With that much weight I would most certainly want brakes. I would prefer surge brakes, they are normally easiest to use because they adjust their intensity based on the weight and rate of deceleration all by themselves. They normally can not be activated from the driver’s seat of the tow vehicle but that is not normally needed anyway.
Electric brakes are more prone to need maintenance and if you are towing the dolly without the car on it you will need to adjust the controller down or you will be sliding the tires every time you touch the brake pedal in the tow vehicle.
(Previous) Coachmen Mirada Select 37RB
(Previous) Coachmen Freedom Express 246RKS
(Current)2022 Grand Design Reflection150 226RK
2022 F150 Powerboost Hybrid.
