Old 10-23-2021, 02:47 PM   #1
Setting up WDH on new trailer
Sorry , Another WDH question, This WDH stuff is a little confusing to me ... So anyway bought a new camper more storage in front.
Usually put the Griddle (27lbs) and Grill (28LBS)in the back of the truck, Does it matter if I put them in the front of the camper or keep them in the pick up bed "WHEN" (which is tomorrow morning) I set up the WDH for the new trailer. What would be the best route to go?
Thanks,...
smithmx47 is offline   Reply With Quote
Old 10-23-2021, 03:57 PM   #2
Put them wherever you normally put them when you use the trailer.
2021 Coachmen Freedom Express 246RKS
2020 Ford Ranger
DougW is offline   Reply With Quote
Old 10-23-2021, 08:09 PM   #3
Not enough to be concerned. After half a season of use and stocking, restocking is the time to fine tune. In the meantime close counts.
Timtation1 is offline   Reply With Quote
Old 10-24-2021, 10:36 AM   #4
Trailer. Something is going to fill that space.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 10-24-2021, 04:20 PM   #5
So True
So true 👍
Richy R is offline   Reply With Quote
Old 10-24-2021, 07:24 PM   #6
Guspech750's Avatar
I use this rack for storing our 22” Blackstone griddle and folding table. I know it is available on Camping World and Amazon websites for about $190.
ID:	264879Click image for larger version
ID:	264878Click image for larger version
Tow vehicle: 2017 Ford Expedition XLT EL factory tow package. Added towing mirrors, 10 ply tires on separate rims, sumo springs, larger rear sway bar.
2021 Cherokee Greywolf 23MK
Equalizer 1,000lb WDH
Guspech750 is offline   Reply With Quote
Old 10-25-2021, 07:48 AM   #7
Trailer rack
Attachment 264879Attachment 264878Attachment 264877
Great product. Mine carries a Honda 2200i gen and a 6 gal marine fuel tank.
Had to lose the hard side propane tank cover and replace with a soft one. Can replace propane without removing the rack. Home made pvc frame for a custom zippered cover for weather protection.
Enjoy
pdqparalegal1 is offline   Reply With Quote
Old 10-25-2021, 07:52 AM   #8
Enjoy
Do you run into any issues with vibration while using the gen? I'm considering one of these (I have the Wen 56380i, which is a bit larger) but concerned the vibration might make sleeping nearly impossible when running it with an A/C. Thoughts?
_______________________________________
2021 Forest River Surveyor Legend 202RBLE
2020 Jeep Gladiator
muttinthehut is offline   Reply With Quote
Old 10-25-2021, 08:14 AM   #9
No. Under the gen and tank is a 1” thick soft rubber mat from Tractor supply. Horse stall pad. The one with molded holes is softer and allows water to pass through easily.
Old 10-25-2021, 08:22 AM   #10
Great idea and thanks for the reply!
2020 Jeep Gladiator
Old 10-25-2021, 08:30 AM   #11
SeaDog's Avatar
Loading can change with that said on the initial setup of a WDH load your truck the way you plan to normally load it this will give you the initial measurements for the wheel wells a very important step to ensure correct weight distribution. good luck
Retired Navy
2016 Flagstaff 26 FKWS
Old 10-25-2021, 06:03 PM   #12
While you're probably well past the setup stage at this point, for future reference I store the accessories that only get used when camping (like a griddle and grill) in the TT. Things I might need at the TV when I'm not camping (like 12V compressor and emergency cones and flashers) I keep in the TV. IMHO having things handy where they get used is a higher priority than worrying about how 55 lbs of gear affects the WDH setup. Put things where they get used and then balance out your WDH.
BTW, you'll vary the load on the WDH by way more than 55 lbs just depending on whether you head out with or without fluids in the tanks.
2015 Wildcat Maxx 28' pushing a 2020 F350 6.7L
GFD47 is offline   Reply With Quote
trailer
