01-10-2022, 08:02 AM
#21
I have a Sherline LM-2000 that I use on my 2021 Vibe 21BH (tongue weight = 940lbs).
The Sherline works great.
-Russ
Russ & Arlene
Yulee, FL
2021 Vibe 21BH (sold)
2019 F150 Screw, 6.5 bed, 3.5 Twin Turbo EcoBoost
w/ Trailer Tow Package - Yellow Sticker Payload : 1810 lbs. (sold)
01-13-2022, 09:24 AM
#23
I have a shurline goes to 2000 ready for sale . used it when setting up Th got my TW and never used it again .
01-13-2022, 09:49 AM
#24
The shurline is the one where you have to take off the ball mount part of your hitch and put this one on instead?
And you're selling it? How much would you be asking?
01-13-2022, 10:02 AM
#25
Originally Posted by dsjohns71
Dsjohns, have you weighed your setup to see how accurate the WeighSafe hitch is?
2022 Rockwood Roo 235S
15kBTU AC; 12v fridge; 1kW roof-mounted solar panels; 80 amp MPPT charge controller; 3,500w pure sine wave inverter; 30a automatic transfer switch; MicroAir EasyStart, 600ah Chins LiFePo; Honda EU2200i (with Hutch Mountain propane conversion kit) gathering dust in the storage unit.
01-13-2022, 10:08 AM
#26
I've used the Sherline scale for 20 years and found it invaluable for setting up trailers (plural). Once the camper is set up the scale is dormant so $120 for a one-time use is rather steep. I loan this to buddies all the time.
Loading U-Haul trailers for various moves has become the current use. Unlike camper trailers there is an almost infinite number of ways to load the trailer and it takes me a bit of trial and error go get the weight and balance right on these.
Most measuring devices are most accurate at the mid point of their scales so a 2000 pound scale is what I have on mine since my tow vehicle has a maximum load of 920 pounds. The pressure gauges are interchangeable.
-- Chuck
01-13-2022, 10:30 AM
#27
Another option is the Curt BetterWeigh blutooth system, I bought it when it was called Haulguage. It's same tech that the new trucks have on board for doing weights.
2020 Rockwood 2104s towed by 2018 Nissan Armada. Curt WDH with sway, portable 150 watt solar, Home made window evaporative cooler
01-13-2022, 10:32 AM
#28
No just use some cribbing/blocking to get the scale plunger under the hitch cup and lower it down.
2019 F150 4X4 7050 GVWR 1903 payload
2018 Avenger 21RBS 7700 GVWR
01-13-2022, 10:41 AM
#29
54 Years, 13 RV's
Originally Posted by DougW
The shearling LM2000 is the same price as the 1,000. Might as well get one that will work on the larger trailer you may but in the future.
Yes. My 2511s can vary from 900 to 1100, so a #2000 Sureline is the best option. That puts common tongue weights in the middle of the gauge range, which is most appropriate.
2021 Rockwood 2511S
2020 GMC 1500 6.2L
01-13-2022, 10:46 AM
#30
54 Years, 13 RV's
Originally Posted by NavyLCDR
I have this (but the earlier version "hitch haul"):
https://www.curtmfg.com/betterweigh
It is surprisingly accurate, within 20-40 lbs of actual weight when weighed on a real scale. I really like it because it not only gives me a very close approximation of tongue weight, but also tells me how well my WDH is set up.
I have it, too and the numbers it provides are very close to actual scale numbers.
It's a bit of a PITA to set up the first time.
2021 Rockwood 2511S
2020 GMC 1500 6.2L
01-13-2022, 10:47 AM
#31
to do correctly you set up scale the same height as your hitch using blocks then lower tongue on scale . $75
01-13-2022, 10:52 AM
#32
54 Years, 13 RV's
Originally Posted by Cdj8465
Looks pretty handy and versatile. I would certainly consider it.
I put my Sureline on top of the floor jack and roll it under the hitch. Jack it up till the foot lifts off the ground and read it. Did this as the last thing before hitch up.
2021 Rockwood 2511S
2020 GMC 1500 6.2L
01-13-2022, 10:53 AM
#33
54 Years, 13 RV's
Or floor jack.
2021 Rockwood 2511S
2020 GMC 1500 6.2L
01-13-2022, 10:56 AM
#34
54 Years, 13 RV's
This is some kind of a good record. 33 posts and nobody has been crabby with each other!!!!!!
2021 Rockwood 2511S
2020 GMC 1500 6.2L
01-13-2022, 11:12 AM
#35
I can't find any information on a ' Shurline' tongue scale? Did you mean a ' Sherline' Scale like many have referenced in this thread?
-Russ
Russ & Arlene
Yulee, FL
01-13-2022, 11:16 AM
#36
-Russ
yea sherline
01-13-2022, 11:17 AM
#37
Originally Posted by Johnfort
Or floor jack.
X2
-Russ
Russ & Arlene
Yulee, FL
01-13-2022, 11:51 AM
#38
My Sherline scale came with a screw in extension to fit in the coupler. They may all include this.
-- Chuck
01-13-2022, 06:01 PM
#39
As noted, there is only one Sherline scale. You can unscrew one guage and screw in another. Been there done that when I went from a 19ft trailer to a 34 ft trailer.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
01-13-2022, 06:36 PM
#40
Or floor jack.
I like that idea better
