Yup, it is low.
But not uncommon for a single axle TT. My Wolf Pup 16BHS CCC is only 780#.
Likely your axle is rated 3500-4000#, basically the TT GVWR minus the rated tongue weight your tow vehicle will carry.
In five years, my 3500# springs were flat. I recently replaced them with ones rated at 5K. While not technically increasing my 3877# GVWR, I’m not near as concerned about weight now.
Yes, you will have to keep weight conscious. And rarely take fresh water along.
Weight loss bonus. IF you change from standard lead acid battery to LiFePO4 100AH, 65# down to 23#. It helps to offset extra solar panels.
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 400 watts CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, SumoSprings, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
