Old 07-06-2020, 07:59 PM   #1
Retired Panpsychist
Theo's Avatar
Switch to LT Tires?
Our 2015 F-150 with 24,000 mi has the original 275/65-18 Goodyear passenger tires on it. They are nearing 5-years of service and, though they still have plenty of tread left, I am beginning to see the beginning of some very fine sidewall cracking.
So, I'm thinking of moving up to LT tires for the replacements. My gut tells me that they will add a margin of safety to our travels. However, I have been counseled by some friends that they will produce a stiffer ride; less sidewall flex I suppose.
I'm not sure that will be a concern since I recently changed the shocks to the Bilstein 4600s. They improved the ride of the truck when NOT towing, but make the truck feel a little "loose" with the TT hooked-up (compared to the OEMS). Perhaps a stiffer sidewall is exactly what I need?
Thoughts?
Theo & Carol
2007 GoldenDoodle ("Cooper")
2020 Rockwood Roo 23IKSS
2015 F-150 4WD XLT SCab, 5.0L, 3.73, 36gal, HD Towing Pkg (53A), 1,980lb Payload
Theo is offline   Reply With Quote
Old 07-07-2020, 07:34 PM   #2
Switch to LT tires.
First, the LTs will make a difference and the ride change will be negligible. I had 2016 Lariat and now a 2019 Lariat and used LT Michelins on both. Additionally, you might want to investigate "Roadmaster" suspension system. (about$500) They are essentially helper springs but because they attach on top of the leaf springs, vs around the shock, they are not activated until you put a load on the hitch. My truck still rides as comfortably as it did on day one when not towing but when towing my 5300# TT the improved stability is comforting.
Karen, Cliff (the people)
Maui and Shiloh (the Goldens)
2020 Salem Hemisphere HL 22RBHL
2019 F-150 Lariat 3.5 EB
Karbean is offline   Reply With Quote
Old 07-07-2020, 07:54 PM   #3
The difference in ride with LT tires is very, very small. The difference in handling when loaded or towing is very noticeable. Go with LT’s, I think you won’t regret it.
2020 Coachmen Mirada Select 37RB
2019 Ford Mustang
H&H Aluminum Car Hauler
Cricket RX5 Golf(?) cart
DougW is online now   Reply With Quote
Old 07-07-2020, 08:42 PM   #4
lswartz's Avatar
It depends on you. If you notice a difference in the handling of your truck when you hookup a TT then I suspect that you will notice a change. Not everyone will notice a stiffer ride or better handling on curves. You are not going to know until you try them. Hopefully you are pleasantly surprised.
2013 Rockwood Mini Lite 2109S
2010 Toyota Tundra 4WD
lswartz is offline   Reply With Quote
Old 07-07-2020, 08:56 PM   #5
st4
from south Louisiana
I just went from P to 10ply and the ride is definitely noticeable. If I had to do it again I think I would stick with the Pís
2020 Rockwood Mini Lite 2109S
2018 F150 3.5 EcoBoost
st4 is offline   Reply With Quote
Old 07-07-2020, 09:19 PM   #6
SlowrideHD's Avatar
Passenger tires have no place on a truck, in my opinion.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
SlowrideHD is offline   Reply With Quote
Old 07-08-2020, 12:40 AM   #7
dbledan's Avatar
I had P tires on my F150. It was squishy towing. When I needed tires I got LT tires. I did not notice a ride difference empty but then again I didnt think there was a huge difference when I went to a 1 ton...there was one but not huge.
When towing it felt better but not like it changed my life. I knew I did the upgrade bit it did not change too much.
dbledan is offline   Reply With Quote
Old 07-08-2020, 07:34 AM   #8
Airdale's Avatar
Switching from "P" to "LT" tires is normally approved by the vehicle manufacturer. What does your vehicle's owner's manual have to say about the switch?
A Trailer Tire Poster
Airdale is offline   Reply With Quote
Old 07-08-2020, 08:09 AM   #9
st4
I think you have to take into consideration the percentages that the truck is actually used for towing vs daily driving, which in my case is the majority of the trucks miles
Old 07-08-2020, 08:15 AM   #10
Another consideration when you have LT Tires on your 1/2 ton truck is tire pressure. The LT tires will be able to take a lot more pressure, up to 80PSI, while the P rated tires take 35PSI. I had the LT tires on my F150 when I had it at the dealer’s for routine service which included rotate and check balance on tires. The let the air down to 35 PSI because that is what the door sticker said to run. It rode fine there and the tires looked good so I ran them at 35PSI for daily driving. When I hooked up the trailer I brought them up to 70 PSI to get rid of the sidewall flex that allows sway. Bottom line: be sure to run proper pressure for the job at hand.
