Old 08-31-2019, 10:15 AM   #1
ryand's Avatar
Ram 6.4 maintenance 100k
My Ram just rolled over 100k miles and itís time to do some maintenance and for some weird reason I felt the need to share the details. Having only done oil changes, 1 set of tires and three air filters so far, costs of ownership (other than gas) have been pretty low
Ram 2500 6.4
Current mileage 102,500
4x4 w 20Ēwheel option
To date:
14 oil changes @ avg of $70.00 each
1 set of continental terrain contact $1,467.00
3 air filters @ $9.80
100k service
Front and rear diff service with required synthetic $53.00 per axle
Trans filters and fluid $87.00
16 spark plugs $138.00
Total cost over 100k miles of routine maintenance required per owners manual $2,750.00
This also is handling all tasks myself, the truck has never been back to the dealer.
There always is talk of Gas vs Diesel threads, this ongoing cost should be a factor as well outside of upfront costs. At least it was for me.
2019 SOB Bunkhouse (Former Coachman FR Owner)
2015 Ram Bighorn 2500 6.4L
https://www.ryandethrow.wordpress.com
Nights Camped 2016: 32
ryand is offline   Reply With Quote
Old 08-31-2019, 10:52 AM   #2
NMWildcat's Avatar
Ram 2500 6.4
To date:
100k service
I keep vehicles a long time also. Thanks for your thread to remind folks that this maint needs to be done.
Every 100k I also change the serpentine belt and all idlers/tensioners. Flush the radiator and replace hoses. Replace any rubber fuel lines. At 200k I will replace the water pump if it hasn't been done already. Alternators seem to last me around 150k.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 08-31-2019, 10:56 AM   #3
Cheaper maintenance with a gasser could be offset by the higher fuel costs.
Diesel costs more to maintain but gets better fuel mileage.
Might be a wash in costs...pure speculation on my part.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 08-31-2019, 12:45 PM   #4
I would have been doing a lot more maintenance than you have already done. Transmission fluid and transmission filter changes at least every 30K miles along with diff oil changes earlier than what the manual says. Brake fluid changes at every 2 years.
babock is offline   Reply With Quote
Old 08-31-2019, 03:38 PM   #5
16 spark plugs? Do you have 2 per cylinder?
Tatsngats is offline   Reply With Quote
Old 08-31-2019, 04:12 PM   #6
ryand's Avatar
I understand your point, however all fluids looked great including rear diff. I donít see the benefit of doing things earlier than required if you are Following the guidelines of the Manufacturer.
Old 08-31-2019, 04:18 PM   #7
ryand's Avatar
Yep. My 11 required all 16 every 30k.
Old 08-31-2019, 04:22 PM   #8
I understand your point, however all fluids looked great including rear diff. I don’t see the benefit of doing things earlier than required if you are Following the guidelines of the Manufacturer.
As long as you are looking at the guidelines for heavy duty towing. To me 100K miles is way too long for transmission fluid changes.
As far as brake fluid changes, many car manufacturers recommend 2 year intervals and RAM doesn't have a recommendation. Change an ABS unit or master cylinder and calipers these days and you can see why it is important to change out brake fluid. Many people just do a brake fluid change when brake pads are replaced if you don't want to do the 2 year interval.
I change out power steering fluid as well.
Antifreeze gets changed out way before 100K. Longer radiator life and water pump life. I change mine at between 60K or 80K.
Old 09-01-2019, 09:40 AM   #9
ryand's Avatar
All depends on how the truck is being used, for me the 100k mileage on the odometer represents less than 10% of those miles were used for towing purposes. I worked as an dealership tech for many years, most of the jargon promoted by the service writers and mechanics were tools to upsell customers.
Old 09-01-2019, 10:48 AM   #10
Depends on how you use it I agree. Our truck has 28K miles on it but more than half are trailering miles. A lot of things I mentioned, like brake fluid doesn't matter how you drive your vehicle.
Old 09-02-2019, 01:37 PM   #11
Op, curious what year is your truck and what is the weight of what you tow?
deepseadan is offline   Reply With Quote
Old 09-02-2019, 05:55 PM   #12
Lins's Avatar
Iím similar, but as I donít rack up a lot of miles typically, I address belts, hoses, etc. at the 10-12 year mark. I get that interval from the aviation world.
2007 Rockwood 2701SS
1953 GMC 9314
1982 GoldWing Interstate
Lins is online now   Reply With Quote
Old 09-03-2019, 09:12 AM   #13
ryand's Avatar
My truck is a 2015 and pull a trailer with a GCVW of about 9500#
Old 09-03-2019, 09:26 AM   #14
Thanks. Iím thinking on either leasing or buying a ram next year. Iím going to lease a 2500 crew or mega cab for the payload. I tow a small toy hauler that only has around 500-600 lbs tongue weight but I want to be able to carry a couple dirt bikes in the back. With the dirt bikes, tongue weight, family and cargo a 1500 just doesnít have the payload. Plus I think rams are probably the best looking trucks. Glad to hear yours doing good still at 100k.
Old 09-03-2019, 09:57 AM   #15
Georgia Rally Coordinator
aceinspp's Avatar
Thanks for providing the info on your cost to maintain. Later RJD
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Days camped 2020 46
Old 09-03-2019, 10:19 AM   #16
Ejs4029's Avatar
Ram 2500 6.4
To date:
100k service
Hi Ryand, How do you like the Continental Terrain Contact's ? Do you have the 20" stock rims ? The reason I ask is I have been looking at these for my 2015 RAM 2500 with 20" wheels I still have the stock Firestone Transforces with 32K however, my local Discount tire manager says they get complaints of vibration and try's to steer me away from them saying I won't care for them and the tries to push Bridgestone's on me and says they are the best he also dislikes Michelins so I have my doubts on his agenda.
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30C
Ejs4029 is offline   Reply With Quote
Old 09-03-2019, 10:38 AM   #17
aceinspp's Avatar
Well I got rid of my Firestone tires right after I bought the truck and installed Michelins. Love em on the Ram. I also had them on my 2500 2015 Chevy and they really make the truck handle very well. Later RJD
Days camped 2019 62
Days camped 2020 46
maintenance
