Old 03-05-2024, 11:59 AM   #1
Towing
My tow vehicle is a 2019 ram 1500 5.7 hemi regular cab according to the literature because of the axle ratio its only rated to tow 8,500 lbs. I have a 33 foot wildwood 27 rk whose dry weight is 6700 with a payload capacity of1,000. Its been used ad a live in and I've never towed it and had begun to look into WDH s for it but now am realizing the tow vehicle may not be adequate . Wondering what anyone's thoughts might be on that. Thanks
vajra7 is offline   Reply With Quote
Old 03-05-2024, 12:29 PM   #2
You definitely will need a larger truck to tow that. That camper is three quarter ton territory. That said it's hard to believe you have a half ton truck with only 1k payload capacity. That trailer's tongue weight alone will be more than 1k pounds. Before you put yourself, your family and your gear in with it you'll be over payload already.
2024 Ram 2500 Tradesman 4X4 14,300 max tow, 3058 payload
2022 Coachmen Catalina 323BHDSCK
Equalizer 4 point WDH
FrankH35 is offline   Reply With Quote
Old 03-05-2024, 12:33 PM   #3
D W
D W's Avatar
Sorry, but that's too much trailer according to the truck.
You don't want to be this guy:
https://www.forestriverforums.com/fo...ml#post2931569
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 03-05-2024, 12:41 PM   #4
llr
What is the payload on the truck? I assume the 1,000 is on the trailer.
With a camper, truck payload is almost always the first limit hit.
2024 Artic Wolf 3018 Suite 5th Wheel
Prior TT Grand Design 2800BH TT 2021 - sold 4/24
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW Lariat Ultimate
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload - sold 4/24
llr is offline   Reply With Quote
Old 03-05-2024, 01:26 PM   #5
bikendan's Avatar
Posy a pic of the truck's payload capacity sticker.
It's on the driver's door and will say "Occupants and cargo should not exceed xxxxlbs".
What year is the Wildwood?
A WDH doesn't increase the the truck's payload capacity.
Older Ram 1500s are notorious for low payload capacities.
I'm betting that the trailer's loaded tongue weight will exceed the truck's payload capacity.
Old 03-05-2024, 01:41 PM   #6
Blackrock's Avatar
My 2016 Ram 1500 has a payload of 1820# but I special ordered it with the heavier axle and tow package. This is the low trim level but it's still got a lot of the necessities jus no chrome or leather heated seats.
Check the door sticker for payload numbers.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Illegitimum non carborundum
Blackrock is offline   Reply With Quote
Old 03-09-2024, 02:52 PM   #7
Yes the trailer ‘s tongue load is 950 not the truck even so it’s too much
Old 03-09-2024, 02:54 PM   #8
Thanks to all this was very helpful if anyone wants to buy this one or swap for a 178bhk I’d appreciate it!😂
Old 03-09-2024, 03:45 PM   #9
bikendan's Avatar
That 950lbs number is a fictional DRY tongue weight. It doesn't include the weights of batteries, factory options, dealer add-ons, water and trailer cargo.
It may also not include the weight of propane, only empty tank weight.
Loaded for camping, its true tongue weight will easily be over 1100lbs. That puts it in 3/4 ton territory.
Wish you had come here BEFORE buying that Wildwood.
Old 03-09-2024, 06:42 PM   #10
Oaklevel's Avatar
According to Wildwoods web site the trailer weighs close to 8000 lbs loaded. That would make the tongue weight well over 1000 lbs close to 1200 lbs.
Do not go by dry weight as others have mentioned gross weight would be closer. Bet since you have been living it the trailer is overloaded too.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Lillie Boxer Mix (RIP)
Old 03-09-2024, 06:50 PM   #11
You might want to list in the Classified section above.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
tow, towing