2019 Ford Mustang
Old 07-08-2020, 08:37 AM   #11
Originally Posted by DougW View Post
Another consideration when you have LT Tires on your 1/2 ton truck is tire pressure. The LT tires will be able to take a lot more pressure, up to 80PSI, while the P rated tires take 35PSI. I had the LT tires on my F150 when I had it at the dealerís for routine service which included rotate and check balance on tires. The let the air down to 35 PSI because that is what the door sticker said to run. It rode fine there and the tires looked good so I ran them at 35PSI for daily driving. When I hooked up the trailer I brought them up to 70 PSI to get rid of the sidewall flex that allows sway. Bottom line: be sure to run proper pressure for the job at hand.
Take a careful look at the sidewall of a P-metric tire on a 1/2 ton truck. They're usually "XL" rather than "SL" and can be inflated to 44 Psi.
On my truck the rear tires will carry @44 Psi over 1,000# more than the axle is rated for.
At 44 Psi it handles great. Most 1/2 ton trucks with E range tires inflated to 80 Psi are going to ride like trucks----'Dump Trucks.
"A wise man can change his mind. A fool never will."
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
Old 07-08-2020, 10:51 AM   #12
Retired Panpsychist
Theo's Avatar
Some very helpful responses so far. Thank you!
My OEMs are the Goodyear Wranglers with a max rating of 51 psi. I was towing at the B-pillar's 36psi, but it seemed pretty squishy after the Bilstein upgrade. Since then, I have been running at 41psi and things are better...but not where I want them to be. The OEM shocks actually felt better when towing, but the ride was a bit harsh.
About 90% of the truck's use is for towing or moving loads like mulch or empty bottles after July 4th. It is used as a driver only now and then.
The manual doesn't give any advice on moving to LT tires so I called the Ford shop. They said that LT tires are fine, but to stay with the same size as posted on the B-pillar.
Anyone have feedback on the Michelin Defender LTX M/S LT tire?
Theo & Carol
Old 07-08-2020, 10:58 AM   #13
Thoughts?
michelin ltx pricey but great..
Thomas ho is offline   Reply With Quote
Old 07-08-2020, 11:03 AM   #14
i use michelin LTX. AT2 . GREAT RIDE, WEAR , TRACTION. PRICY BUT GET WHAT YOU PAY FOR. SHOP AROUND . CHECK OUT Ecustom rim.com for great prices.free shipping no tax. Got a great price on trailer tires on rims. Delivered to house read to install. Sold used tires and rims for cash to help with new tire cost.
Old 07-08-2020, 12:37 PM   #15
Michelin LTX
Once the Goodyear Assurance OEM P rated tires were due for replacement on my 2015 Tahoe I went Michelin Defender LTX and the noticeable improvement was when towing.
SalemCanada is offline   Reply With Quote
Old 07-08-2020, 01:30 PM   #16
Tundra 2014
Tires
If you are using it as a "Truck" go w/ LT tires. The Improvement on load capacity and control exceeds any ride difference. I have use Michelin LTX tires for 20 years, 4 different sets. Great all around tires. Just make sure they say LT on the tire.The OEM's on my my truck were "P"s.
Tundra 2014 is offline   Reply With Quote
Old 07-08-2020, 01:41 PM   #17
"Curmudgeon"
Send a message via MSN to Trawlerphil Send a message via Yahoo to Trawlerphil
I agree with Doug! The issue is more of pressure than the tire. I've got Michelin load range E and I run them at 40 PSI when not towing and 70-80 PSI when towing our 9,000 lb. 5th wheel.
_____________________
TrawlerPhil
2014 Flagstaff Classic Ultralite 8528RKWS
2012 Tundra 5.7
Trawlerphil is offline   Reply With Quote
Old 07-08-2020, 02:43 PM   #18
Let me get this straight. You have a pickup that you tow a trailer with, and you have passenger car tires on the truck. And you want to know if you should put tires that are actually designed for a pickup, that tows a trailer, on your pickup?
2016 Rockwood Windjammer 3001W
2016 F150 SCREW 3.5 EB
ProPride 3P 1400
Oafdawg is offline   Reply With Quote
Old 07-08-2020, 03:00 PM   #19
SilhouettePenny's Avatar
Yup....that's my thought. If you want a super smooth ride get a car, if your are towing with a truck then put truck tires on it. Sharp turn, loaded trailer and a little wind will convince you to get truck tires, stay out of the ditch !
2017 F350 Dually 6.7
2019.5 Hathaway
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 07-08-2020, 03:18 PM   #20
Retired Panpsychist
Theo's Avatar
Yep.
Just wondering how it might feel. The p-metrics came with the truck when we bought it used. Go figure.
Theo & Carol
switch, tire, tires
