Need some expert inputs, I've been trying to figure out best way forward, how to tow my Envoy. Reading my manual under recreational vehicle towing it shows a picture of flat towing and says put transfer case in neutral and pull RDO fuse to save battery. Followed by next section 4Wheel Drive which tells you put transfer case in nuetrel . Simple, I can flat tow.
Then under Towing your vehicle section:
Your vehicle can be towed with wheel lift
or car carrier equipment. When towing with wheel lift
equipment, the transfer case must be in NEUTRAL and
the following tow limits must be used:
Towing from the front -- 55 mph (88 km/h) or
legal speed limit and distance is unlimited
Towing from the rear -- 35 mph (55 km/h),
50 miles (80 km)
So I read all 3 sections to say, I can tow 4 down, dolly or trailer. Basically the only thing to do either flat tow or dolly is put transfer case in neutral and pull RDO fuse.
I am leaning towards dolly just because I am not restricted to just towing Envoy with my 329DS without buying different adapters for other vehicles.
Do you agree, I can flat tow, dolly or trailer?
