Old 08-19-2019, 03:27 PM   #21
Originally Posted by ppine View Post
You can compensate for the larger wheel size by going to a lower aspect ratio tire. You want the diameter to remain unchanged.
If you use a similar tire in a larger size you will increase the diameter and have a noticeable reduction in power.
and a speedometer reading that will read slower than actual
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 08-19-2019, 07:28 PM   #22
No. If you go down in aspect ratio while going up in wheel diameter to end up with a similar overall tire diameter as the previous post described, you do not change final gear ratio. Also you would not change the speedometer reading.
It's simple. To convert metric to old school US floatation tire size you need to know some 4th grade math.
A millimeter is 25.4 inches.
A metric tire is described as follows:
Millimeters wide, aspect ratio and wheel diameter.
This is shown like this...
315/70-17
That tells you that the tire is 315 mm wide.
It is 70% as tall from wheel bead to tread surface. This occurs twice, road surface to wheel and then wheel to top of tire.
Then you have the wheel diameter.
So 315/70-17 is:
31525.4=12.4" wide.
12.4" 0.70 is 8.68" from tread to bead. This is doubled to be 17.36".
The wheel is 17" so it's 17" wheel + 17.36 = 34.36" tall and 12.4" wide.
You can repeat this over and over with different sizes too get a diameter and width that you desire.
2019 Ram Bighorn, CC/SB 2500 4x4 6.4L/8 Speed, Max Tow 14,460 lb/2,940 lb payload.
2019 F-150 King Ranch 3.5 Eco, 12,800 lb/1,546 payload.
2020 Coachmen Apex UL 289TBSS
2019 Quality Trailers 16'x7' 7K GVWR Utility Trailer
2019 IronBull 22'x102" 14K GVWR Equipment Trailer
Larry0071 is offline   Reply With Quote
wheel
