Old 10-24-2021, 06:37 AM   #1
Tire Pressure Monitoring System
Hello fellow RVers,
I apologize in advance if I am posting this in an incorrect location.
I am not a fan of the TPMS (EZ READ TIRE CAPS) that were included on my new 2022 Forest River Grey Wolf 26RR because I cannot monitor it while driving down the road.
I need a recommendation for a Tire Pressure Monitoring System (TPMS) for my new RV Trailer. I have TPMS installed on my truck so I only need them for the trailer.
I have looked at multiple brands but I am uncertain which brand to choose but the reviews are not very good.
Any recommendations would be greatly appreciate. I would like to purchase the best that I could afford, because the most expensive are not always the best.
Thanks.
danlavoie55 is offline   Reply With Quote
Old 10-24-2021, 06:44 AM   #2
Part-Time Campground Host
cboss's Avatar
I've been using TireMinder since 2017 with no problems. Change the battereis once a year. It has saved me twice. And it has good reviews!
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Craig & Cath
Days camped since 2015(retirement): 1673
cboss is offline   Reply With Quote
Old 10-24-2021, 07:23 AM   #3
Homebrew's Avatar
We’ve been using the TST system for the past two years and had no issues. One of the nice things is the monitor can be charged and used without the cord.
Another is you can program different vehicles on one monitor, so you can have sensors on multiple trailers on one monitor. Works great when having a RV , boat and utility trailer.
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is offline   Reply With Quote
Old 10-24-2021, 07:28 AM   #4
cboss's Avatar
If you end up with this one get the extender. I mounted mine on top of the LP tank cover.
Craig & Cath
Old 10-24-2021, 08:06 AM   #5
Homebrew's Avatar
X2 , the extender is important with longer rvs . The TST system comes complete with extender. We have a 5th wheel and mounted the extender in the front battery compartment.
2014 Ram 3500 DRW
Old 10-24-2021, 12:50 PM   #6
High Country Duramax's Avatar
TST. Only thing I don’t about it is not being able to all tires at once. It scrolls through them one by one.
High Country Duramax is offline   Reply With Quote
Old 10-24-2021, 01:21 PM   #7
Jeff DeRouen's Avatar
Tire Minder I10
I purchased the Tire Minder I10 about a year ago. It's currently listed online at $329 for the unit, a signal booster, and 6 transmitters. It's super easy to set up. I have a class A and use a tow dolly to carry a Jeep Cherokee, so I have the 10 transmitter unit. I don't normally have an problems with signal. The only issue that I have had with it is that you can't change any of the settings for the alarm. If the pressure in a tire goes up or down a certain percentage (I think it's 10%) the alarm will sound. My car dolly has small 8 ply wheels, so when it's hot outside sometimes the pressure will increase (which is normal for that tire) beyond the threshold limit and the alarm goes off. Besides that I've had no issues. It can monitor up to 20 tires.
Jeff DeRouen is offline   Reply With Quote
Old 10-24-2021, 02:47 PM   #8
I have TST system on my class C coach. Scrolling thru TP and Temp is not an issue because system will sound immediate alert when there is a blowout (I know from experience). If you already have a system on your truck I suggest checking to see if it is expandable by just adding sensors to your trailer.
The2002Wanderer is offline   Reply With Quote
Old 10-24-2021, 03:17 PM   #9
TST for me. I’ve been using it about a year and saved one tire already. It scrolls through all the tires rapidly, about 3 seconds per tire. Fully adjustable for both upper and lower limits and the repeater is easy to install and use. No downside at all.
medalguy is offline   Reply With Quote
Old 10-24-2021, 03:53 PM   #10
X2 on TST. Had the flow through sensors for maybe ten years, on two different units, and the peace of mind they provide is great.
Rich Phillips
Rich Phillips
2019 K-2500 Duramax Crew Cab
2014 Silverback 33RL
richp is offline   Reply With Quote
Old 10-24-2021, 05:05 PM   #11
clanthon is offline   Reply With Quote
Old 10-24-2021, 06:33 PM   #12
Clanthon, what's the question?
Rich
Rich Phillips
Old 10-24-2021, 07:40 PM   #13
JMike.VA's Avatar
TMPS
This is what I use and very satisfied.
JMike.VA is offline   Reply With Quote
Old 10-24-2021, 07:50 PM   #14
I have a TST 507. Have for three years. They work what ever brand you choose. Caught two blows and just a month ago caught a screw in tire. Saved a blow out which would have caused lots of damage. Easy to cause 4 G in damage on a camper. Had time to slow down and get off road. Do your research and choose the one with features you like. I installed metal valve stems to stop the whipping of stem.
831 BHDS Flagstaff 2015 is offline   Reply With Quote
Old 10-24-2021, 07:53 PM   #15
I see you have a 2020 Silverado 1500. Does it have the advanced trailering system? If it does, all you need to do is get the sensors and you can monitor trailer tire pressure and temperature on your infotainment screen.
2019 Silverado LTZ 1500 6.2L 10 Speed 3.42 Max Trailering Package
2018 Freedom Express 192RBS
2022 Highland Ridge Open Air Lite Range 17BH
AlaskaErik is offline   Reply With Quote
Old 10-24-2021, 08:11 PM   #16
Commented with thumbs up but it came out as ? ??
Old 10-25-2021, 04:50 AM   #17
Sorry but that was from the factory, not possible to connect both systems.
Old 10-25-2021, 04:54 AM   #18
Thanks but correct me if I am wrong but based on the reviews this is more of a passive system? Not a lot of great reviews.
Old 10-25-2021, 05:21 AM   #19
No, I unfortunately do not have that feature, I can only check the trailer lights.
Old 10-25-2021, 05:52 AM   #20
Gotcha.
pressure, tire
