Old 08-16-2020, 09:25 PM   #1
nvs4602's Avatar
To grease or not to grease?
How many people put grease on the ball hitch? I have always greased mine before I use it to save on wear and tear., and I think it makes backing a trailer easier.
I see a few people who never grease theirs.
What's your all thoughts on this.
nvs4602 is offline   Reply With Quote
Old 08-16-2020, 09:27 PM   #2
jay2703's Avatar
It depends on your hitch. Anderson WDH's don't need grease. The ball turns with the trailer.
2011 Rockwood Mini Lite 1809S
2013 Rockwood Ultra Lite 2304S
2004 Dodge Dakota SLT+ 4.7
2012 Ford F150 FX4 3.5 EcoBoost
jay2703 is offline   Reply With Quote
Old 08-16-2020, 09:33 PM   #3
Lets go camping!
str8t six's Avatar
i grease mine
2014 Rockwood Mini Lite 2504s
2016 Ram 3500
str8t six is offline   Reply With Quote
Old 08-16-2020, 09:35 PM   #4
Platokidd's Avatar
Originally Posted by str8t six View Post
i grease mine
X2
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
R.I.P. Luke the campin dog
Old 08-16-2020, 09:48 PM   #5
i grease mine
X3... when we had a trailer.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 08-17-2020, 04:43 AM   #6
Chris Pastuzyn's Avatar
Absolutely grease mine ,Keeps every thing moving free.
Chris Pastuzyn is offline   Reply With Quote
Old 08-17-2020, 05:52 AM   #7
I grease.
2018 F 150 Supercrew 6.5 bed 3.5 EB Max Tow
Jfkmk is online now   Reply With Quote
Old 08-17-2020, 07:06 AM   #8
Head Rambler
I never grease the connection.
When we had bumper pull trailers I used wax paper on the ball to lube it. Keeps the mess down and doesn't attract dirt/grime. We moved to a fifth wheel with a conventional hitch and I used the teflon plates, then we got an Andersen Ultimate, and they state in the literature NOT to use lube. And that is right up my alley.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 08-17-2020, 07:25 AM   #9
Always greased the ball on my truck when pulling large boats and travel trailers. Now with the 5th wheel I use the teflon plate but would grease it otherwise.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
mwdilday is offline   Reply With Quote
Old 08-17-2020, 07:47 AM   #10
larry2c's Avatar
I use grease now but back in my early and not so experienced days I didn't think I had to. When I saw the hitch had worn through the chrome on my ball I figured I had it wrong and been greasin' up ever since.
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Two shedding mutts
larry2c is offline   Reply With Quote
Old 08-17-2020, 09:49 AM   #11
NMWildcat's Avatar
We rarely, if ever, use grease for the many utility trailers on the farm. If you grease, you also have to ensure you clean the old grease out of the coupler and off the ball after it's been sitting, otherwise you have created sandpaper.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 08-17-2020, 10:07 AM   #12
Grease, here.
katkt is offline   Reply With Quote
Old 08-17-2020, 10:35 AM   #13
NMWildcat's Avatar
This tells me you had a cheaper chrome plated ball. The good ones rarely do that, grease or no grease. Wish I could remember the specific one we use, but we just tell the hardware store guy we need so many of the good balls (small town).
Old 08-17-2020, 11:27 AM   #14
Thurman's Avatar
Grease, sort of. I use a spray white (lithium) lube on the ball at each use whether the TT, the cargo trailer, or utility trailer. I use paper towels to clean the ball after each use also. Just my way, , ,
2015 FR Freedom Express 310BHDS pushing a 2014 GMC Sierra CC
Thurman is offline   Reply With Quote
Old 08-17-2020, 11:58 AM   #15
Grammar Pedant
67L48's Avatar
I grease. The tolerance of my hitch & ball is razor thin. If I don't grease, it takes an almost perfect positioning for my trailer to let go of the ball. It's tight. So, grease is an absolute must for my use. Even with grease, I often have to plead and coax my trailer to let go of the ball.
As mentioned, you have to maintain the grease so as not to create a mess of dirt, grime, and abrasives up in the business part of the hitch and its locking mechanism.
Former RV: 2018 Rockwood Mini Lite 2504S
67L48 is offline   Reply With Quote
Old 08-17-2020, 12:23 PM   #16
Son of a Machinist
My Father was a machinist and tool and die maker. I think he'd come down and haunt me if I didn't keep things properly lubed up.
Arizona Mike
Flagstaff 21FBRS
Jeep Grand Cherokee
Equal-I-Zer
Arizona Mike is offline   Reply With Quote
Old 08-17-2020, 01:08 PM   #17
B and B's Avatar
Grease on balls and pins. Always! As stated you need to make sure old grease is cleaned off once and while.
Old 08-17-2020, 01:31 PM   #18
I greased mine at first but later realized it did fine without it. NMWildcat explained it well. In addition the grease makes a mess if you brush against the ball.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is offline   Reply With Quote
Old 08-17-2020, 03:32 PM   #19
Cover the mess
We grease the ball, then while unhitched, I slide a sandwich baggie over the ball. No grease on my legs while walking between truck and trailer.
Tim & Angi
Bailey & Jasper, Mini Schnauzers
2019 Patriot Edition 27RR
2012 2500 Ram Diesel
2016 Harley Ultra Limited CVO
akdj1129 is offline   Reply With Quote
Old 08-17-2020, 03:43 PM   #20
I use this 3M product. Wipe it off once I'm at camp.
https://www.3inone.com/products/trailer-hitch-grease/
Gary
Get out and have a good day on purpose cause everyday on this side of the grass is such a great time.
Nothing lasts forever, So live it up,laugh it off, take chances, & never have regrets, because at one point, everything you did was exactly what you wanted.
GlowPlug is offline   Reply With Quote
