Old 07-26-2019, 03:28 PM   #61
Usually Confused Member
emm-dee's Avatar
Originally Posted by babock View Post
They have mountains in Tennessee?
They’re hidden under the trees.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
emm-dee is online now   Reply With Quote
Old 07-27-2019, 09:11 AM   #62
Big difference
The tow/haul mode lets your computer know there is a potential heavy load and compensate accordingly and will usually lock out overdrive automatically. There is a big difference in downshifting and motor braking. Downshifting only causes the transmission to over-rev and overeheat. Our 2013 GMC 2500HD with 6.0 liter gas and 6 speed tranny uses motor braking. We live in the flatlands of Florida. The first time I tried it was traveling through Georgia. As long as the cruise control is set when you start down a large grade, the motor will activate its internal valves and sound like a semi on an offramp. It works great and reduces the need for braking.
tccommish is offline   Reply With Quote
Old 07-27-2019, 09:14 AM   #63
DouglasReid's Avatar
Im confused, are you saying you do not get any compression braking from your engine when you downshift?
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 07-27-2019, 09:16 AM   #64
Blackrock's Avatar
What 'Motor' do you have that can activate internal valves?
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 07-27-2019, 09:22 AM   #65
There is some compression from taking your foot off the gas. There is no comparison to the increase of backpressure on a motor braking system.
Old 07-27-2019, 09:33 AM   #66
Mr. Dan's Avatar
There seems to be some Heavy Duty guessing going on here. My '14 GMC 6-spd does NOT lock out overdrive with the Tow/Haul mode ON. Its two highest gears are OD and both are active with Tow/Haul ON.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 94; booked = 14
Old 07-27-2019, 10:22 AM   #67
emm-dee's Avatar
Originally Posted by Mr. Dan View Post
There seems to be some Heavy Duty guessing going on here. My '14 GMC 6-spd does NOT lock out overdrive with the Tow/Haul mode ON. It's two highest gears are OD and both are active with Tow/Haul ON.
Same thing with my 2018 Ford V10, 2017 Ram dually with CTD and previous ‘14 Ram 5.7 and ‘18 2500 CTD. They’re all a little slower to engage OD with tow/haul engaged but they all get there.
Old 07-27-2019, 11:30 AM   #68
Blackrock
Originally Posted by Blackrock View Post
[/COLOR]
I will admit I was wrong. Eric H explained it pretty well.
Here is an explanation of the Jacob's brake that does incorporate a valve. No, my vehicle does not have a diesel.
What is an engine brake?
The Jacobs Engine Brake® (also known as the "Jake Brake®") is a diesel engine retarder that uses the engine to aid in slowing and controlling the vehicle. When activated, the engine brake alters the operation of the engine's exhaust valves so that the engine works as a power-absorbing air compressor. This provides a retarding, or slowing, action to the vehicle's drive wheels, enabling you to have improved vehicle control without using the service brakes*.
Old 07-27-2019, 11:36 AM   #69
Mr. Dan's Avatar
Sir, I commend you!! We have many wrong statements on this forum but very few will acknowledge being wrong. Peace!
Old 07-27-2019, 12:20 PM   #70
Blackrock's Avatar
I have never done any Jake brake work on a Detroit engine but I have done a lot of Cummins, Mack and Caterpillar engine work. After emissions became an issue there was a lot of redesign work done with Cummins and Mack coming out with their own systems to work in conjunction with variable vane and waste gated turbos. These are all on their heavy truck engines.
All of the light truck diesels are using a type of exhaust brake in conjunction with some transmission retarding.
Gas engine trucks are using variable valve timing and transmission retarding by throtteling line pressures.
Old 07-31-2019, 09:39 PM   #71
Originally Posted by Papadave View Post
Growing up in the mountains of Tennessee we used to shake our heads at the flatland tourists on the side of the road with their brakes on fire. I do worry about downshifting when she spins up to 3,500 rpm or more and brakes are cheaper than trannys but when the brakes overheat and fade out on a downhill you are out of options. Last week in North Carolina I saw my first tractor trailer at the far end of a pea gravel runaway ramp. Glad he was ahead of me.
Yikes
myxkp is offline   Reply With Quote
Old 07-31-2019, 10:17 PM   #72
My2014 Silverado 1500 has a vacuum pump driven by the engine to operate the power brake booster. Why? I suspect that when I let off the gas pedal, especially in 6th gear the computer cuts off fuel and opens the throttle blade for the fuel economy test. Perhaps in tow/haul mode the blade is closed when the transmission downshifts for more engine braking. It’s also possible that the torque converter is locked up when the engine braking is activated. I’ve never really tried that feature as I usually don’t engage tow/haul and just shift manually. Jay
2016 Rockwood 2504s.
TV: 2014 Silverado 1500 double cab.
Jay2504 is offline   Reply With Quote
Old 07-31-2019, 11:24 PM   #73
SailorSam20500's Avatar
While in T/H and cruise on, my 2018 F-150 has gotten into 10th gear. As I recall, I was in the flats of Ohio and had a tail wind....
Al
Save the Earth. It’s the only known planet with Beer.
There are times where my greatest accomplishment is keeping my mouth shut...
S.E. Mich. Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 08-01-2019, 10:39 AM   #74
frank4711's Avatar
Just got back first trip with any hills (Tenn/north GA) pulling beast of 5th wheel (now sold) with my grocery getter .... in tow haul on my new 2019 Ram it worked great just a tap of the brake and engine down shifted slowed us nicely. I was surprised how well the 5.7 pulled up the hills not screaming but a strong low pull never exceeding 3300 rpms, pulled right past the semis then they would fly by down hill as I cruised at 63 ... New smaller shorter and lighter Rockwood will be here in 2-3 weeks I guess it is true when they say buy your 3rd RV first well this is #2 we hope to stop for awhile ...
Frank & Cindy--- (SOB) 5th Wheel ---2019 Ram 3500 Cummins 6.7 SRW 4x4 8' bed--- Payload 4394------Remi & Sage camping pups---TST 507 TPMS ... B&W Patriot 18K---3.73 axle ... Predator 3500---2019 48 days ---2020 28 days Camping
frank4711 is offline   Reply With Quote
gas
