The trailer may be too heavy for the truck.
What's the maximum towing capacity of the truck? The maximum allowable tongue weight with a WDH is usually 10% of that.
There are normally two maximum allowable tongue weights: weight carrying and weight distributing. On my entirely unrelated truck rated at 9200 pounds maximum towing capacity they're 600 and 920 pounds respectively.
OK, 8800 pounds max towing capacity.
But what's the maximum tongue weight with a WDH? Should be in your owner's manual. If it's 880 pounds as I suspect this trailer's 1100 pound tongue weight is too heavy for the truck even with a WDH, you're gonna overload something.
And...
8800 pounds is the towing capacity of the empty truck with only a 150 pound driver in it. Figuring on 180 for you and 120 (max) for your swimsuit model wife you're left with very little room and all that camping stuff.
All the math makes me dizzy at times which is why I invented the One Ton Rule. By this rule you need a tow vehicle with an 11,000 pound towing capacity. 8800 + 2000 = 10800 rounded up to 11,000. Which can be had in a properly -- and specifically -- equipped F150 and probably another Dodge.
-- Chuck
