02-10-2019, 10:05 PM
#21
If you only need 2 sensors, call Chip to make up a two sensor system for you...
https://www.greatrvproducts.com/onli...play-c27693345
If you have metal valve stems go for the flo-thru sensors... otherwise just get the normal ones.
2014 Shamrock 183
02-11-2019, 08:06 AM
#22
This is what I was looking for. I really didnt want to waste my money. I will just go with the tst and pay a little more for something that I know will work.
02-11-2019, 09:17 AM
#23
Denver To Yuma In 90 Days
I bought a TireMinder setup used from some friends that upgraded to system that covered their 5'ver and truck tires all on one system.
My 5'ver is 33-feet long and I haven't had to install the repeater antenna.
And it paid for itself the very first day I towed with it, alerting me to a low tire that had a nail in it.
02-11-2019, 03:09 PM
#24
507 x2
2016 Champagne EL38
2016 Dodge Ram 3500 DWD
02-11-2019, 03:49 PM
#25
Responses
How hard would it be not to respond to someone that you think is lazy. What would you say to your waitress after you ask her for a pepsi and she responded did you read the menu. We only serve coke.. Bet her tip would be zilch.
Retired Air Force
Side Kick: Karma
Tipp City, Ohio
02-11-2019, 04:19 PM
#26
Georgia Rally Coordinator
TST 507 here. Bet bang for the buck. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
02-11-2019, 04:21 PM
#27
Originally Posted by Wifshowfur
Has anyone found an affordable tpms that works well for a tt. If so what kind do you have? Thanks to everyone in advance.
Since you only seem to want an answer... here it is... TST 507.
02-11-2019, 04:24 PM
#28
You dont know me and I am not a waitress.
02-11-2019, 04:32 PM
#29
TST 507 for last 6 years or so. No TPMS on my TV so over time I added 4 more. It has more than paid for itself in alerting me to pressure loss in tires that would have tore up the side of the trailer. Had that happen 2 times before DW said I could spend the money. Never know when you may pick up a nail.
Looking in my crystal ball, I see a lock in this threads future.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
02-11-2019, 04:35 PM
#30
Wfishowfer - Maybe the Admin will stop the negative responses, sorry, hope you got what you needed. All they have to do is unsubscribe from the thread.
2016 Champagne EL38
02-11-2019, 04:55 PM
#31
To Admin....
How about putting a sticky up front on each forum on how to use Search. Try putting in "best TPM" or "Tire pressure monitor" in search. What you get is 490 responses that most are useless. If members are going to suggest using search tell them how to best use it.
Best....
2016 Champagne EL38
02-11-2019, 05:56 PM
#32
Thanks to all. I am still learning this forum stuff.
02-11-2019, 07:11 PM
#33
Wifshowfur, I for one welcome you to the forums. There is a lot of good help in here but some feel you should be a well informed RVer and well versed in how the site works before you buy your first RV or ask your first question.
The biggest percentage are here to help each other out.
02-11-2019, 09:56 PM
#34
I like TST 507, probably a lot of campers choice on here. I have had mine for probably ten years. I have a color monitor now plus the monochrome one. The color unit works best for me just hard to get used to the psi being on the right side after all the years of the psi being on the left side. Mike Benson is on this site a lot to answer any questions and he is easy to call
02-11-2019, 10:01 PM
#35
Google great rv products they are normally the cheapest around for the TST plus most people take the locks off as it makes the sensors lighter and you can use regular valve stems.
