Old 03-08-2020, 06:07 PM   #1
rollscanardly's Avatar
Peculiar Hitch...
I came across this today. Had to take a pic of it.
Kind of interesting...
Rich
"rolls down one hill, can 'ardly make it up the next..."
1999 21' Wildwood WDF21RK
2006 Dodge Ram 2500, 4x4, Quad cab, 5.9L Cummins, 3.73 gears.
rollscanardly is online now   Reply With Quote
Old 03-08-2020, 09:36 PM   #2
Now a "Top Member"
EdJunior's Avatar
So, what the heck is it supposed to be used for??
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Old 03-09-2020, 03:13 AM   #3
It was hooked up to a camper.
Rich
Old 03-09-2020, 03:51 AM   #4
nomad297's Avatar
It doesn’t look like it could handle much of a pin weight.
Bruce
Old 03-09-2020, 05:12 AM   #5
It appears to be a goose neck hitch. It appears it is connected to a 5th wheel in the picture. I just don't know what the exposed ball is for? Perhaps an adjustable hitch to move it forward or back if necessary? 3 position ball location???
I googled "High Ball Hitches" but came up empty with a company.
Old 03-09-2020, 07:06 AM   #6
Originally Posted by nomad297 View Post
It doesnít look like it could handle much of a pin weight.
Bruce
Just curious...why do you think that? It looked pretty rugged.
Rich
Old 03-09-2020, 05:22 PM   #7
Well...I found out a little more about this hitch. It was made locally...
...in my garage, actually!
I stuck the decals on as a goof. I have since taken them off...
Rich
Old 03-09-2020, 07:56 PM   #8
Now a "Top Member"
EdJunior's Avatar
Aha! Wow, that is quite a hitch. I have no idea about how it is compared to a brand name hitch, but I'm in awe of you being able to even make something like that. Weld on!
Ed and Sharon
2010 Wildcat 28RKBS
Old 03-09-2020, 07:57 PM   #9
Saw one exactly like it in Lazydays Tampa accessory store.
Kgaspari is offline   Reply With Quote
Old 03-10-2020, 03:25 AM   #10
Really?? I "invented" this one out of pure necessity. Not because I wanted to, but because I pretty much had to.
I can't even imagine that there's another one like it out there...
Rich
Old 03-10-2020, 07:56 AM   #11
Rich
So, what is the story? What advantages are there for you? Could others benefit? How long have you used it? Give us some details.
Orlando bull is offline   Reply With Quote
Old 03-10-2020, 08:33 AM   #12
Nice work Rich...
You said you invented this because you 'had' to... why couldn't you use any other kind of conventional 5th wheel hitch?
Days Camped: '17=30 '18=51 '19=58 '20=98
Old 03-10-2020, 04:07 PM   #13
Nice work Rich...
I will start a new thread (under Modifications) about why I did this, and lots of pictures.
It will be titled, "Insane modifications..."
Stay tuned...
Rich
Old 03-10-2020, 05:10 PM   #14
After following your insane Wildwood rebuild I guess I will have to follow the next chapter
2017 River Stone Legacy 38mb
2001 Kenworth T2000
2008 Smart on deck
dblr is offline   Reply With Quote
Old 03-10-2020, 06:24 PM   #15
...https://www.forestriverforums.com/fo...ml#post2284488
Rich
Old 03-12-2020, 06:13 AM   #16
nomad297's Avatar
Rich
Well, just based on the first picture you posted of this, I couldnít work out what was what and I was focusing on that ball that isnít connected to anything and it just seemed to me that if a lot of weight was placed onto that ball, the plate it is attached to might fail.
Now that you have posted all of the pictures in your other thread I have a better understanding (I think), so my original comment is most likely not the case.
Bruce
Old 03-12-2020, 07:55 AM   #17
Pretty sure the structural guy from the frame manufacturer would be concerned about the length of this fatiguing the connection to the frame.
Very heavy thing as well.
I kind of like the Anderson better. It has the designed by a professional stamp on it.
tomkatb is offline   Reply With Quote
Old 03-12-2020, 08:21 AM   #18
I certainly don't have any measurements but from the side photos, it appears to be SHORTER than a regular pin box. I don't know that ingenuity needs some kind of "professional" stamp of approval.
If length is your hang-up... doesn't having the adapter of an Andersen with the ball coupler in the forward position, essentially make it a longer lever on the pin box? Are you not concerned about fatiguing the frame just because it says Andersen on it?
Old 03-12-2020, 08:35 AM   #19
Bruce
Yeah...I used cold rolled steel (vs. hot rolled steel) for the ball plate.
CRS is 20% stronger than HRS.
Do you have any idea what you're taking about? First of all, the center of the hitch point is exactly what it was before.
The weight is actually less because of the fact that the original goose neck adapter is removed, along with some of the original pin box.
The Anderson Ultimate doesn't pull from the ideal pull point. It is offset to the rear of the axle. While people don't cite any issues with it, it's not ideal when you tow from behind the rear axle.
Plus, my overall goal was to create bed rail-to-overhang clearance. The Anderson hitch wouldn't work, even if I wanted it to.
Rich
hitch
