I have large cardinal 4th wheel. I think you just have to experiment until you get a setting you feel good with. I have the ram integrated break controller ion the truck and it has several settings (light electric, heavy electric, light hydraulic over electric, and heavy hydraulic over electric). truthfully I do not know what these various settings do and the difference between them. but heavy electric seems the most descriptive for my situation. once that it set then you have to adjust the trailer brake gain. in my case 8.5 seems to work. each time I hook up I do a little test. i start to tow slowly and then i squeeze the manual override levels together without using the truck brakes. the trailer brakes will stop both the truck and the trailer. this at least lets me know they are working. as to the optimal gain setting, i really don't know how to know what it is. you'll get many different suggestions from various parties. i'm thinking that knowing that they are working before you take off is i good habit.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
