Replace Water line 2012 Flagstaff 2109S
Today I installed a Lippert Solid step on my 2012 Flagstaff 1209S Pull behind Camper. When I started drilling the 2nd row of mounting bolts, I hit a water line that runs under the door threshold to the drain outlets. It is past the control panel.
I want some input on the best way to get to the pipes at the door way. I figure, I am going to have to remove the newly installed stair and cut the under belly to expose the pipes.
Any suggestion would be appreciated.
