Tire Temp?
I thought the question was about RR tire temperature.
IMO as a Tire Engineer, If your temperature is increasing 10F then I would expect your tire pressure to increase 2%
Now if you are running an external TPM sensor screwed onto a metal valve stem then a big driver of the temperature reading is the temperature of the metal wheel rather than the temperature of the air in the tire. If you have a brake or bearing heating up it will heat up the wheel.
Those items would be what I would check before getting all tied up in a knot with tire pressures, assuming you have an accurate digital tire pressure gauge and the TV tires were set the same RR & LR then unless there was some significant change in tire pressure, which you said there was not, I would not worry about inflation till you figure out why the wheel is getting hot.
.Write a blog on RV tire application RV Tire Safety. 48 years experience as tire design & forensic engineer. My RV Freelander 23QB on Chevy 4500 chassis. Giving seminars on RV Tire applications (not selling)@ FMCA Conventions. Mar 20-22 Tucson AZ
