Old 11-13-2017, 09:03 PM   #41
Originally Posted by Wileykid View Post
Agree with the Chevy engineer getting hired by Ford. My Chevy has the same issue, and solved by buying a new clevis hook that has the wider throat and is rated higher at Tractor Supply (https://www.tractorsupply.com/tsc/pr...n?cm_vc=-10005)
Mark
Those are the exact version shown in the second picture in post #1. No joy without modification.
madmaxmutt is offline   Reply With Quote
Old 11-16-2017, 09:22 PM   #42
My Fastway breakaway cable D ring won't fit either. I found this oddly; well perfectly shaped D ring at Tractor Supply Co.
Name:	breakaway brake d ring.jpg
It fits perfectly.
Old 11-16-2017, 11:41 PM   #43
Attachment 156562
It fits perfectly.
It's called a carabiner.
2011 Traverse LT, 3.6L, FWD
Old 11-17-2017, 08:51 AM   #44
mzbrandi's Avatar
Originally Posted by youroo View Post
The Engineer that got Fired from GM for the Same thing got Hired by Ford! Real Pain trying to use "As Is"! Youroo!!
Ha ha I think your right.
Brandi
mzbrandi is offline   Reply With Quote
Old 11-17-2017, 10:25 AM   #45
Originally Posted by Retired JSO View Post
You guys fussing about the truck hitches need to take a good look as to how your chains are attached to the trailer. Mine are bolted to the tongue with 3/8” grade 5 bolts using a flat washer to support the chains.
So we shouldn't worry about whether the chains actually attach to the new trucks . . . ?
Old 11-17-2017, 10:26 AM   #46
k
I prolly misspelled a few words and missed a comma or two also. LOL
Old 11-17-2017, 10:46 AM   #47
Retired JSO's Avatar
No I didn’t say not to worry. The thread is about fussing on chain attach points to the truck. I didn’t disagree but if most will look at their rigs, the majority of chains would break off the trailer anyway due to such shoddy design.
Retired JSO is offline   Reply With Quote
Old 11-17-2017, 10:56 AM   #48
3/8 gr5 bolt shear strength is over 6000#.
Old 11-17-2017, 04:16 PM   #49
Never had a problem with my 2003hd Chevy, so the guy from Ford must still be looking for a job.
I always start the hook at the bottom and clip it upwards and it fits just fine.
willykel is offline   Reply With Quote
Old 11-21-2017, 06:42 PM   #50
ID:	156943Click image for larger version
I had the same problem with the 20K receiver. I figured this out on Sunday. When I went for a trial run with the new truck. Went to my local Northern Tool and picked up these larger hooks. Work pretty sweet. Headed out tomorrow for the long weekend.
2017 Silverado 3500 D-Max Crewcab 4x4 2014 Hemisphere 272RLIS
rockertom is offline   Reply With Quote
Old 11-21-2017, 07:26 PM   #51
2007 WildCat 32QBBS
18CrewDually's Avatar
Looks like a permanent solution to a temporary problem. Safe travels.
18CrewDually is offline   Reply With Quote
Old 11-21-2017, 07:35 PM   #52
TwoMile's Avatar
I've found that on most hooks all I've done is to cut or grind the "keeper" latch down a bit and it will fit fine for both 3/8 and 5/16 hooks.
2022 F350, DRW, Lariat Ultimate, CCLB, 4x4, 7.3, 4.30
2023 Rockwood Ultra Lite 2720IK
2005 Four Wheel Camper - Grandby
TwoMile is offline   Reply With Quote
hitch, safety
