Best to base your weight calculations on the trailer GVW, not dry weight.
With that said, here are some actual numbers from my setup.
Advertised dry weight: 5645
Advertised tongue weight: 720
As delivered weight: 6052
Loaded actual weight: 6950
Trailer GVW: 7642
Actual tongue weight: 950
Observations on comments from others:
Ram 1500 or F-150 make better daily drivers than heavier trucks. Heavier trucks may have a higher cargo capacity.
My F-150 is stock with 20" wheels. No air bags or upgraded shocks. I have no complaints on towing. Rather than upgrade the truck, I spent the money on a ProPride hitch which I think is the safest available hitch. Lots of threads covering the "which hitch is best" discussion.
Since you are in Michigan, if you want a ProPride, you can save around $250 by picking it up in Davidson, just outside Flint.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
