the truck, why wouldn't I clip the breakaway cable to that? That's where the chains hook up too.
I have seen receivers come loose either wrong bolts or rust.................  all of your safety devices would be in one place not a get idea................
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
06-02-2017, 04:40 PM
#44
Originally Posted by 5picker
Ironic, they show the cable connected to the receiver. Which brings a question....
How many have ever seen a factory hitch on a new vehicle ever fall off or actually pulled off? I'm sure there are times when someone will try and hook an extremely heavy trailer to a small SUV causing undue stress to the hitch, but actually pull it off? Curious. (Not talking about the twenty year old rust bucket.)
Cause I know of no one who does not connect the breakaway cable to the receiver.
And for those who say not to do this, have you ever checked the length of the breakaway to make sure it is sized correctly to apply the brakes when need (breakaway) and not apply when turning a corner?
06-02-2017, 04:58 PM
#45
I can say I personally had one crack and almost fall off my used vehicle. I was pulling a tire trailer over to Shreveport with the same truck I pull my travel trailer with. As I was going down this bumpy road, I hear my tongue jack scrape the pavement.
I immediately stopped and got out to look. The receiver had cracked on both sides and was bent down about halfway between it's normal position and the road. I was able to limp it enough over to a lot and unhook the trailer.
Then it was off to find a new receiver, which nobody in Shreveport had a class IV/V receiver for my truck. I had to order one back in my hometown, for the next day. I installed it and went back to get my trailer.
I was lucky it just bent down and didn't completely crack off, or I would had lost it all.
I may still have some pics of it.
 2011 Flagstaff 831 RLBSS
I often say to myself, "I can't believe that cloning machine worked."
06-02-2017, 05:41 PM
#46
I had the frame of an F250 rust away enough to make the mounting bolts loose. I traded it. ( Removed the receiver it had serious rust as well. The vehicle and hitch were less than 10 years old.
As far as the break away cable length has not been an issue but I have added to one can't remember which one. I currently have 3 trailers with brakes, 3 without. The ones without I expect could kill as well, but the law doesn't require brakes on a single axle trailer under 3K gross in my state.
1966 Mustang GT
1986 Mustang SVO
06-02-2017, 05:47 PM
#47
length of cable
Hi, I have a 6ft zip plastic coated w/ clip. now, but before I went to hardware store and bought a length of 1/16" ss cable and the squeeze clips made my own using old pin. worked fine.
06-02-2017, 06:09 PM
#48
Why don't 5th wheels have safety chains?
06-02-2017, 06:13 PM
#49
The dealer wove my breakaway cable into the safety chain. It loosened up, dragged on the pavement, and wore almost into. I never liked it connected that way. I bought one of those coiled cables from Amazon (4 ft) and like it much better. I do need to see about a better place to attach it.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
06-02-2017, 06:39 PM
#50
World Wide Wanderer
Receivers have been known to fail (someone had a recall on this a few years back). My Fords have a separate place on the bumper to hook up the break away cable.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
06-02-2017, 06:45 PM
#51
World Wide Wanderer
~snip~
Someone and IIRC it was Chevy had a major recall on hitches a few years back that were failing, I think it had something to do with the welds on the hitches.
Aaron
Aaron & Rhonda
06-02-2017, 07:02 PM
#52
Aaron
My bumper is bolted to the frame too.
06-02-2017, 07:06 PM
#53
World Wide Wanderer
But usually separate from the receiver.
Aaron
Aaron & Rhonda
06-02-2017, 07:08 PM
#54
How about a bumper pull?
06-02-2017, 07:11 PM
#55
World Wide Wanderer
In that case hook the cable to the frame... Rocket science it ain't.
Aaron
Aaron & Rhonda
06-02-2017, 07:14 PM
#56
Pulling your leg!
06-03-2017, 06:57 AM
#57
How on earth does a 29yo have a GRANDCHILD?
2017 Dynamax Isata 4
06-03-2017, 07:10 AM
#58
The article said step-grandchildren. But obviously that is the most pressing question from this accident.
2016 Flagstaff 23LB
06-03-2017, 07:27 AM
#59
I've bought 2 new trailers and both have left the dealers hooked up (by them) to my truck, with the safety chains and breakaway intertwined and hooked to the receiver. I can't even think of another spot where it could attach... gonna have to have a good look!
Carmen and the pack
2015 Coachmen Clipper 17BH
2017 Dodge Durango Citadel 5.7 Hemi
06-03-2017, 08:13 AM
#60
New TT Owner
The 6 month old baby died yesterday and it's organs were donated to save other babies.
