04-17-2022, 09:08 AM
Overnight Hookup OK?
I would like to have my truck and trailer all set up the day prior so all we have to do is wake up and leave the next morning.
Can I do any harm to my truck leaving the camper hooked up to it for 20 hours or so just sitting in the driveway?
Thanks.
Ron
Ron & Family
2017 Shamrock 23IKSS (Traded)
No longer active with Forest River Forum.
04-17-2022, 09:15 AM
I don't see how. I do it almost every trip we take. And if we are making a multi-day trip and just stopping for one night before moving on, I won't unhook then either. Just back in, maybe or maybe not deploy scissor jacks, hook up electric and/or water (usually but not always), make a sandwich, rest/sleep, get up early and am gone within minutes.
2007 Sierra 2500HD Duramax | ECSB
2012 Rockwood Minilite 2104 - Purchased 08/2012 - Sold 07/2022
2022 SOB 29' 5th wheel - purchased 09/2022; 400w solar on roof; 150w suitcase kit; 206ah LiFePO4; 2k inverter; boondock ready
04-17-2022, 09:17 AM
Do the same here before heading out. Hooked up and loaded the day before and just have electric going to keep fridge running.
04-17-2022, 09:21 AM
Ron, I think your RAM trailer wire connector is 100% full time turned on (at least everyone I owned up to 2018 was). So as your trailer is eating up battery sitting there, its also eating up your truck battery.
also if you have your Trailer plugged in, the AC is charging your trailer batteries PLUS your truck battery. Either way (plugged into AC or not) I would disconnect the trailer wire harness until your ready to leave.
04-17-2022, 09:25 AM
Good Advice. Thanks. We'll leave the AC power connected to the house to keep the fridge cold until we leave.
Ron
Ron & Family
04-17-2022, 09:27 AM
yes you can
EXCEPT .... do not plug in the 7 pin wiring plug
you risk flattening your trucks battery if your trailer has 12v fridge etc
leave it 7 pin unplugged
plug in your shore power if you want to leave fridge on
when ready to go in morning
make sure you plug the 7 pin into your truck
04-17-2022, 11:22 AM
Leave the trailer plugged into shore power until ready to depart, then when ready to depart, unplug the shore power and plug in the trailer to the tow vehicle.
04-17-2022, 11:27 AM
Enjoying Life
I have done this for years and had no trouble. It makes for a quick get away in the mornings.
2022 Rockwood 2109S
Previous: Rockwood 2608WS, 2608BSD
2006 Durango HEMI
04-18-2022, 03:22 AM
Camping the Natural State
Disconnect the 7 pin cord from the truck.
Run the fridge on propane.
2021 Rockwood Ultra Lite 2614 BS
04-18-2022, 05:09 AM
I do the same thing hook up the day before, leave the shore power hooked up as we have a residential fridge, don't hook up truck umbilical cord until ready to go. Another thing I do that probably isn't really doing anything is I leave the front jacks down to take the stress off the trucks suspension and if only stopping overnight I'll put the front jacks down to keep the 5ver from moving around every time someone walks around inside.
2021 Alpine 3790FK
2021 F-350 SD XLT PS 6.7 Dually Longbed 4wd Crew Cab
04-18-2022, 06:36 AM
Georgia Rally Coordinator
X 2 Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
04-18-2022, 07:14 AM
One thing that I might suggest is to leave a checklist on the steering wheel with the remainder of what needs to be accomplished. If you always have the same steps, laminate a 3x5 card and write anything special in grease pencil or dry erase marker.
1. Unplug shore power
2. Plug in 7-pin
3. Raise jacks
4. Make sure DW is in truck
Then maybe a temp note like: Dump tanks on way out.
04-18-2022, 08:33 AM
All good advice. One note of caution, do not hook up the electric to the truck and electric to the trailer at the same time. A friend did that at a campground and it created a feedback to the truck. Burned out electronics to the truck and learned an expensive lesson.
2015 Dynamax REV 24TB class C
04-18-2022, 11:55 AM
Even if you don’t have a written pre-flight checklist, ALWAYS do a walk around. You will end up having a mental checklist anyways, and looking around the trailer exterior before you leave will remind you of each area of concern. ESPECIALLY, when it’s left overnight ALMOST ready to go.
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 400 watts CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, 3.55, SumoSprings, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
04-18-2022, 12:20 PM
To avoid running the tow cars battery down I had a ? not sure what it is called but the trailer can no longer run the tow rigs battery down but the tow rig will still charge the trailers batteries.
05-02-2022, 07:50 AM
you can use a voltage sensing relay between the truck and the trailer
the relay detects that the truck's wiring is 13.7v which means the motor is running
when it detects 13.7 v it allows power to go to the trailer.
turn off the motor the circuit returns to 12v........ and the trailer is disconnected
set and forget.
search the internet for blueseas acr
https://www.google.com/search?q=blueseas+acr
05-02-2022, 11:17 AM
When it comes to leaving the 7-pin plug in or out, not all trucks have live charging wires when engine is not running. I'd check the "Plus terminal" first before worrying about "Plugged In/Not Plugged In".
My TV only has power to this pin when engine is running. I leave the plug in whenever hitched up and stopped. Less chance of taking off with an unplugged cable.
It all depends on the truck.
05-02-2022, 11:29 AM
Ditto Mike.
We often make 2-3 days overnighting in small campgrounds.
We pull in. Wife puts the level system down manually in the rear. I put the front jacks down. She lets out slides as I attach power only.
We can do this in minutes. Cocktail time!
Most modern trucks shut power off to the rv when the engine is off. This was an issue in the 60’s. Every vehicle is different thou.
