Old 09-12-2019, 03:56 AM   #21
RVSmitty,
I'm this entire fiasco, you have never once told us what the payload is. You have said tow ratings, but you dropped to silence on the most important fact... Payload. It does feel as if you stopped responding, I'm guessing that is because you don't like the responses your getting? Please don't be offended, we are actually trying to help you out.
Call the dealer, ask them to open the driver's door and take pictures of the yellow sticker and text them to you. This should be no big deal for them. And then for the first time you can respond to us with that fact, and you'll also discover the severe limitations (or not?) of that truck.
Or, I guess you can be offended, go silent, dislike the truth and go buy that truck and trailer with blinders over your eyes and move on with life.
2019 Ram Bighorn, CC/SB 2500 4x4 6.4L/8 Speed, Max Tow 14,460 lb/2,940 lb payload.
2019 F-150 King Ranch 3.5 Eco, 12,800 lb/1,546 payload.
2020 Coachmen Apex UL 289TBSS
2019 Quality Trailers 16'x7' 7K GVWR Utility Trailer
2019 IronBull 22'x102" 14K GVWR Equipment Trailer
Larry0071 is offline   Reply With Quote
Old 09-12-2019, 04:22 AM   #22
Originally Posted by Lins View Post
Apples to oranges since mine is a 2500, but I have the rear air on mine, haven't seen a warning yet, other people have seen it, but they were around the axle weight limit which is about a 1000lbs over the payload rating, give or take.
Not true on the statement of the rear axle limit being about 1000lbs over the payload rating. My 2017 Ram 1500 standard cab 8' bed has 1670lbs payload on the yellow sticker and 3900lbs rear axle limit. Crew cab higher optioned trucks could have much less payload but all 4th gen 1500 Rams have a 3900lb rated rear axle.
My17Ram is offline   Reply With Quote
Old 09-12-2019, 08:59 AM   #23
Lins's Avatar
I'm talking about the 2500s, and what I meant was I have heard of people getting the overload warning, but they were 1000 lbs over the payload rating, and the total rear axle weight at the time was around the rear axle weight rating. I did not mean the axle weight rating is 1000 lbs over payload.
2007 Rockwood 2701SS
1953 GMC 9314
1982 GoldWing Interstate
Lins is online now   Reply With Quote
Old 02-11-2020, 12:38 AM   #24
Excellent b2b
2015 ecodiesel quad cab 3.92 rear end. Just bought a 2018 2612ws new for good price. Tows great.
Reese pro series WDH
Green Diesel Engineering engine tune
SKT transmission tune
Timbergrove enterprises supplemental airbags.
Seems to be a great set up. Will have more info after first trip later this month.
1shadowsabre is offline   Reply With Quote
diesel
