Old 04-18-2020, 09:11 AM   #1
Reese Revolution
I bought a 2015 8289ws last spring. The previous owner didnít use the revolution feature. I used it for a couple of short hauls but ordered the maintenance kit for this season.
I have tried everything that I know to get it to separate. Anyone know what I maybe doing wrong. I didnít take off camper thinking that the weight would help drop it off pin. Even with the nut off it takes a grown man to move from side to side. Tried driving wood wedge and sprayed with kroil
Any additional help would be appreciated
Tommuy6867 is offline   Reply With Quote
Old 04-18-2020, 09:18 PM   #2
PhoneDude 8289's Avatar
First time I did mine I had used it for two years, bought RV new 20/'13. Had a heck of a time getting it apart the first time. screwed a 4" long bolt in place of one of the wedge bolts. Unscrewed the large nut from the shaft leaving 1/2 the nut threaded on so not to let it un expectedly drop. Used a 4' long crow bar to swing it side to side, it eventually worked it's way down the shaft. Removed the castle nut, backed the truck tailgate under it swinging it side to side till it dropped on the 4"x4" timber I had across the tailgate. The thing was nasty with rust, grime, welding slag and whatever. I have done it every year since without any issues. I clean it grease it and put it back together.
A few before and after pictures.
Name:	top plate of pin box.jpg
Name:	Spindal condition 2.jpg
Name:	Spindal & bottom  plate of pin boxafter cleaning.jpg
Name:	getting it together..jpg
Name:	Condition of spindal.jpg
Joe & Beverly
2014 Ram 2500 CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 04-19-2020, 06:29 AM   #3
Reese revolution
Thanks thatís the best information
I will let you know how it turns out. Thanks again
Old 04-19-2020, 03:19 PM   #4
Now when it's parked I rotate the hitch pin under the RV out of the way.
Joe & Beverly
2014 8289WS lifted
Old 04-19-2020, 03:20 PM   #5
Thanks for info but the slots on mine are welded flat for some reason. Came from factory that way.
Tomorrow weather permitting I’ll put the heat gun on stud may loosen hardened grease but not hot enough to melt bushing.
reese
