Old 07-19-2015, 09:58 AM   #1
Receiver Lock Recommendation
For years I always thought it was odd to spend $20 on a receiver lock to secure a $15 receiver available from any store. After just spending over $400 on the hitch setup to pull the new TT and difficulty to replace that receiver from a local Walmart or Tractor Supply... I see where the $20 is not a bad investment.
Any recommendations as to what design or manufacture is best? I see some are 1/2 in to 5/8 sleeved... Any issues with the sleeves getting stuck in the hitch or being a headache? I worry about some of the cheap no names as I would hate to have road slop get in and jam the lock up so the key wouldn't work.
Thanks!
2015 Flagstaff MicroLite 25DS
2008 F150 XL 4.2L
Days Camped 2015 - 23
skidooosl is offline   Reply With Quote
Old 07-19-2015, 10:11 AM   #2
Thanks!
I've been using them for years, no issues. Pep Boys for me usually. No brand loyalty and not even sure who the manufactured the one I use now. Camper in storage along with hitch receiver lock.
George Scott
2015 Salem Hemisphere Lite 272RLIS/ Prodigy P3
2006 Heartland BH 3400/Summer Home
2007 Dodge 2500 CDT QCSB/Blue Ox Sway Pro 1500lb WDH, Maxxis 8008 225 x 75 x15 LR E tires/J T Strongarms
Scotty is offline   Reply With Quote
Old 07-23-2015, 05:32 PM   #3
Tfort's Avatar
Just remember that these locks just keep people honest. I work for a car dealership and we have to take hitches out and usually don't get the key. One good hit with a heavy hammer and it breaks the lock right off.
Tfort is offline   Reply With Quote
Old 07-23-2015, 05:34 PM   #4
Torch's Avatar
Too make my life easier knowing it's just a deterrent, I use the locks that your ignition key is used to open,One-Key Lock Technology - Learns YOUR key the first time you use them ‚ÄĒ BOLT Locks by Strattec
Torch is offline   Reply With Quote
Old 07-23-2015, 05:55 PM   #5
Just a Little input,if you have a (Class #5) (2-1/2") Hitch as in GM you (Might have to (Turn Down) the shoulder on the (5/8) locking Pin to allow the (locking Side) to enter! Just a caution to look at! Youroo!!
Old 07-23-2015, 06:09 PM   #6
Torch's Avatar
I have a 2 1/2 receiver on my 2013 Ram and that lock works fine, tight but ok with out any modification.
Old 07-23-2015, 06:32 PM   #7
trbomax's Avatar
When I used to use a WDH all the time I would just run a gr 8 5/8" sae thread bolt thru instead of pin,then secure it with a stover nut. Since I always have a cordless 1/2" impact in the truck,I would just run it down to 100 ft lbs and not worry about it. 99,9 % of the people that would want it dont have the tools to remove or the strength.Never lost one in 45 yrs!
trbomax is offline   Reply With Quote
Old 07-23-2015, 08:07 PM   #8
ferguson65's Avatar
I have a cheap locking hitch pin that lived in my old 2004 F150. It's a no name unit and did the job. Only had one time where road salt almost got it, but I managed to get it loose. It's worn pretty bad now to the point I wouldn't use it if I could. Current truck has a class 5 hitch and I needed a new one, ordered "Deadbolt" brand from Etrailer. So far so good, but I really only use it to lock a shank in the hitch once in a while. My biggest issue in searching was trying to find one that advertised some kind of weight capacity, and there weren't many. I don't tow a ton of weight with the receiver, I have a 10K dump trailer, everything heavier has been gooseneck or 5th. Lately I have just used the standard pin and leave the shank in the dump trailer toolbox when I'm done. Everyones shins thank me!
2013 F350 dually
2015 Palomino Puma 351THSS Premier Edition
2015 Nights camped 15
2016 Nights camped 5
ferguson65 is offline   Reply With Quote
Old 07-24-2015, 04:04 AM   #9
Advance auto sells a line of hitch pins branded by Reese. The Class 4 pin is shorter than the 2.5 inch class 5 pin. The 5/8 pin has a greater weight rating than the 1/2 inch pin, those things are sloppy enough, without adding any more to it! Max ratings on the new class 5 is 17K with weight distribution hitch, I figure to buy once, and hate to buy again!
2015 Dynamax Trilogy 38RL, 2014 Ram 3500 DRW Maxtow package.
Kevinc2011 is offline   Reply With Quote
Old 07-24-2015, 06:46 AM   #10
Engineer of Crazy Train
ChooChooMan74's Avatar
I use the one key Bolt lock. Little more expensive, but you always have the key with you.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 07-24-2015, 07:02 AM   #11
Stormrider151's Avatar
I just remove it from the truck and put it in the bed. It's out of sight so theft is not a problem. I got tired of hitting my leg on it all the time.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost (Best tv ever)
2018 F250 Lariat (ok but I miss my F150)
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 07-24-2015, 07:08 AM   #12
Just drilled the 5/8" regular hitch pin out to accept a regular Master padlock.
Old 07-26-2015, 03:37 AM   #13
Just a member
kandl's Avatar
Master Lock produces a variety of receiver locks. We've been employing one for the past four yrs and have had no issues with it.
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge 3500 SRW Crew HO CTD
kandl is offline   Reply With Quote
Old 07-26-2015, 06:13 AM   #14
Who Dares, Wins
doc73's Avatar
Being that we both live in ice and snow areas how has it held up with it? I only keep the lock in long enough to keep stuff from going away. I had to saw a cheaper lock off a few years ago after only a few months of being on the truck. Won't do that again... LOL
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 07-26-2015, 01:53 PM   #15
Just a member
kandl's Avatar
The lock gets a liberal dousing of WD-40 once or twice a year - has kept it functional through snow, ice and that notorious prairie gumbo. I tend to not leave the ball mount installed in the receiver unless I'll be using it and even then I'll remove it periodically to clean it and make sure everything still works. So far, so good.
Old 07-26-2015, 02:09 PM   #16
asquared's Avatar
We went to Wal-Mart and picked one that was the correct size for our receiver and could withstand the weight of our old tt. We used that locking pin every time we towed in addition to when not towing.
<a href=https://i62.tinypic.com/28rp645.jpg target=_blank>https://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
