Old 08-01-2022, 11:04 PM   #1
Safety chains not welded on trailer.
I just wanted to give everyone a heads up and to check your rigs. We bought a new FR Cherokee 26BRB in 2021. It is stored inside and used in the summer.
Just a few weeks ago I unhooked at a CG and forgot to unhook a chain. Pulled away from TT in 1st gear at maybe 3mph. Trailer never moved an inch, wheels loosely chalked at the time. Chains broke free from tt with zero accelerator force. On closer inspection the piece of steel holding the Chains was only tack welded. Fortunately a local welder would come to cg to make the repair.
ID:	277332   Click image for larger version
Cairns is offline   Reply With Quote
Old 08-01-2022, 11:46 PM   #2
bikendan's Avatar
Yep, Lippert Industries at their finest.
Old 08-02-2022, 05:46 AM   #3
Oaklevel's Avatar
Can't tell by your picture but it looks like a link of the chains broke where it was "tack" welded to the frame? The whole area does not look good but I am not 100% sure what I am looking at.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 08-02-2022, 06:12 AM   #4
Mopar Guy
it was more than a tack weld, part of the loop stayed, so the loop it self fatigued and broke.
Also appears that it has been failing for a while, only about 1/4-1/3 of the break is fresh, the top 2/3 of that is rusty and fractured, and therefore happened previously.
Dave
2019 Grey Wolf 24JS- sold
1998 Holiday Rambler Imperial 41wds
Cost4133 is offline   Reply With Quote
Old 08-02-2022, 06:25 AM   #5
That is a whole lot of rust for a 2 year old trailer that is stored inside and only used in the summer. What part of the country do you live in?
Glad it did not happen on the road at highway speeds.
Keith
Rockwood 2021 2104S MiniLite
2004 Buick Raineer AWD
Tailwindpilot is offline   Reply With Quote
Old 08-02-2022, 06:31 AM   #6
What he said...
looks like a fatigue point failure....
whatever they BENT to make the connection point for the chain failed.
the weld to the frame is good.
when they bent that attachment point it stressed the metal and it only took a short while for it to fail ............ 2021 build ?
whats worse is the amount of rust on such a new frame ... that has been stored inside?
I'm... going to go out and check my frame
on a 2022... only used twice but stored outside
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
Old 08-02-2022, 06:47 AM   #7
That is a lot of rust for such a new trailer, even for up north. Maybe they followed one of those liquid salt trucks the whole way from the factory.
22 Freedom Express 257BHS
19 F-150 3.5 Max-Tow
fipntdot is offline   Reply With Quote
Old 08-02-2022, 06:54 AM   #8
GravelRider's Avatar
Yikes. The weld looks okay and was not the failure point. The link itself was. And as was already said, it was already previously stressed and ready to break at any point. Good thing you made this little mistake, as it could potentially save you a lot bigger headache in the future if you were ever to have a failure of the hitch.
Was it this rusty when you bought it? I've got a '21 Cherokee with closing in on 150 nights camped that is stored outside, and occasionally camped in during the winter, and it has nowhere near the amount of rust that yours has. And I live in a mountainous area of Pennsylvania that has ample salt on the roads from Nov-Apr.
GravelRider is offline   Reply With Quote
Old 08-02-2022, 06:54 AM   #9
Safety Chains
Looks as though there is an old fracture on the top half of the links as evidenced by the rust. The lower part of the links shows fresh metal fractures.
And yes, that rust indicates the frame needs a good wire brushing and a fresh coating of rust preventing paint.
Bob
Bob K4TAX is offline   Reply With Quote
Old 08-02-2022, 02:33 PM   #10
I'm not a metallurgist, nor a tribologist or mechanical engineer, but I used to work with them. They taught me that metal under stress will corrode (rust), even stainless steel. One form is called fretting.
The rust does not necessarily indicate exposure to weather. Continued stress and progressive breakage could have caused it.
