Old 01-23-2020, 08:53 PM   #1
Toad Lights in Addition to Dolly Lights
I tow with a dolly and was thinking that, for extra safety, it might be good to have lights on the toad that work with the dolly lights. Those dolly lights make you legal, but I think people are more used to seeing the lights on a vehicle activate.
Does anyone have this concern? And what was your solution?
I have thought about running a pigtail to some additional lights on the toad.
2011 Sunseeker 2860
2006 Honda CR-V
PoppySteve is offline   Reply With Quote
Old 01-23-2020, 09:10 PM   #2
dbledan's Avatar
Buy a truck light bar look for 48". Add a magnet to stick the truck lightbar to and you are in business as long as its not an aluminum body. You could stick it directly to your towed and leave it there as well. You may want a shorter tailgate light bar depending on what you stick it to.
https://www.amazon.com/dp/B07Z3PTB99...X.KkEbYRFEB4T*
https://www.amazon.com/dp/B07PTSW1M9..._igLkEb25D48FK
If you don't like to wire things get a Y adapter for your trailer lights and some extension wire for trailer lights.
https://www.amazon.com/dp/B01JCT84XY..._ZdLkEb69HG0ZY
https://www.amazon.com/dp/B07JMZNQ7Z..._qhLkEbSKZWWVT
For $50ish not a bad deal.
dbledan is online now   Reply With Quote
Old 01-23-2020, 09:42 PM   #3
Great links, thanks! Sounds like you have had the same idea.
2011 Sunseeker 2860
2006 Honda CR-V
Old 01-23-2020, 10:08 PM   #4
dbledan's Avatar
I put some on my cargo carrier for better visibility. I should have put them on my TT but swapped the light housing instead...lots more work. They have also gotten a lot cheaper in the last few years.
After looking at your towed I would say look for 48" truck tailgate light bars. 60" will wrap around your CRV. At 48" you can put them in the back window.
Old 01-24-2020, 01:49 PM   #5
RudysWorld's Avatar
I used a 7 pin y adapter and lights that attach to trunk lid or lift gate. Good Luck.
Rudy - 10 year old long haired dachshund, RIP
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
RudysWorld is offline   Reply With Quote
Old 01-24-2020, 02:19 PM   #6
Consider the 7 pin Y adapter plus this: https://www.amazon.com/ABN-Wireless-...9893505&sr=8-7
I use these lights on my Toad.
McCormickJim
2017 GT 31L5
McCormickJim is offline   Reply With Quote
Old 01-24-2020, 02:21 PM   #7
My motorhome has the 7 pin round connector. I wired 2 (two) flat 4 wire trailer light pigtails into the 7 pin male plug. One is for the dolly lights and the other is for a extra set of lights I mounted on the rear shelf of my 2009 Hyundai. I bought a good led magnetic light kit and have them tie wrapped to the shelf by the rear seats headrest. We just run the wire out the door,then under to hood and connect at the plug. I tried the cheap harbor junk magnetic kit, But the the wires are so tiny and delicate they were always a problem.The dolly lights work fine but being so low and way up front they are hard for others to see. When not in use we just coil the wire and lay it on the shelf
Mark1 is offline   Reply With Quote
Old 01-24-2020, 04:35 PM   #8
Dolly lights are NOT the only lights you need to be legal unless they are within 3' of the back of the towed vehicle. Glad you are looking at solving the issue. Make sure your set up includes tail, stop, and turn signal lights.
Dirt Sifter is offline   Reply With Quote
Old 01-24-2020, 04:54 PM   #9
jk510's Avatar
I tend to go overboard on stuff like this and here's what I do.
My motor home has both 7 pin round and 4 pin flat connectors. The 7 pin, of course, goes to the dolly. For the 4 pin I have wired a connector on the car to the car's lights using a diode set from etrailer.
It takes some time to set it up originally but I have lots of lights!
Joel K
Southeast AZ
2013 Coachman Mirada 29DSSE
jk510 is offline   Reply With Quote
Old 01-26-2020, 01:42 PM   #10
While considering your options, think LEDs so as not to overload a fuse. LEDS are also brighter.
PenJoe is offline   Reply With Quote
Old 01-26-2020, 02:10 PM   #11
Kanadian Kamper
kenandterry's Avatar
With lights at the rear of your toad, your legal in all states and provinces.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
light, toad
