In tow/haul mode, probably the same no matter what the brand of truck, the gears hold higher to help you out with your load. I don't know what the RPM's are for that truck, but in the gasser Fords, the RPMs would get up to over 4000 when under load (or in Tow/Haul). That engine would scream. But it is designed to do just that, as that RPM range is where the truck gets its power. So I would research your engine/tranny combo, see what the RPM range is for its max rated power, and go with it. It does take some getting used to it, for sure.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Retired AF MSgt
