Old 05-06-2021, 01:23 PM   #1
Tow Vehicle
Hi all...looking at buying an F150 with 2.7 ecoboost. I have a 178bhsk just under 4000lbs. It should pull it just fine but curious if anyone has some real input they could give??
shane030173 is offline   Reply With Quote
Old 05-06-2021, 01:53 PM   #2
I have not personally owned one, but many on here swear by them. All things considered, it probably provides as good a "bang for the buck" in towing that you can get for a half ton. As you stated, that will be more than enough to tow that camper. Seems like a great match.
2020 Ram 2500 Tradesman 4X4 14,300 max tow, 3089 payload
2020 Salem Cruise Lite 263BHXL
Equalizer WDH
FrankH35 is offline   Reply With Quote
Old 05-06-2021, 08:04 PM   #3
071567's Avatar
I had a 2015 f150 2.7 Ecoboost pulling a 35ft Gulfstream Amerilite .
I want to say it was about 6500lbs. It had great take off but if I was on the interstate,and a big truck came by me I would start to walk.
With that being said I think you will be fine. But even with the WDH/ with load levelers on it you might want to invest in some air bags for your rear end.
071567 is online now   Reply With Quote
Old 05-06-2021, 08:46 PM   #4
bikendan's Avatar
Shouldn't need airbags for a under 5000lbs GVWR TT. A good WDH with integrated sway control should take care of any possible minor squat.
The 2.7 Ecoboost F150 will be a perfect match, for your Wildwood. Just be care about the fancy bling trim levels, they'll lower payload capacity.
Old 05-06-2021, 08:55 PM   #5
071567's Avatar
Ok if you say so. That's what I thought until I got the TT. I ended up put some on and it made a world of difference. But to each is their own. Just keep the thought in the back of your mind. Good luck and have fun camping.
Old 05-07-2021, 08:23 AM   #6
You did notice that the OPs trailer would fit inside your trailer, right? Might be able to fit 2 of the OPs trailers in yours.
2015 Chevy 2500HD 6.0 4x4 CC SB
2021 Salem Heritage Glen 290RL
Andersen Ultimate
corn18 is offline   Reply With Quote
Old 05-07-2021, 01:29 PM   #7
DauntlessFox's Avatar
+1 on this - you should be fine with the 2.7 F150 and that trailer without adding bags or aftermarket parts (other than a good hitch setup). Only thing to consider might be the 2.7 Payload Package.
Definitely watch your options; I took a 104lb loss in payload between my moonroof and tailgate step alone. options do add up quick!
2020 Freedom Express 195RBS
2021 Ford F-150 XLT Powerboost 4x4
DauntlessFox is offline   Reply With Quote
Old 05-07-2021, 09:48 PM   #8
Camping the Natural State
It will definitely not do what the 3.5Eco will but lots of people use the 2.7Eco for towing travel trailers. I sure wouldn't go over 7000 gross camper weight.
2021 Rockwood Ultra Lite 2614 BS
ARhappycamper is offline   Reply With Quote
tow, tow vehicle
