12-12-2017, 03:02 PM
#21
Originally Posted by windsurfdog
And your point?
Ha! You beat me to it . There is no point......
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
12-12-2017, 03:12 PM
#22
They have the 2018 Durango as capable of towing about 9000 lbs.
12-12-2017, 03:14 PM
#23
Originally Posted by Iwannacamp
I don't think the police get all fired up on the 10% over CCC capacity... it is the 1/2T or 3/4T people towing a 12-13-14,000 lb 5er with a truck that isn't very safe. Some TVs will allow the heavier loads, but some won't. See it here all the time.
My 3/4 is more than capable of towing 13,000 lbs.
12-12-2017, 08:17 PM
#24
X2 on the 3/4
William & Sara
2012 Silverado 2500 HD DA
2014 Cedar Creek 38CK
12-12-2017, 09:34 PM
#25
Broken Toe
Absolutely missing your point...oh well...
Cause... the same people who publish that mag also makes an obscene amount of money selling 'half-ton towable' 5ers.
Publishing info that contradicts their salesmen when they say "Your F150 can tow 11k pounds, it can tow this 10,800 pound 5er no problem" is not conductive to making sales.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016 Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
12-12-2017, 10:35 PM
#26
Mine won’t. If the pin weight is at 20%(which many aren’t) then I’m at 2600# which is only 535# more than the cargo of 2065# advertised. Tow? Yes. 13,500 on tow weight and 23,500 max gross. Thus I am stuck with a lite 5er, TT or a new TV. YMMV
2017 Puma 297RLSS
12-13-2017, 09:10 AM
#27
Your statement makes it sound like TL is putting out false information. Dodge lists the 2018 Durango as having a max towing capacity of 8700# for properly equipped vehicles. If you think Dodge is being deceptive, target your comments appropriately.
Tim
I see your point though there is a definite bias inferred with the "obscene amount of money" phrase. Yes, TL, trailer manufacturers, trailer dealerships, trailer dealers, truck manufacturers, truck dealerships, truck dealers are trying to sell their wares. Some stretch the truth, some are very truthful, some care about nothing but making a sale. It's up to consumers to ferret out the truth. To imply TL is deliberately deceiving readers is a bit harsh.
2016 Microlite 21DS
2014 Ram 1500 QC 6 cyl. 8 spd.
Blue Ox SwayPro
12-13-2017, 09:56 AM
#28
My Camping World dealer absolutely would not sell me the 5er I wanted because my truck wasn't rated to tow it.
William & Sara
12-13-2017, 10:33 AM
#29
Broken Toe
It's not deception, it's omission. Bear in mind that Good Sam Inc. would have to sell hundreds, if not thousands of subscriptions to make the same $$$ as it does on one camper sale, you can see what drives them to not be totally forthcoming with that particular set of data.
Its called "Knowing what side your bread is buttered on". I can' really fault them for it. It's has a taint of being shady, but business is business.
tim
12-13-2017, 11:00 AM
#30
Phat Phrog Stunt Crew
My dealer would sell me something too heavy for my TV but would have me sign waiver saying they warned me that it was overweight.
2014 Wildcat 327ck
12-13-2017, 11:16 AM
#31
Originally Posted by cody1884
Payload of a truck varies from truck to truck depending on options, engine and trans etc. There is no way to publish an accurate pay load of every truck configuration built. It is printed on the drivers side door jam on a yellow stick. It is still owner responsibility too tow within the weight limits of his or her equipment.
X2
12-13-2017, 11:20 AM
#32
I was once told......
That for every 1000' you go up in elevation you have to subtract 500 pounds of towing capacity because of the thin air.
I also once had a truck salesman tell me the trail blazer which can tow 7500 pounds would toe my 6000 pound empty trailer. he said I be fine.
I went with the Nissan Titan with a towing capacity of 9400 pounds. It does fine going from Michigan to Florida over the Appalachian mountains but I'm not so sure I would go over the rocky mountains with this toe vehicle. Your thoughts?
Have a Jesus filled day
Greg in Michigan
12-13-2017, 11:39 AM
#33
C'mon, you expect us to believe that? Better produce some video or else it never happened!
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
12-13-2017, 12:00 PM
#34
In general publishing CCC would be about as valuable as published dry weights on trailers....it would be best case with lots of exceptions and would only be right for maybe one vehicle and the vast majority would be lower. The problem is people would use that like they do dry weights to justify towing something they likely shouldn't.
12-13-2017, 12:10 PM
#35
Broken Toe
Greg in Michigan
Not a consideration on a turbocharged engine, however...
Tim
12-13-2017, 03:47 PM
#36
Yeah, you are right. I did buy that 5er (and a new truck).
William & Sara
12-13-2017, 05:05 PM
#37
I would never expect a magazine to be able to post all of the CCC for every truck, nor did I ever mention that they should have. I was just surprised that the CCC was never even mentioned or suggested that it could be something to consider.
2016 Forest River Wildcat 314BHX
2019 Ford F-450 Limited DRW 6.7 Diesel
12-13-2017, 05:06 PM
#38
Greg in Michigan
i would - in fact I just did it this summer with my set up - My Durango has a tow rating of 7200 lbs (though I really want the new 2018 D that can do 8700 lbs LOL). I am pulling a 6000 lb hybrid camper (that is actual loaded weight not dry), the max altitude we saw was just over 11,000 ft at the Eisenhower tunnel on I70. Granted, I stayed on the interstate but was very happy with the way the Durango towed that camper up the grade and on the way down the engine braking handled the speed so well that I did not have to apply the brake hardly at all.
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Gill" 2022 RAM 2500
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
12-14-2017, 10:56 AM
#39
Originally Posted by saus
The latest trailer life magazine issued a 2018 tow ratings for most vehicles but never mentions the cargo capacity for any of them.
For some reason this magazine is still coming to my house so I look through it. The latest issue came with a 2018 towing guide. The guide first states that tow-vehicles come in various configurations such as cab size, bed length, engine types, etc. It then states that these are key components that affect tow ratings. It then states that tires, fluid coolers, and suspension are other key factors. Then the chart gives you the vehicle, engine type, and tow limit. That's it. Nowhere does it mention cargo capacity. This seems misleading to me. Many people may look at this and think that they can get a large camper because the towing guide says that the vehicle will pull it.
Just an observation that I thought was interesting. God bless. Have a great day.
Will let me jump into this and answer your question to the best of my very limited knowledge as a retired engineer.
Why? Because the SAE J2807 Towing requirements do not required the CCC for towing a trailer! Here is a article from Truck Trend that explains the test and the requirements: SAE J2807 Tow Tests - The Standard
The "weight police" do not like the SAE testing requirements because it invalidates a lot of their beliefs that have been born on the internet.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
12-14-2017, 12:04 PM
#40
I don't think anyone disputing that J2807 is a towing standard that does not take payload into account.
However, most trucks, loaded for camping and towing trailers loaded for camping, will run out of payload before they run out of towing capacity. This a fact based borne out by specifications and mathematics.
I agree with the OP. Payload should be part of the conversation about matching truck to trailer.
