04-17-2023, 07:45 PM
Towing chains too short
I've a new hitch and the chains are too short. How do you extend them about 6 inches to a foot for an 8000lb trailer?
2016 Ram 2500 CTD 4x4 Big Horn
2017 Coachmen FE 292bhds
04-17-2023, 08:07 PM
It might help if you posted what brand and model WDH you have.
Sent from my SM-G781U using Forest River Forums mobile app
04-17-2023, 08:14 PM
If they are indeed too short, I would be more comfortable replacing rather than extending them.
2021 2205S Rockwood Minilite
2019 F 150 Lariat 3.5 Eco Fx4 Max Tow
Equal-i-zer WDH, 1809 lb payload
04-17-2023, 08:29 PM
You need new chains of the proper length for the strength.
2015 Dynamax REV 24TB class C
04-18-2023, 01:06 PM
04-18-2023, 02:47 PM
Originally Posted by aircommuter
This is like what I used. You remove the hooks, join the chains then put the hooks on the end. Not difficult.
2024 Artic Fox 3018 5th Wheel
Grand Design 2800BH TT 2021 - for sale
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW - on order
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload
04-18-2023, 03:36 PM
Brian & Becky
2018 Avenger ATI 27RBS
04-18-2023, 03:42 PM
There are a variety of safety chain extension cables available. Back when I had a travel trailer, I used something similar to this and it worked out well:
https://www.amazon.com/Trailer-Safet...NsaWNrPXRydWU=
2019 Georgetown GT5 31L5
04-18-2023, 06:44 PM
I was looking at those cable extensions, so it's nice to know someone has used something similar. Here's what I'm dealing with. For a Weigh Safe True Tow hitch. Attachment 286109
04-18-2023, 07:16 PM
Just remove the hook and use the cable extenders or the coupler and another piece of chain, then put the hooks on the end.
To remove the hook you just need to remove the cotter key from the pin, then slide the pin out. Reverse to replace the hooks, you may need ne cotter keys but if there is no cracking they are ok.
04-18-2023, 08:01 PM
It may also depend if you can get the length you need without making them too long and if you have a way to cut the chain. If not then you can just buy the pieces cut at a supplier for your needs.
04-18-2023, 08:59 PM
Canadian Member
Hopefully there is a metal tag on the existing chains that’ll tell you what grade your chains are. They are probably Grade 43. I just bought a Weigh Safe WDH for the new TT we have on order and it will require extending the chains so I bought Grade 70 - 5/16” chain to be sure it’s plenty strong enough. I’ll use a Grade 70 double clevis coupler to connect the two chains.
04-18-2023, 09:04 PM
The tag fell off a while ago.
04-18-2023, 10:11 PM
Section § 393.70: Coupling devices and towing methods, except for driveaway-towaway operations.
Guidance Q&A
Question 2: When two safety chains are used, must the ultimate combined breaking strength of each chain be equal to the gross weight of the towed vehicle(s) or would the requirements be met if the combined breaking strength of the two chains is equal to the gross weight of the towed vehicle(s)?
Guidance: If the ultimate combined breaking strength of the two chains is equal to the gross weight of the towed vehicle(s), the requirements of § 393.70(d) are satisfied. It should be noted that some States may have more stringent requirements for safety chains.
04-18-2023, 10:47 PM
Old guy having fun
Originally Posted by Backcountryboondocker
That is what I did on mine. As near as I can tell in Ohio they want each chain breaking strength (not the working load) to equal or exceed GVWR of the trailer. The chain and this quick link both meet that requirement. I did crank hard on the threaded "nut" to make sure it would not come loose and I do check the quick links every time I hook up and at each walk-around en route.
Dave / Believer45
04-18-2023, 11:00 PM
Those are almost twice price as the ones mentioned above.
04-19-2023, 12:54 AM
https://www.amazon.com/Curt-Manufact...%2C336&sr=8-13
And these ones are cheaper than the ones you showed. Things like connecting links are not hard to find in any size or design or price that you want. It just depends on what your preference is and what is the best thing for your application. And the amazon links are just for reference. Tractor Supply has them for cheaper.
04-19-2023, 07:24 AM
Geez, guys, these are $3 items and we're price shopping?
-- Chuck
04-20-2023, 12:02 PM
As always, a wealth of good info. Thank you all.
