Old 06-14-2019, 02:58 AM   #41
DouglasReid's Avatar
Originally Posted by jbrobson View Post
I had thought about doing this today, but have no idea how to do it. Do you weigh the combined rig and then unhook and do just the truck? Chevy 2500 with a Rockwood 2906ws TT. Any advice to not look an idiot is appreciated.
That is exactly correct.
There is a speaker at the scale where you can talk and listen to the attendant. They will tell you when to stop as you pull forward.
Then tell them you want a "Reweigh" drive to the parking area, drop the trailer then back to the scales.
Go to the office pay the @17.00 and they will give you the two weigh tickets.
Simple.
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 06-14-2019, 05:38 AM   #42
Oaklevel's Avatar
https://catscale.com/how-to-weigh/
Click and Scroll down CAT scales web site address RVs weighing how to pull on the scales.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 06-14-2019, 08:44 AM   #43
mwheue's Avatar
Originally Posted by clarkbre View Post
Very few and far between that an RV rolls over a scale.
One thing that I do think people get hung up on is that they "need" to use a CAT scale. I've always just used a standard scale and taken measurements and subtracted weights as I rolled on. It's a little more math but the same concept. The spreadsheet I use actually does all the calculating as I enter the scale data.
Living in WA, I need to find a CAT or other private scale. Local dirt suppliers are easy and close by with large scales.
When we travelled through OR this year and last, they have roadside scales that I have rolled across. Those are very handy and I wish we had them up here.
Pilot Travel Center
I-5 & Exit 208
Arlington, WA 98223
Manager: Jennifer Melick
Phone: 360-654-8324
Street Address: 2430 State Route 530 NE
Arlington, WA 98223
mwheue is offline   Reply With Quote
Old 06-14-2019, 09:54 AM   #44
We use the scales when fully loaded and all water tanks empty, we get 2 tickets one hooked up and 2nd after I drop front jacks and weigh 5er and truck separate just to be sure. We get weighed once every year regardless - 2018 F-350 / 2019 Grand Design Reflection. Have fun & Be safe
The Boys is offline   Reply With Quote
Old 06-14-2019, 10:26 AM   #45
Never been on one.
TheWolfPaq82 is offline   Reply With Quote
Old 06-14-2019, 11:27 AM   #46
Fulltime family RVer
With a travel trailer, you'll do 3 weighings:
1) truck + trailer together; WDH connected/"engaged"
* pull off the scale to make changes, disconnect WDH bars and throw them in the truck bed *
2) truck + trailer together; WDH off- just coupler on ball
* pull off the scale + park the trailer *
3) truck only
Full instructions here:
https://learntorv.com/how-to-weigh-a-travel-trailer/
If you have the "Weigh My Truck" app, you can capture each weight with the app. If you don't, you have to go inside after the first weighing to get your weigh slip so that you have a weigh number for the re-weighs.
And then, take the results and plug them into this:
Actual Weights - Travel Trailer/Bumper Pull Weights from CAT Scales - Towing Planner
Old 06-14-2019, 01:40 PM   #47
bikendan's Avatar
Originally Posted by mwheue View Post
Pilot Travel Center
I-5 & Exit 208
Arlington, WA 98223
Phone: 360-654-8324
Arlington, WA 98223
This Pilot just became operational a few months ago. A year ago it didn't exist so many in the area, don't know about it. I check it out, every so often, and it seems to be empty a lot
Old 06-15-2019, 03:18 PM   #48
clarkbre's Avatar
Originally Posted by Macrosill View Post
Can you share the spreadsheet for others?
Happy to. Follow the link and download it to your computer.
Here is the link:
https://www.dropbox.com/s/och5g6y4ds...e.xlsx?dl=0&m=
2017 Forest River Surveyor 247BHDS...
...Tugged by a 2016 F250 XLT FX4 SuperCrew, Shortbed 6.2L, 4wd, 3.73...
...Joined with a Husky Centerline TS 800-1200lbs WDH
clarkbre is online now   Reply With Quote
Old 06-15-2019, 07:10 PM   #49
Here is the link:
Thank you so much for sharing!
Kaffeenjunkie is offline   Reply With Quote
Old 06-16-2019, 07:48 AM   #50
Camper
Here is the link:
That is a pretty detailed spreadsheet. I made a quick one the other day but no where as detailed as yours. I never thought to put in the capacities of the truck and trailer axles.
Thank you for sharing.
Thanks,
Brian
TV - 2006 F350 6.0 DRW CC
TT - 2018 Wildwood 31KQBTS
Macrosill is offline   Reply With Quote
Old 07-01-2019, 01:36 PM   #51
3) truck only
AWESOME site. Just came from the local port weight scales. Did the 3 runs. Plugged in actual numbers and everything I calculated jives. Plus, it gave me my loaded camper weight, assuming after bars sent some weight back, which was a number I was not able to calculate.
2016 Wildwood DLX 353FLFB (for sale)
2019 Coachman Catalina 29THS
2018 GMC Sierra 1500 5.3 Max Tow
Husky Centerline HD 1400/14000 WDH
alb2tpa is offline   Reply With Quote
cat, scales
