Originally Posted by DouglasReid
I will not get into the debate about that particular vehicle or its suitability. What I will do is give you some practical advise.
Look at and decide what camper you want. You can also go around driving the 1/2 and 3/4 ton trucks of all the makes, see which one you like best in each weight classification. Do not make the truck purchase first!!
When you decide on a final selection of the camper, look at the weight on its yellow sticker. Add in the weight of persons clothing, cooking utensils, propane tanks, grills, chairs, etc (1000 lbs to be safe) to get the tow weight.
NOW look at the capabilities of the trucks vs the actual weight of the camper. If you are bumping up against the max of the truck's capacity, upgrade to a larger truck. You will avoid having too little truck and have a much more pleasant towing experience by doing this.
If you buy the truck first, you will have to limit the camper selection based on the trucks capabilities plus there will most likely be no room for upgrades so when you need a new bigger camper, you also need a new bigger truck
+ 1
When you buy the camper take 15% of its GVW, add 100 lbs for a WDH plus the weight of all contents - driver, passengers, dogs, firewood, kayaks, bed covers, running boards, etc added after purchase. Then add a safety factor.
When looking at campers, as a general rule smaller ones are more maneuverable and will fir most state parks while larger ones are more comfortable - especially for longer trips.
Note that the price difference between the various weight classes of of pickup trucks is relatively small when ordered new and may be non-existant when talking to a dealer anxious to move units from his lot.
Here, in SoCal, the majority of HD trucks on the used market are work trucks that have been pretty well thrashed. Caveat Emptor
