Old 10-03-2019, 03:54 PM   #1
Ram Integrated Brake controller
I have a 2017 Ram 3500 Duelly pulling a 2015 Flagstaff. Fully loaded weight on the 5th wheel is 8577 lbs. I know, way more truck than I need. Since the truck was new I have had issues with the brake controller. It will not stop the trailer safely. Finally found a dealer who had the knowledge and tools to test. Turns out the controller puts out 8.2VDC when energized, gain set at MAX. Tested 3 other Rams, same voltage. Tested F350. 10.6VDC. Answer from Ram engineers, "That's the way it is".
Talking to commercial pullers, they tell me to put on an after market if I want to stop safely. So it looks like I bought a $65K truck and get to hang a controller under the dash.
Anybody else having problems?
sdfarmer is offline   Reply With Quote
Old 10-03-2019, 04:06 PM   #2
I have a ram 3500 also. Have no problem with the controller. There is a setting for a heavy load. It has to be set up. Check your truck manual. My trailer weighs 12,000 pounds have no problem with the factory controller. Also tow/ haul must be turned on. Also if you have a Diesel turn on the Jake Brake
MichaelW is offline   Reply With Quote
Old 10-03-2019, 04:33 PM   #3
TowPro's Avatar
I had a 15 and a 18, both functioned perfect. You will find it don't lock up the brakes but your not supposed to lock up your trailer brakes. But if you read the diesel forums they will tell you there opinion on how it's broke.
Did you set it heavy electric
2019 Forest River Forester MBS 2401R
TowPro is offline   Reply With Quote
Old 10-03-2019, 04:56 PM   #4
rracer5's Avatar
X2
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 10-03-2019, 08:25 PM   #5
Lins's Avatar
My brake controller works way better than my prodigy ever did. Also, you don’t get full voltage until you’re at a certain speed. Hopefully that was factored in when your dealer tested it. I have my doubts considering 3 other trucks did the same thing.
2007 Rockwood 2701SS
1953 GMC 9314
1982 GoldWing Interstate
Lins is online now   Reply With Quote
Old 10-04-2019, 12:26 AM   #6
Had a 12 Ram CTD and the TBC sucked. Put a P3 in and used it for 6 years. Bought a 2018 Ram 2500 6.4. The TBC works perfect. Towing 9500 lbs I run 7.0-7.5.
My TT also has 12"x2" drums.
Pulled two different trailers with the 12 CTD so I knew it wasn't the trailers.
Also pulled one of the trailers with a 2010 F150 and that TBC worked perfect.
I think it's hit or miss with Rams TBC.
goduc is offline   Reply With Quote
Old 10-04-2019, 05:01 AM   #7
I have a 2017 Ram and 2019 Ford, both with factory brake control in the dash and both work better than every aftermarket I had ever owned. My ram is set on "Heavy Electric".
2019 Ram Bighorn, CC/SB 2500 4x4 6.4L/8 Speed, Max Tow 14,460 lb/2,940 lb payload.
2019 F-150 King Ranch 3.5 Eco, 12,800 lb/1,546 payload.
2020 Coachmen Apex UL 289TBSS
2019 Quality Trailers 16'x7' 7K GVWR Utility Trailer
2019 IronBull 22'x102" 14K GVWR Equipment Trailer
Larry0071 is offline   Reply With Quote
Old 10-04-2019, 05:50 AM   #8
TowPro's Avatar
There was a tsb in 2015 or 16 that made the older ones work right. Than I think a new design in 16 or 17
Old 10-04-2019, 09:07 AM   #9
Lins's Avatar
Correct. Our '17 is an early build and we've had no issues with our TT, a dump trailer and an HD open car hauler with marginal brakes on it.
1953 GMC 9314
Old 10-05-2019, 09:39 AM   #10
I have mine set to "heavy" with the gain set to 9, it works great.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 10-05-2019, 07:10 PM   #11
frank4711's Avatar
Works fine on my 2019 Ram ... tried both light and heavy both worked ... I am set 7-7.5
... best of luck
Frank & Cindy--- (SOB) 5th Wheel ---2019 Ram 3500 Cummins 6.7 SRW 4x4 8' bed--- Payload 4394------Remi & Sage camping pups---TST 507 TPMS ... B&W Patriot 18K---3.73 axle ... Predator 3500---2019 48 days ---2020 28 days Camping
frank4711 is offline   Reply With Quote
Old 10-05-2019, 09:15 PM   #12
NO, thats " Not the way it is" However its Ram's default answer with Problems.
Ask to run other trucks voltage when set at max and see what you get.
Explain this is a safety issue and the purpose of the break controller installed on the vehicle is to coordinate the proper operation of trailer brakes. If this is not done properly, then you feel like it creates an unsafe operation, rendering your truck useless for the purpose purchased.
my new 5th wheel is running a tad over 13K now I believe and it stops extremely well.
Ron and Kathy
2019 Cougar 369BHS 5'VR
2018 Cherokee Limited 304 BH (Traded)
Joyfully Towed with a 2018 RAM 3500 6.7 CTD
ronheater70 is offline   Reply With Quote
Old 10-10-2019, 08:24 PM   #13
vintage's Avatar
Had the Ram factory controller on my 2016 and now on my 2019 with no issues, run on "heavy setting"....not to be an ass but make sure your TT brakes are set up and adjusted, because the brake controller won't make up that difference.
2016 Grey Wolf 26RR Limited
2017 Arctic Cat Wildcat Trail Limited
2019 Dodge Ram 1500 Bighorn Crew Cab
5.7 litre Hemi 4x4
vintage is offline   Reply With Quote
brake control, controller
