Old 10-18-2019, 10:55 AM   #81
Hey there,
Someone mentioned earlier, check bed height and how much adjustment up/down in your hitch setup. I heard of some guys having to lift their trailer to get the correct ride height. I'm contemplating getting a newer Dodge 3500 4x4 which sit higher than the 4x2 I have now. I have 4-5" of adjustment on my hitch which might work out.
Good luck!
2015 Rockwood 8289WS
2003 Dodge Cummins w/Banks 3:73
CraigBean7672 is offline   Reply With Quote
Old 10-18-2019, 11:06 AM   #82
Not sure the big three make 4x4 anymore . most are 6x4 or 8x4 . since 4x4 stands for 4speed 4wheel drive . lol
MR.M is offline   Reply With Quote
Old 10-18-2019, 01:59 PM   #83
I believe you are wrong - the first number is the number of wheels, the second number is the number of driven wheels.
Fred W
Old 10-18-2019, 02:16 PM   #84
Fred W
Just trying to be a little lite hearted here . the acronyms 4x4 have meant several things from 4 wd to 4wd 4 speed etc . so it really depends on the when so not so wrong . lighten up
Old 10-18-2019, 02:36 PM   #85
Iwannacamp's Avatar
The first thing I thought of.... Olds 442
The AWD, FWD, 4WD, 4X2, 4X4, deuce and a half... I stay confused
2017 Puma 297RLSS
Old 10-18-2019, 02:37 PM   #86
Herk7769's Avatar
Fred W
This is correct.
In fact, without a positive traction (locked) rear, you are really 4x1 (LOL). To get true 4x4 you would need a locked front axle as well.
It is only by convention that 4WD means both axles have driven wheel(s).
Now AWD means that the wheel(s) with traction get the power.
HAM CALLSIGN - KC3FFW
Old 10-18-2019, 03:05 PM   #87
llr
Originally Posted by Gary Dup View Post
Another thing that convinced me to go with 4X2 was that the 4X4 has a higher bed height which I did not want pulling a 5th wheel.
I don't use the 4WD much but this is the only reason I would look for a 2WD truck. Of course I have a TT so this doesn't apply. One possible other reason at least with Ford super duties starting in 2017 or 20018, they are too tall for a standard garage.
TT 2017 Flagstaff 831CLBSS Classic Ultra lite
TV 2017 F150 6.5' bed 3.5 Eco-boost
prior TV 2014 Silverado 2500 HD
llr is offline   Reply With Quote
Old 10-18-2019, 05:01 PM   #88
rollscanardly's Avatar
I'm anguishing over this bed rail height / 5th wheel overhang clearance issue now while deciding on a new truck.
I'm surprised that the truck manufacturers don't offer an optional bed with lower bed side rails just for this reason.
Rich
"rolls down one hill, can 'ardly make it up the next..."
1999 21' Wildwood WDF21RK
2006 Dodge Ram 2500, 4x4, Quad cab, 5.9L Cummins, 3.73 gears.
rollscanardly is offline   Reply With Quote
Old 10-18-2019, 05:20 PM   #89
frank4711's Avatar
Rich
Have you been checking 3/4-one ton ... 4x4 ... they are higher than 4x2 ?? I have not done any test drives yet ... are you looking at Ram ... Thanks
Frank & Cindy--- (SOB) 5th Wheel ---2019 Ram 3500 Cummins 6.7 SRW 4x4 8' bed--- Payload 4394------Remi & Sage camping pups---TST 507 TPMS ... B&W Patriot 18K---3.73 axle ... Predator 3500---2019 48 days ---2020 28 days Camping
frank4711 is offline   Reply With Quote
Old 10-18-2019, 07:44 PM   #90
Lets go camping!
str8t six's Avatar
get the 3500. it doesnt have the TPMS. it has TPIS so you can run your tire pressures as low as you want without getting the warning light. i have mine at 50 right now. the 2500's will throw a light if they get below 65psi I think. makes the truck ride rough and limits tire selection.
also, i would get 4x4, better resale value. you can take out the rear spacers on the 3500 and it wont sit as high. about 1.5" lower.
2014 Rockwood Mini Lite 2504s
2016 Ram 3500
str8t six is offline   Reply With Quote
Old 10-19-2019, 07:49 AM   #91
My current truck is a Ram 2500 4x2.
I've got 5-6" of bed rail / 5er overhang clearance space right now.
My truck is way lower (less tall) than any 4x4 out there.
The camper leaf springs are axle-over.
So, without trailer frame modification, or the purchase of a "taller" camper, I'm pretty much stuck with what I have.
Rich
