Old 01-13-2013, 01:36 PM   #1
wyo700's Avatar
P2 or P3
Who has which brake controller. Is there a huge difference between the two. There is a $50 dollar difference between the two which wouldn't be a big deal if the P3 is that much better. Thanks for any input.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 01-13-2013, 01:58 PM   #2
asquared's Avatar
The difference is in the display. The p3 has a little better diagnostics as well. Both are good controllers. Check on ebay because we found a p3 on there for around $110 plus additional $15 for nissan wiring harness ( old tow vehicle).
asquared is offline   Reply With Quote
Old 01-13-2013, 02:03 PM   #3
Camper Less Camping
Cajun Po-Boy's Avatar
I really like the P3...if it's only a $50 difference for a device that you'll have for many years...splurge
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 01-13-2013, 02:50 PM   #4
Too old to be too smart
SpringerPop's Avatar
When it's not being used towing my trailer, I keep my P3 running as an alternator voltage monitor.
Very easy set-up, too.
Sorry, but I can't compare it to an older one, as you asked.
Pop
Terry 250RKS, perfect for the two of us and the pups.
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
SpringerPop is offline   Reply With Quote
Old 01-13-2013, 03:15 PM   #5
JDWeir's Avatar
I have had both and I think that the P3 is smoother in brake application than the P2. JMO
TV, 2000 Dodge RAM 2500 Quad cab short bed, Cummins 5.9, Edge Comp, Gauges.
5ver, 2011 Palamino Sabre 31 RETS.
JDWeir is offline   Reply With Quote
Old 01-13-2013, 03:39 PM   #6
Mark and Linda's Avatar
I have the P2, ordered it from Etrailer.com and installed it myself. Hooked up the trailer and set it last year. Haven't had to do anything to it yet.
2009 Palomino Puma 25RS
2007 Chevrolet Silverado
Prodigy P2 Brake Controller
Mark and Linda is offline   Reply With Quote
Old 01-13-2013, 04:14 PM   #7
Iggy's Avatar
P3 is suppose to be $50 better.
I bet it has the same chip and only gives you more info on the screen.
You never told us what you are pulling?
If you have a large trailer or 5th wheel 12,000 lbs or more get the P3
If you are like most with smaller trailers get the P2
If you are rich and don't care... Have someone deliver your trailer to the campsite and fly in by plane and have a limo pick you up and take you to the campsite.
2012 Georgetown XL 378TS (Large box with wheels) 76,100 miles
Iggy is online now   Reply With Quote
Old 01-13-2013, 04:27 PM   #8
wyo700's Avatar
I have a 2013 Toyota tundra crewmax and i am pulling a 2012 sandstorm 203slc weighs around 6500 pounds fully loaded ready to go.
2013 Toyota Tundra
Old 01-13-2013, 04:42 PM   #9
Iggy's Avatar
P2 is all you need. You have a super light tow.
Your truck weighs about 5,625 without fuel, cargo or people.
So I figure it would be 6,000 lbs to 6,500 lbs loaded
Your trailer weighs the same with stuff in it around 7,000 lbs
Your truck max pulling weight is 9,000 lbs
Bottom line you are still good with a P2
Old 01-13-2013, 05:56 PM   #10
Witch Doctor's Avatar
They are all great controllers, only wish I had Iggy's money. You can not not go wrong with either, just more bells and whistles, just like the I phone !!!!!!!
Coachmen M/H
Concord
2018 / 300 DSC
Old 01-13-2013, 07:05 PM   #11
wyo700's Avatar
Thanks guys think I will probably go with the P2. And it's nice they already have a Toyota harness for it for 11 bucks. Can't beat that either.
2013 Toyota Tundra
Old 01-13-2013, 07:11 PM   #12
That same $11 harness also fits the P3.
Pop
Old 01-14-2013, 12:07 AM   #13
P3 still fits in the cubby in the centre dash that the P2 will fit. I had a chance to borrow a P3 for a couple tows. The extra features are nice for sure, and I like if something goes wrong, the screen will flash red to get your attention. (trailer plug wasn't quite locked in and after an hour wiggled loose and triggered the warning)
If you like the extra info, (system voltage, brake current/voltage) the P3 is nice, but it worked just as well as my P1. I do like the button placement better on the P3 tho
'07 Toyota Tundra 5.7L DC 4x2
'16 Surveyor 226RBDS
Nights camped 2016 - 3
Nights camped in 2015 - 20
Ditchooker is offline   Reply With Quote
Old 01-14-2013, 05:37 AM   #14
Gizmo0706's Avatar
We use the P3 in our Sequoia and really like it. We had a cheaper one and the difference is night and day.
Gizmo0706 is offline   Reply With Quote
Old 01-14-2013, 10:40 AM   #15
Experienced Newbie
I'm very happy with my P2. A vast improvement over my old fixed value controller.
2011 Silverado CC/SB
2014 Cougar 31SQB
mhartzel is offline   Reply With Quote
