03-05-2022, 12:32 PM
One more hole down or longer shank?
Thoughts please. I believe I'm too high. I think I have one more hole on this shank. I have to go buy a wrench... Don't have one big enough.
Should I go down one hole or buy a new shank with more drop?
Thanks for the ideas.
Ron
Ron & Family
2017 Shamrock 23IKSS (Traded)
No longer active with Forest River Forum.
03-05-2022, 12:44 PM
Personally, I'd take the truck in to a tire shop, without the trailer attached, and see if they could drop you down bolt hole. They would have the sockets, impact and torque wrench to do it properly. I believe those bolts should be, depending on the hitch, better than 200 ft.lbs, and I don't think you'd budge them with a wrench.. Then rebook up the trailer and see where you sit. I'd take your before and after measurements on the fenders too and see how they change.
Camped: 2023 (Days/Nights) - 34/27
2022 (D/N) - 41/33, 2021 (D/N) - 37/29, 2020 (D/N): 58/49, 2019 (D/N):27/20
TT: 2020 26' Hemisphere 26BHHL
TV: 2020 GMC 2500HD 4x4
03-05-2022, 01:23 PM
you need to go through a complet and proper setup process on that hitch.
lowering it 1 hole will make the trailer a bit mor level but from what I can see it will still likely be a little nose hitch.
The suggestion to check your wheel well measurements is correct, if the rear of the truck is above where it was before the trailer was hitched you could reduce the tension on the bars which would also make the trailer a bit more level.
(Previous) Coachmen Mirada Select 37RB
(Previous) Coachmen Freedom Express 246RKS
(Current)2022 Grand Design Reflection150 226RK
2022 F150 Powerboost Hybrid.
03-05-2022, 01:43 PM
Looking at the picture you posted, you will have to buy a new shank in order to drop it down another hole.
cliffy49
2018 Catalina Trail Blazer 26TH
2021 Chevy Silverado Custom 2500HD
03-05-2022, 05:50 PM
As suggested, I started from scratch with the Equalizer instructions. I'm stuck at step 3.
Trailer is parallel to the ground, 21 inches front and rear frame.
Existing ball needs to be 1 inch or less above the trailer coupler.
I can't get there from here. Need a new shank.
I don't have the right tools. I either buy them or ask my dealer to do it.
I like tools... [emoji16]
Ron
Ron & Family
03-05-2022, 09:11 PM
I rented a 500 ft-lb, 3/4" drive torque wrench with socket for $18 to readjust my equalizer when I got my new truck. You might consider doing that. Total outlay for the readjustment: $18 plus the gas needed for two round trips to my local tool rental place.
2015 Wildcat Maxx 28' pushing a 2020 F350 6.7L
03-06-2022, 10:04 AM
Ok... Follow on question.
Measured for new shank. 25" to top of receiver, 20 Inches to top of coupler. I'd like a 2.5" receiver size shank.
Equal-i-zer website recommends 90-02-4325 with a 6 inch drop. I'm guessing I will be using most all of those 6 inches.
Is there any harm in getting the next size larger with a 9" drop? 90-02-4900
Cost difference is less than $5
Thanks!
Ron
Ron & Family
03-06-2022, 11:08 AM
Most of the time the 6 inch of drop would be from the top of the receiver to the ball mount. Then you put the ball on top of that so the 6 inch drop actually becomes more like 3 inches to the top of the ball. Top of ball to top of coupler is the measurement you want to use when setting the ball height so the 9 inch would be the minimum I would be looking at.
03-06-2022, 03:29 PM
Thanks!
Ron
The biggest issue with too much drop in the shank will be the unused portion extending below the "ball mount". Might find yourself digging grooves in the pavement when entering parking lots where you have to cross the jump that keeps water from flowing from gutter into parking lot.
03-06-2022, 04:13 PM
Correct Hitch Setup
There are numerous videos and instructions online which explain how to set a weight equalizing hitch correctly.
If you choose not to do this yourself due to lack of proper tools, then go to an RV dealer and have them do it. Or perhaps many vehicle dealers will do this for a price. Nothing is free these days.
One can do it themselves by using a very level parking lot, a ruler to make measurements, a 6 ft level, some masking tape to note numbers on the vehicle, and required wrenches. Add an hour of your time and some sweat equity and get 'er done.
03-08-2022, 12:35 AM
Camping the Natural State
RV dealerships are the worst choice to set up a WDH correctly ! They mess it up every time !
2021 Rockwood Ultra Lite 2614 BS
03-09-2022, 08:12 PM
The new shank arrived today. I have a new HD TV so I decided to get the 2.5" shank to avoid having to use the sleeve in the receiver.
Damn this thing is heavy.
I think I might buy the wrench, socket and torque wrench and do it myself. Gas alone to get to my dealer and back will be $40. Then there would be the cost for them to do it.
Thanks for your thoughts.
Ron
Ron & Family
03-09-2022, 09:17 PM
Ron
I’d bought them also and keep them the trailer just in case.
2019 Freedom Express 248RBS
2012 F150 Supercrew 4x4
03-09-2022, 09:45 PM
Professional Curmudgeon
Your safety chains are hooked backwards.
2022 Cougar Half Ton 24RDS fifth wheel
2014 Coachmen Catalina 253RKS (sold)
2017 F350 6.7L DRW CC LB 4x4 Lariat
03-09-2022, 11:10 PM
How so? Please explain.
Ron & Family
03-09-2022, 11:12 PM
They should cross.
Rockwood Geo-Pro 15TB on order
2019 Ford Ranger
03-09-2022, 11:15 PM
Originally Posted by W5CRE
They should cross.
It might be hard to see. But they are crossed.
I thought maybe you meant the direction I hooked on top vs the bottom.
Does that matter???
Ron
Ron & Family
03-09-2022, 11:23 PM
Does that matter???
Ron
Yes, it does. They should be hooked with the open side facing to the rear.
03-10-2022, 12:55 AM
I agree that is how we were taught so that the hook can't jump off if you hit a large bump. However, I'm not certain this applies with a safety hook that can't jump off once hooked.
2019 Ford Ranger
03-11-2022, 05:26 PM
Solved - New 9" drop shank
The new shank arrived. I followed the Equal-i-zer instructions found the optimal height and setup.
It looks maybe a tad low but that could just be an illusion based on where I'm parked. The level looks pretty good.
I appreciate the thoughts and inputs you all provided.
Thanks.
Ron
Ron & Family