(It's even possible that too-short chains could have been repeatedly stressed on tight turns.)
Larry
Larry-NC is offline   Reply With Quote
Old 08-02-2022, 02:43 PM   #11
Bob
EXACTLY, this metal had been stressed from a downward force. The parent metal failed the weld did not break.
Northern Indiana
2018 Salem Cruise Lite M-241QBXL
2018 GMC Canyon Denali
Rick the Rocket is offline   Reply With Quote
Old 08-02-2022, 02:53 PM   #12
D W
D W's Avatar
X3. The amount of rust is an eye catcher. A wire wheel, rust check and some paint are in order.
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 08-02-2022, 03:05 PM   #13
Great point. I do wonder if the chains were too short.
OP, have any pictures of the hitch and chains while connected prior to this happening?
Old 08-02-2022, 03:14 PM   #14
For the rust, just spray it with Ospho. I love that stuff. Keeps my truck and trailer rust free. Just don't let it drip on the driveway.
2015 Chevy 2500HD 6.0 4x4 CC SB
2021 Salem Heritage Glen 290RL
Andersen Ultimate
1200W solar > 412 Ah LiFePO4 > Victron MultiPlus II > Cerbo GX
corn18 is offline   Reply With Quote
Old 08-02-2022, 03:21 PM   #15
I have to agree with everyone else and conclude the weld held, the metal didn't.
I also agree with Larry, looks like the chains were too short and have been pulling/fatiguing those links for some time. Or... you've pulled away before with the chain(s) still attached as you did this time when it broke. Even part of the front frame tube cap is bent where the link was stressing it.
And for whatever reason... it sure is rusty for such a new unit kept inside. I've got a 5+ year old unit that does get used at times on salted, winter roads and the frame isn't in that bad of shape.
Days Camped: '17=38 '18=49 '19=58 '20=110 '21=116 '22=95
Old 08-02-2022, 03:45 PM   #16
Thank you all for the replies. Yes the trailer is stored inside, we live in SD and get some snow but, we don't use the trailer when it is snowy. The chains are long enough, and do not drag but any longer and they may. The link that I am holding is the metal used to weld the chains to the trailer frame. The rust is more than I would like.
Old 08-03-2022, 06:50 AM   #17
As said before, this amount of rust is unusual, especially for a year and a bit old trailer. None of our trailers we've owned have been stored inside, and none have that much rust. The only one with a similar amount is a 16 year old flat deck that has seen a lot of gravel over the years.
The link is not tacked on. It is welded and has been failing for some time.
Camped: 2022 (Days/Nights) - 41/33
2021 (D/N) - 37/29, 2020 (D/N): 58/49, 2019 (D/N):27/20
TT: 2020 26' Hemisphere 26BHHL
TV: 2020 GMC 2500HD 4x4
glen1971 is offline   Reply With Quote
Old 08-03-2022, 07:23 AM   #18
so I went out and inspected my trailer.
the weld on the chain just passable.
I might re-weld it one day.... but will definitely keep an eye on it
Rust on my frame and coupler was minimal
some minor stuff under the coupler...
plus ... one spot in a very noticeable place front frame section near the isolation switch
anyone know of a good matching frame paint?
mine is more charcoal looking and FLAT (no gloss)
not worth chasing a warranty fix.
I will clean the surface rust off with wire brush and light sanding then re-paint.
Tarpon Springs FL
2022 Salem 24RLXL
Old 08-03-2022, 07:45 AM   #19
Before whatever paint you choose (I've always liked Rust-Oleum Industrial Spray paint) treat the surface (as mention previously) with Ospho. It's good stuff.
Rust-Oleum has a rust reformer spray but I don't think it works as good as Ospho.
Old 08-03-2022, 07:53 AM   #20
very minor surface rust in easy to get to location...
so sanding it off and a good primer will stop it dead.
can't see the need for chemical treatment for the two spots I want to paint.
Tarpon Springs FL
2022 Salem 24RLXL
safety, trailer
