Old 12-03-2018, 04:19 PM   #21
I mounted 2 strong magnets to the handle, It has never fallen off of the steel part of the fifth wheel. And i can put it where ever is handy. Another bonus, is that you don't have to drill any holes in your camper, which to me is just another spot that moisture can due damage.
Stein is offline   Reply With Quote
Old 12-03-2018, 04:26 PM   #22
Originally Posted by Old Bleu View Post
I mounted my lock handle with two of these magnets: https://www.amazon.com/Master-Magnet...nd+base+magnet
I've been moving it around on the pin box, looking for just the right spot.
I used magnets too, never had a problem and no holes!
clicker1944 is offline   Reply With Quote
Old 12-03-2018, 04:26 PM   #23
X2
Old 12-03-2018, 04:40 PM   #24
Seems the magnets are pretty well represented.
I don't have the Andersen but my brother does and he uses magnets too.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 12-03-2018, 07:20 PM   #25
Originally Posted by Cypressloser View Post
Yeah, you get what you pay for I guess.
I used self tapping screws and fastened the bracket right to the fiberglass without pre-drilling. Make sure you hand tighten the screws with a screwdriver not a power tool.
Hopefully the Harbor Freight impact sockets fare better because If they can’t handle 40 ft lbs. I sure would want to put them on an impact.
2016 Ford F350 Lariat
2019 Sandpiper 372 LOK
2019 Puma 32RBFQ
cstreu1026 is offline   Reply With Quote
Old 12-04-2018, 02:42 PM   #26
1” and 6” bits are plentiful. The 1” bit is too short (needs to be
1 5/8” minimum length)
I have a 6” bit but as mentioned above it twists a lot when torquing.
I still don’t get the T-handle/torque wrench discussion.
Where did you guys find the correct bit length?
2016 RAM 3500 DRW 4x4 LB LoneStar, w/RDS 33Gal Aux tank, Timbrens, Andersen Ultimate2, SwiftHitch SH04
2018 Chaparral 360IBL w/TST507 TPMS, Lippert GC3 Autolevel, Furrion Backup Cam, Progressive HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHUw/Andersen No-Sway
chaps2018 is offline   Reply With Quote
Old 12-04-2018, 02:50 PM   #27
2007 WildCat 32QBBS
18CrewDually's Avatar
I guess you weren't the only one. Amazon recommends these three items!
18CrewDually is offline   Reply With Quote
Old 12-04-2018, 02:50 PM   #28
I picked up a set of impact sockets from Harbor Freight that are long enough and should take quite a bit more than the 6" long sockets.
2019 Puma 32RBFQ
Old 12-04-2018, 02:52 PM   #29
Attachment 192597
That's too funny because I ended up doing exactly the same thing.
2019 Puma 32RBFQ
Old 12-04-2018, 03:14 PM   #30
Originally Posted by cstreu1026 View Post
I picked up a set of impact sockets from Harbor Freight...
Thanks!
Old 12-04-2018, 03:18 PM   #31
I used a Proto hex socket and it's the perfect length 1-5/8", and being that it's Proto it's plenty strong enough.
Gotta go campin!
Old 12-04-2018, 08:49 PM   #32
Question for Andersen Ultimate 5th Connection Users
It came home today. Click image for larger version
I did notice something I didn’t have with the travel trailer. It’s kind of like there is slack in hitch with what feels like front to back movement.
2019 Puma 32RBFQ
Old 12-04-2018, 09:05 PM   #33
Mr. Dan's Avatar
It came home today. Attachment 192620
That doesn't sound right. There's absolutely no slack/no chucking in mine.
Old 12-04-2018, 09:07 PM   #34
My brother says the same.
No clunks or chunks.
Old 12-04-2018, 09:23 PM   #35
It doesn’t occurs when you’d think it would which kind baffles me. I’m going to run through everything again to make sure everything is properly torqued
2019 Puma 32RBFQ
Old 12-05-2018, 12:23 AM   #36
X2
Old 12-05-2018, 09:08 AM   #37
Make especially sure that you torque the top bolt first the then the side bolts. And make sure the side bolts are loose before torquing the top one.
The instructions call for 50 lb/ft but I torque mine to 60 lb/ft.
Gotta go campin!
Old 12-05-2018, 08:28 PM   #38
My instructions say 40 ft-lbs but their You Tube video says 60 on both top and side bolts. I split the difference at 50. I have to wonder if I’m not hitting overload springs
2019 Puma 32RBFQ
Old 12-05-2018, 10:00 PM   #39
We have absolutely NO chucking or movement. Something is not right.
merrykalia is offline   Reply With Quote
Old 12-05-2018, 10:34 PM   #40
I’m also wondering it’s at the goose ball.
2019 Puma 32RBFQ
