I have:
Tow vehicle: 2016 Sunseeker 2250 on Chevy 4500(combined brake/turn lamps)
Toad: 2012 GMC Canyon 4wd crew cab (separate brake/turn lamps)
Baseplates: Roadmaster
Towbar: Roadmaster Falcon 2
Supplemental Braking System (SBS): Demco Stay-in-play
Tail/stop wiring via diodes.
The baseplate install and brackets for the crossbar on the Falcon: All is very easy to install though it takes time. Only one 1/2" hole is need to be drilled in each side of the frame rails, otherwise the installation uses existing holes. The splash guard needed minor modifications to clear the bracket at the guard forward attachment points, and the air dam needed 2" square holes for the removable brackets.
Installing the braking system took time, and a bit of rework here and there. I mounted the operating unit under the hood in a convenient location between the air filter box and windshield washer & antifreeze overflow containers on the passenger side. The two hoses and electrical harness routing was easy & clean, along the top of the firewall to the drivers side.
The tail/brake light wiring + brake-away wiring was mounted in the license plate bracket with additional bracing, and routed to the radiator core support, where they terminated in connectors to facilitate easy bumper removal in the future, should it ever be necessary. From there, the cabling was routed to the battery breakout box/on to the connection point for the braking system, and aft to the tail/brake/CHMSL (center high mounted stop lamp) lamps.
As it worked out, I used 6 diodes, though during the setup for the CHMSL, I found the wiring bundle just before all was broken out for separate bulbs. All told, I could have done the setup with 4 diodes - Stop/CHMSL, Left turn/stop, right turn/stop, and all tail lights.
The Canyon is super easy to put into tow mode:
1) Hook up tow bar, umbilical, break-away cable, safety cables.
2) Turn on braking system via a switch on the Demco Stay-in-play "G-Force Controller" box.
3) Place the Canyon transmission in neutral, keep foot on brake, press & hold 2H and 4L buttons for about 15 seconds. When the red N light comes on, Put it in park, pull the key and hop out.
We tested the setup with a 20 mile run, including turn tests in a parking lot. The 2250 Sunseeker on Chevy has a tight turning radius, so with the motorhome steering wheel turned to the stops (full steering wheel lock), I turned about 220 degrees before my friend started holler... I had a half inch between bumpers.
Pictures & comments of the install and tests...
