Old 08-21-2017, 06:52 PM   #1
Ram 342 gears
Was looking into a ram 3500 srw cummins with aisin trans only to find out its only available with 342 gears. I wanted 410s. Like my ram drw has . My tow range is around 12k to 13k . How much of a difference will the 342 be over the 410s ? I`m concerned it will be a major let down . Dealer wants used diesels and if the deal is good as good can get I would trade . But I`m thinking the gears will be a deal breaker . What`s your thoughts ?
Big Red and 30WR is offline   Reply With Quote
Old 08-21-2017, 07:06 PM   #2
Crusadernoob's Avatar
That's a big hit on ratio, I would compare transmission gears and see what it would be like. I'd put them both on paper, I would think it would be easier to strategize that way side by side.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37, 2020 19
Crusadernoob is offline   Reply With Quote
Old 08-21-2017, 07:09 PM   #3
drittal's Avatar
Ram 342 gears
Lock out 6th and go. I tow 12k. Many that tow more.
The Aisin will give lower starting gears compared to the 68RFE.
My fathers 4.10 DRW in 6th and my 3.42 SRW in 5th are roughly same rpm.
*edited because of autocorrect
drittal is offline   Reply With Quote
Old 08-21-2017, 07:09 PM   #4
BGKirkham's Avatar
Check the tow ratings and payload for the truck you want to buy. If it will do the job, why sweat the axle ratio. I think 900 ft-lbs of torque will make you happy, regardless of the axle you're stuck with.
Gary
2017 Cedar Creek Silverback 37MBH
2008 Dodge Ram 3500 6.7L, DRW, 4.10 Rear end
BGKirkham is offline   Reply With Quote
Old 08-21-2017, 07:13 PM   #5
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Don't worry as long as the weights and tow ratings pan out. That Aisin is a beast!!!
Put her in Tow/Haul and hit the gas.You're gonna get awesome fuel mileage, seriously.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
Cypressloser is offline   Reply With Quote
Old 08-21-2017, 07:26 PM   #6
Both trucks have the aisin tranny so wouldn`t they be the same gearing? My drw with 410s also has 900ft of torque and it tows amazing .
Old 08-21-2017, 07:31 PM   #7
The tow rating on the srw is 16860 my drw is 30320 A big difference but both over my tow range
Old 08-21-2017, 07:35 PM   #8
My fathers 4.10 SRW in 5th and my 3.42 SRW in 5th are roughly same rpm.
So with that said with 342 it really wouldn`t downshift more than with 410. Better fuel mileage empty as well
Old 08-21-2017, 07:36 PM   #9
drittal's Avatar
Damn autocorrect got that.
I tow in 5th, my father tows in 6th.
Old 08-21-2017, 07:37 PM   #10
markfromark's Avatar
The truck in my signature has 3.42 along with the Aisin. I was concerned at first, but after towing with it for a year, I'm really pleased. 1st gear is so low, it's seems effortless starting off. My tow range is similar to yours.
Mark
Mark and Dianna
along with Hank the Wonderdog
2016 CC Silverback 33IK
2015 Ram 3500 DRW
markfromark is offline   Reply With Quote
Old 08-21-2017, 07:51 PM   #11
Mark
I know what you mean my drw with the aisin first and second gear are slow but comes to life fast when it gets into 3rd gear .
Old 08-22-2017, 02:54 AM   #12
Big1's Avatar
So what did you decide to go with, either way you are good?
2018 Dodge Ram 3500 6.7L CTD
2019 Jayco Eagle 321RSTS
Retired Army MSG.
Big1 is offline   Reply With Quote
Old 08-22-2017, 04:35 AM   #13
m35a2's Avatar
My srw has 342 gears and a 68RFE. Tows great. In fact the Aisin has LESS trailer weight capacity on an srw (truck in my sig has max trailer weight 17,010, with an Aisin it'd only have 16,860)
Bottom line you don't need 411 gears or an Aisin unless you want to tow more than a 17k lb trailer... and in that case you need a drw anyway.
I've pulled from SC to NM and back with this setup. It's solid.
-- My wife complains I never listen to her. Or something like that.
2017 Heritage Glen 368RLHBK Limited
2017 Ram 3500 4x4 Crew, 6.7 Cummins
m35a2 is offline   Reply With Quote
Old 08-22-2017, 05:48 AM   #14
The chevy has one ratio, 3.73 no options. i was concerned but have not had an issue.
Like others have said, look at the tow ratings. If they are within range go for it.
2015 grey wolf 27RR
2015 Chevy 3500HD
kcmusa is offline   Reply With Quote
Old 08-22-2017, 11:25 AM   #15
Still waiting to hear back from the dealer and see how the numbers add up. Probably end up keeping my dually with the 410 gears .
